Originally Posted by Jivewalker
Drive shaft spiders lubed? how many miles on the runner? Changed the oil in the diffs? Transfer case? Check your wheel bearings. Alignment? I would think tires, but you say you swapped them.
It has 90,000 on it, mobile one 75/90 front and rear diffs, changed every 20,000 . Drive shafts lubed every 5,000 transfer case changed every 20,000 with royal purple. Alignment done dead on.
Maybe it is the needle bearings and mine just presents it a little different than everybody else's?
Ironically I have a set of East Coast gear front rear diffs on the way (4.56). Maybe that'll take care of the issue.
