Old 05-18-2021, 11:16 AM #1
Reverie Reverie is offline
Real Name: Nick
Reverie is on a distinguished road
Real Name: Nick
Parking Brakes Will Not Fit into Rotor
I replaced the rear pads and rotors a few months ago and noticed that the parking brakes were wearing, as though they were applied while driving. I made a mental note and ordered the shoes and hardware kit. A couple of weeks later I was driving and heard an awful grinding sound coming from the rear. I stopped and pulled off the rotors and discovered the retaining pin and Shoe Strut had both become dislodged. The strut was still there but the spring and retaining cup were both gone. I removed the rest of the hardware and drove home. When I installed the new shoes and hardware kit, everything installed nicely. The Hold Down Springs were a pain to install because of the hub, but I managed. The problem arose when I wanted to reinstall the Rotor/Hub. Nothing I could do, short of beating it on with a hammer, could get the Rotor/Hub over the parking brakes. My first thought was that the adjuster was too far out. Upon examination I found that it was run all the way in and was tight. When I actuated the parking brake pedal, the brake mechanism worked smoothly. Still, the Rotor/Hub would not go over the brakes. I then disassembled the brakes and reinstalled the hardware and encountered the exact same problem. It then disassembled the brake again and took everything to a nearby shop. They ran into the same problem. They had new shoes and hubs delivered and they have the same issue. I have called Toyota and they sent me the pictures which confirmed everything was installed properly. Now I have no parking brakes and an unhappy wife. Has anyone else run into this? There is a special place in mechanics hell for whoever designed this. I know this is a standard way to do this in Toyota vehicles but it is an iron-assed biatch to fix.
Reverie is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 12:05 PM #2
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Can you provide more info.
Got pics?
What year?
Did you buy used?
Can you tell if the brakes were serviced before you did them?
Is there slack in the brake cable when you’re trying to compress the assy?
1000MPH is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 01:00 PM #3
Real Name: Nick
Real Name: Nick
Got pics?
What year?
Did you buy used?
I have pics and I'll figure out how to post them. It is a 2011 SR5 4x4. I purchased it as a Toyota Certified Preowned. I'm guessing it was a lease as the same person shows up on the records for the first two years. I do know it was from Pennsylvania, so it was exposed to salt. That may be why the hardware failed eventually. The rear brakes were replaced prior to this but not the parking brakes. I'm not sure this is what you are looking for but when I depressed the parking brake it expaned the brakes as expected. When I released the parking brake pedal the cable slacked but the brakes only compressed a little. Not as much as I expected.
Old 05-18-2021, 02:14 PM #4
BlueRidge77's Avatar
BlueRidge77 BlueRidge77 is offline
Real Name: Michael
BlueRidge77 will become famous soon enough
Real Name: Michael
There may be additional issues you’re dealing with, but could you take the rotor to a shop with a brake lathe and have them “turn” that portion like we used to turn and true up old drums in full drum brakes. Could you remove some material that way for it to fit...?
2016 MGM TEP w/KDSS - P285/70-17 Toyo Open Country AT3 on Stock Trail wheels, no spacers - Dobinsons IMS Lift 2.75”/2” (302/505 Springs) - Freedom Off-road UCAs - TRDP Grill - Redarc Trailer Brake Controller - SumoSprings Helper Spring Bumpstops (black)
BlueRidge77 is offline   Reply With QuoteReply With Quote
Old 05-18-2021, 02:31 PM #5
1000MPH's Avatar
1000MPH's Avatar
Look at this thread in the 4th gen section.
Broke something in the parking brake mechanism while doing the rear disc brakes
Sounds like a common issue is the hold-down springs get elongated and need replacing for everything to fit back together.
Old 05-18-2021, 03:36 PM #6
Real Name: Nick
Real Name: Nick
I hadn't considered having the drum turned. I don't even know for sure if it can be done on one of the combination Rotor/Drum but it may be worth a try. They are brand new but nothing else seems to work so, what's another 50 bucks?
Old 05-19-2021, 10:04 AM #7
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
Be sure the emergency brake actuation cables are free. It is common to get moisture in the cables, then they rust and seize up. Or in the winter, the moisture will freeze and the cables will not slide in the sheath as they should.
fkheath is offline   Reply With QuoteReply With Quote
brake , brakes , hardware , parking , shoes
Spongy brakes after rotor/pad change daesonn 5th gen T4Rs 6 11-14-2019 07:09 PM
When ordering brakes what mm rotor do I need? bassmacka 4th Gen T4Rs 5 10-02-2017 01:23 PM
Weak parking brake after pads/rotor change 13sr54runner 5th gen T4Rs 14 02-06-2016 07:28 PM
Change Front Brakes, pad & rotor suggestion! AE1M 4th Gen T4Rs 0 08-13-2012 01:12 PM
Rear rotor swap, parking brake stuck ? project-roc 4th Gen T4Rs 2 09-08-2011 07:01 AM
