Old 05-13-2021, 06:44 PM #1
Bry n Bry n is offline
Bry n will become famous soon enough
SLEE bracket for driver side air compressor install
So I test fitted the bracket and noticed flex hoses rubbing against the side of the bracket which do happen to be on the sharp side. Has anyone had any issues with the bracket slowly eating at these hoses with regular vibrations? Or have people just relocated/adjusted these hoses to not run against it? Just wanted to see what people have done. Not sure if it’s different with models 2019 and below. I know a few things have moved a slight bit in 2020+ within the engine bay.
Side note: time lapse of SLEE bracket install for 2020+ 4Runner fuse/relay box relocation Login • Instagram
SLEE bracket for driver side air compressor install-4f4c75ab-ad68-4884-b3dd-bfbfd6f7bc22-jpeg  SLEE bracket for driver side air compressor install-6713f2c9-a826-46d6-b79c-e3d2a0c8d6d5-jpeg
Bry n is offline   Reply With QuoteReply With Quote
Old 05-13-2021, 10:05 PM #2
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Mmm, I think you would be asking for trouble with the contact, and it seems like a lot of work to relocate hoses.
I had a Rago mount for 2 years in my 2019 and didn't have that problem (great fit and I liked that it was aluminum). I replaced that this summer with a PowerTray and it doesn't have that problem either (added a Switch Pros).
Can you send it back? Easiest to go with a different brand IMO.
rageandlove is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 02:33 AM #3
Gonna contact SLEE about it. Sad, though. I’ve read nothing good stuff about the SLEE mount on this forum. I’m surprised it wasn’t mentioned. You actually have to push those hoses aside to get the mount in place so the hoses are sitting fairly firmly against the edge of the bracket once let go.
On the positive side their relay box relocation bracket worked perfectly to regain the space 2019 and below models have in the same area of the engine bay
Old 05-14-2021, 09:33 AM #4
2112 R's Avatar
2112 R 2112 R is offline
2112 R will become famous soon enough 2112 R will become famous soon enough
2112 R's Avatar
I have an ARB comp installed there and once you get it in there my main issues is the dam thing gets very very hot when airing up.
Understanding that the comp itself is going to generate a lot of heat when active I think the basic location of the bracket itself puts the unit in a place that's already kicking out a lot of engine heat, especially after hitting the trail.
Just wanted to give you a heads up that once you get it in there, I would suggest an ARB remote hose coupling kit like this:
ARB Remote Hose Coupling Kit | 171314|Northridge4x4
My arb orange hose overheated and burst due to the heat when it was connected directly to the comp. Since relocating the hose output (with a 3' braided cable to the new hose coupling) I've had no issues.
2112 R is offline   Reply With QuoteReply With Quote
Old 05-14-2021, 10:55 AM #5
I've had no problems with heat. The ARB hoses are junk though. I ditched mine and bought a flexzilla. Much higher quality.
Old 05-14-2021, 11:08 AM #6
2112 R's Avatar
2112 R's Avatar
Really? The air comp itself and even the metal braided hose I have running off it to the remote coupling get insanely hot.
I was thinking it had to do with the friction from the air comp as it generates pressure, combined with the fact that it's sitting right on top of the engine when mounted in that spot.
Even after cleaning out the little filters and everything it still generates a ton of heat.
Maybe climate is also a factor since we're wheeling in the desert 90% of the time and pretty much everything is cookin on the vehicle.
Old 05-14-2021, 09:05 PM #7
I'm sure climate matters. I live in Seattle and most of where I go is WA/OR/ID/MT/BC/AB. So, 80 is hot. And it's rarely that hot in the mountains.
I still run stock wheels/tires too, so air ups don't take too long. I'm sure if I ran bigger tires, more heat.
Old 08-18-2022, 03:27 PM #8
Humble Leader's Avatar
funny I came across this thread. I had a slee bracket on my workbench that I hadn't installed yet. I went to do a test fit and ya you are right, in my 2012 there is an uncomfortable amount of movement of the hoses that needs to happen to fit this bracket. the only way it fits somewhat comfortably is to run the flex hose under the left side of the bracket, where it rests on a sharp edge.
I too have read many good reviews about slee but I can't put that in my truck as is. will be getting a rago now if I can't find a way to nicely move those hoses out of the way...
2020+ , bracket , hoses , people , side
ARB twin compressor + Slee bracket fit w/out manifold? b407driver 5th gen T4Rs 10 07-05-2021 07:59 AM
5th Gen: Lightbar mounts & Slee Compressor Bracket - ATL Area Terrapod For Sale: T4R Items 0 03-23-2020 05:12 PM
FS: 5th Gen Slee Single or Dual Compressor Bracket $60 + shipping DFW_TRD For Sale: T4R Items 2 12-30-2018 10:16 AM
Wtb 01-02 t4r driver side motor mount bracket. xspsi6 Want to Buy/Trade 0 12-28-2014 12:46 AM
WTB: Driver side traction arm bracket Kehl79 Want to Buy/Trade 0 06-28-2011 02:04 PM
