Old 05-15-2021, 12:06 AM #1
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 will become famous soon enough 2021nightshade4x4 will become famous soon enough
Will these tires+wheels fit? Help me with offset and tire size math
Username says what I drive. All stock thus far. Thinking of adding these wheels:
4PLAY(R) 4P60 Wheels - Black with Brushed Face Rims
In a 22x10, -18 offset, 6x139.7 bolt pattern, 106mm hub.
I wish to mount a 285/45R22 tire on these. Curious if backspacing alone is enough to clear without modifying suspension. (I have X-REAS)
Stock: 245/60R20 = 31.6x9.6
Install: 285/45R22 = 32.1x11.2 (this is an EXTREMELY low profile A/T tire, only found Nitto Terra Grapplers in this size, no BFG)
Will this setup clear stock height without trimming? I didnt find this (specific) size in the cheat sheet with the green/yellow/red for all the tire sizes and if they clear.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 08:30 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough rdruss is a jewel in the rough
rdruss's Avatar
Real Name: Ron
Well, the vehicle fitment for a 2021 4runner 4x4 says that wheel does not fit your vehicle. Your proposed tire is 2" wider than stock, that's a lot. How is your current clearance to UCA? You will no doubt need to push that tire to the outside but then you probably will have rubbing on the front/rear of wheel well when turning. So you have a fun project ahead of you.
There are wheel fitment charts you can google and put in your current wheel/tire setup and your proposed and it will show you what will happen. I would use that before any major wheel/tire changes.
Old 05-16-2021, 02:26 AM #3
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
you're buying 22's for a 4runner. who the f*ck cares if they fit. sell the 4runner and buy an escalade.
blackened_offroad is offline   Reply With QuoteReply With Quote
285/45r22 , clear , offset , stock , tire
NEED HELP (Tire size, Wheel offset, Lift?) Jordanbiird 4th Gen T4Rs 3 06-25-2018 07:48 AM
Wheel fitment help - 17x8.5 - 0 offset -will it fit? should I go with different size? chrissurfr 5th gen T4Rs 2 04-26-2018 09:05 AM
NEED HELP! Rim / Tire / Offset SIZING! Jordanbiird 4th Gen T4Rs 4 07-29-2017 11:59 AM
Rim Size VS offset VS backspace question(s) kapp_badbloodz 5th gen T4Rs 23 07-09-2015 10:44 AM
Wheel size and offset for 255/80/17 Tires? alexb 5th gen T4Rs 29 08-25-2014 03:53 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
