Old 05-12-2021, 09:06 AM #1
MyFirstRunner's Avatar
MyFirstRunner MyFirstRunner is offline
MyFirstRunner is on a distinguished road
Firestone Air Helper Springs
Hi, installing the these helper springs this weekend to help with towing my pop-up camper.
Where did you all install your valves?
Also, it came with 2 small red pieces in the parts bag, anyone know what they are for?
Thanks!
Amazon.com: Firestone W237604135 Coil-Rite Kit: Automotive
MyFirstRunner is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 09:38 AM #2
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Not mine - but this is where I put mine only on the passenger side.
Old 05-12-2021, 09:53 AM #3
scratchhax scratchhax is offline
scratchhax has a spectacular aura about scratchhax has a spectacular aura about
I mounted mine to the hitch wiring bracket
scratchhax is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 11:37 AM #4
I like that!
Old 05-12-2021, 11:41 AM #5
My only concern with above the bumper is introducing a rust point. Any issues over time?
Old 05-12-2021, 12:02 PM #6
meltdown meltdown is offline
meltdown will become famous soon enough
I have my air bags run to a single valve. I mounted it just behind the drivers side rear mud flap towards the inside of the truck. I donít have a picture, but if you look at it from below itís easy to figure out. Easy to get to and install. Surprisingly, it stays very clean in that location.
2014 MGM TEP - Dobinsonsí C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 02:11 PM #7
Do you have problems with cornering going to a single valve? When I installed mine it was suggested (by etrailer) to keep them distinct otherwise they said you could run into an issue where compression on one bag causes the other to expand ie cornering. Not likely to cause major stability issues unless you really over did it with the bags, but additional wear and tear.
Old 05-12-2021, 03:10 PM #8
Jetboy's Avatar
Jetboy's Avatar
No problems. It's all plastic there, so no rust concerns. And it's easy to go back if you want to remove. Two barbed push rivets would cover the holes pretty easily. Or you could replace the the plastic bumper trim piece.
The location is inside the rear door edge, but outside the door seal. Its not totally protected from dirt and road grime, but mostly protected. So they stay pretty clean.
Old 05-12-2021, 03:51 PM #9
Smitty19TRD Smitty19TRD is offline
Smitty19TRD is on a distinguished road
I will keep mine separate for that very reason. Combining properly requires a valve to keep the air from transferring across.
The hoses are small so I don't think the air would travel rapidly; however, if you are on a sweeping curve, you would end up transferring pressure. That being said, depending on the load, as in, still being comfortably within the limits of the suspension, it may not be a glaring issue. I will still keep mine separate.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 04:11 PM #10
Does anybody know what the two little red pieces are that come with the kit? Are they just to reform the tubes after you cut it?
Old 05-12-2021, 04:35 PM #11
QwikKotaTx's Avatar
QwikKotaTx QwikKotaTx is offline
QwikKotaTx is on a distinguished road
QwikKotaTx's Avatar
Have them on my Ram with a tee to single valve. Have not noticed any issue when cornering. I have mine attached to a vertical surface with a hole in it on my hitch, used large washers to make up the difference.
2010 SR5 MGM w/LEATHER
2002 DAKOTA 4.7L V8 VIPER T56
2015 RAM LARAMIE HEMI
QwikKotaTx is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 04:47 PM #12
AggieOE's Avatar
AggieOE AggieOE is offline
AggieOE is on a distinguished road
AggieOE's Avatar
Used Airlift bags and ran the valve to the top of the bumper under the liftgate as someone posted earlier. Single valve though split to both bags. I've had it since November and no issues yet. Super helpful when loaded up or towing!
2015 4Runner SR5 4x4
Bilstein 5100s at 1.75-F with 1.5" Cornfed-R, AirLift 1000 Airbags, 265/70 BFG KO2s, Shrockworks Sliders
2016 Jeep Wrangler Unlimited Rubicon
AEV 2" Lift, 34" BFG KO2s, ARB Bumper
AggieOE is offline   Reply With QuoteReply With Quote
Old 05-12-2021, 07:03 PM #13
I have not noticed any issues. When towing my normal load (About 2500 lbs), I run between 15-20 psi. The roads are pretty straight through the delta region too. When not towing, theyíre set 5 psi or less.
I use a small bike hand pump to air them up. Combining them on one valve saves me some time. I doubt on road driving would be affected much. If I offroaded heavily or did rock crawling, I would probably separate them.
Old 05-16-2021, 03:49 PM #14
Installed them today, a lot of work without taking apart the suspension but as others aid, itís doable. Did take off the pan hard bar which gave a little more room for the passenger side.
Thanks for the help!
Old 05-16-2021, 10:07 PM #15
IrishRover's Avatar
IrishRover IrishRover is offline
IrishRover will become famous soon enough
IrishRover's Avatar
I just installed a pair and did a 2400 mile road trip. Very noticeable difference and confidence in handling. I decided to combine them into a single hose/input for safety and simplicity. The air pressure will equalize and if one fails on a trip, one side wonít dip. I figured this is the safest approach as my rear suspension sags about 2Ē without the airbags.
IrishRover is offline   Reply With QuoteReply With Quote
helper , parts , pieces , red , springs
Which helper springs can I use with 9 wrap LC coils? yotatake2 3rd gen T4Rs 5 04-25-2017 11:42 AM
Anyone use a Daystar Leveling kit with the Firestone Rear Coil helper bags? ChaosStarter 4th Gen T4Rs 2 04-20-2015 12:33 PM
Just being a Houston helper 3rd gen king 3rd gen T4Rs 15 03-25-2012 06:02 PM
3rd gen parts: Highlander tall springs, Firestone Coil Rite Air Bag asmtrd For Sale: Suspension/Wheels/Tires 5 11-19-2011 10:39 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
