Old 05-15-2021, 12:06 AM #1
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Will these tires+wheels fit? Help me with offset and tire size math
Username says what I drive. All stock thus far. Thinking of adding these wheels:
4PLAY(R) 4P60 Wheels - Black with Brushed Face Rims
In a 22x10, -18 offset, 6x139.7 bolt pattern, 106mm hub.
I wish to mount a 285/45R22 tire on these. Curious if backspacing alone is enough to clear without modifying suspension. (I have X-REAS)
Stock: 245/60R20 = 31.6”x9.6”
Install: 285/45R22 = 32.1”x11.2” (this is an EXTREMELY low profile A/T tire, only found Nitto Terra Grapplers in this size, no BFG)
Will this setup clear stock height without trimming? I didn’t find this (specific) size in the cheat sheet with the green/yellow/red for all the tire sizes and if they clear.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 05-15-2021, 08:30 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Well, the vehicle fitment for a 2021 4runner 4x4 says that wheel does not fit your vehicle. Your proposed tire is 2" wider than stock, that's a lot. How is your current clearance to UCA? You will no doubt need to push that tire to the outside but then you probably will have rubbing on the front/rear of wheel well when turning. So you have a fun project ahead of you.
There are wheel fitment charts you can google and put in your current wheel/tire setup and your proposed and it will show you what will happen. I would use that before any major wheel/tire changes.
Old 05-16-2021, 02:26 AM #3
blackened_offroad blackened_offroad is offline
blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about blackened_offroad has a spectacular aura about
you're buying 22's for a 4runner. who the f*ck cares if they fit. sell the 4runner and buy an escalade.
blackened_offroad is offline   Reply With QuoteReply With Quote
285/45r22 , clear , offset , stock , tire
NEED HELP (Tire size, Wheel offset, Lift?) Jordanbiird 4th Gen T4Rs 3 06-25-2018 07:48 AM
Wheel fitment help - 17x8.5 - 0 offset -will it fit? should I go with different size? chrissurfr 5th gen T4Rs 2 04-26-2018 09:05 AM
NEED HELP! Rim / Tire / Offset SIZING! Jordanbiird 4th Gen T4Rs 4 07-29-2017 11:59 AM
Rim Size VS offset VS backspace question(s) kapp_badbloodz 5th gen T4Rs 23 07-09-2015 10:44 AM
Wheel size and offset for 255/80/17 Tires? alexb 5th gen T4Rs 29 08-25-2014 03:53 PM
