05-14-2021, 07:01 PM
TRD 4runner: This noise is driving me crazy
Can anyone help diagnose this problem? I made this video when the car had 200 miles on it. I have taken it to the dealer twice and each time they say the car is to spec and they can't hear the noise. It is driving me and my wife insane.
I did some research and it seems different that a lifter noise but maybe someone here on the forum can help? I am talking about this oscillating noise in the background.
Shared album - Titus Leo - Google Photos
Thanks.
05-14-2021, 07:13 PM
It's your motor.
You're welcome.
05-14-2021, 07:47 PM
Sounds totally normal to me. Maybe go sit in another 4Runner with the engine running and see if it sounds the same?
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
05-14-2021, 08:05 PM
Don’t worry, it’ll sound like that for another 20 years.
05-14-2021, 08:11 PM
Not normal at all, it’s a lemon. I’ll start the bidding at $100
05-14-2021, 08:31 PM
I bid $102.
‘19 Limited Nightshade, Midnight Black Met, front leaving kit, 265/60R20 BFG KO2’s, fronts tinted to 20%, moonroof to 5%, Magnuson Supercharger
'03 Harley Dyna Superglide Sport
05-14-2021, 08:53 PM
P.S. You and your wife may want to work on your "drives me crazy" threshold, because 4Runners make a LOT of weird noises.
05-14-2021, 10:06 PM
Originally Posted by nimby
It's your motor.
You're welcome.
05-14-2021, 11:01 PM
Thanks.
Unlike many other cars, Toyota uses a chain drive for the camshafts/valves instead of a timing belt. A whirring sound like this is normal. Chains last forever; you never will need to replace a timing belt.
05-15-2021, 01:47 AM
Mine was making the same noise.
Your main fuse box is under the hood driver side. Open it up and find the flux capacitor. It has an adjustment screw, turn it to the left very slowly and you should notice a reduction in noise. Be sure to use a left handed screwdriver.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
05-15-2021, 05:03 AM
Real Name: BLACK TRD PRO
Just don’t hit 88mph after the adjustment. Although, a 4Runner may never make it to 88mph.
05-15-2021, 06:57 AM
Honestly most modern cars use timing chains anymore. Timing belts are mostly a figment of the 90s/early 2000s
2020 4Runner Venture
2002 4Runner SR5 4WD (sold)
1998 BMW M3/4/5
05-15-2021, 07:08 AM
Completely normal. In time you will not even notice it.
2014 Super White TEP, Dobinsons 2"/1" lift, Firestone Destination AT2 265/70‑17, OEM led headlights 81070-35600/ 81140-35610
05-15-2021, 08:39 AM
You need to give it a little more gas ;)
120 is when mine hits the limiter.
2024 Lexus GX550 Overtrail+ - pre ordered
2021 TRD Pro - Lunar Rock
2017 TRD Pro - Super White, RCI Rock Sliders, Falken Wildpeak A/T3W - SOLD
2012 Porsche Cayman S
05-15-2021, 09:57 AM
Not always. My 1992 Toyota pickup that I bought new, threw its timing chain at 49000 miles. Put me off Toyota’s for years.
