Old 05-18-2021, 09:50 PM #1
Xanderzuk88 Xanderzuk88 is offline
Xanderzuk88 is on a distinguished road
Pro Lift - Westcott Front & Eibach Rear?
I have a 2021 TRD Pro and I’m looking for a lift kit that utilizes the factory Fox shocks.
The Westcott Designs kit is really appealing but I noticed they sell the front components individually. This got me wondering, are people pairing the front collar with a different spring in the rear?
I was thinking I might be able to pair the front Westcott collar with the rear Eibach springs since the rears are supposedly unchanged for the 2021.
I would be interested in getting the Eibach springs all the way around but my understanding is that they won’t be out until August/September and I have an off-road trip through Colorado and Utah planned for early August, so I’ll have to find something different.
Btw, I’m also trying to decide between 285/70/17 or 255/80/17 on the factory wheels. Feel free to throw your two cents in on this as well.
Xanderzuk88 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 06:44 AM #2
DallasTRDPro's Avatar
DallasTRDPro DallasTRDPro is offline
DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light DallasTRDPro is a glorious beacon of light
I don't see why you couldn't pair the two. I have the Eibach springs and am very happy with them. Way easier to install. I am a fan of the Westcott stuff, but chose the easier path and my installer was happy I did. I will always believe a spring replacement is better than a spacer or a collar.
I also have 285's and love the look. I wouldn't want a skinnier stance although it would be better for mileage I bet, but it would be marginal at best.
DallasTRDPro is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 12:15 PM #3
Do you think Westcott front and Eibach rear will be even front to back?
Old 05-19-2021, 01:57 PM #4
MGordo MGordo is offline
MGordo has a spectacular aura about MGordo has a spectacular aura about
That is exactly my setup... was planning on going full Eibach, but didnt want to wait till September. Worth mentioning, I only used the lower Westcott perch as I felt it would give me the ride height I wanted. Rear is a littlw lower due to weight.. ski gear up top and two bikes plus rack on the back.
My tires are 285/65/18 and fit stock, but also different offset wheels.
No complaints what so ever.
Pro Lift - Westcott Front & Eibach Rear?-4runner-inv-2-jpg
MGordo is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 10:24 PM #5
Wow, great looking rig! So if you out the top plate in, how would it sit?
Old 05-20-2021, 01:13 PM #6
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
You can run the 285s with the pro ins stock trim...thats what I did. Slight rubs fixed with a heat gun. I am waiting on the eibach springs too and this worked for me. Its fine until they get in. Off road only minor rub on steep downhill left turns. Minor enough that I have not bothered to address.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 02:29 PM #7
So even in full articulation, no real rubbing issues?
Have any pics you could share of your setup?
Old 05-20-2021, 03:02 PM #8
lewdog998's Avatar
lewdog998's Avatar
Have not done a full articulation test. But after install of 285s I did spend a week in New Mexico mountains on some pretty rough terrain...from NM CO border to roswell.
Did not have any issues. But since you asked I just took a look at my truck and took some pics for you. Keep in mind that I have the 285 70 duratacs which measure a full 33 od according to manufacturer. From what I can see it looks like the heat gun mod may have bounced back a bit. I drive pretty aggressive and don't slow down much for driveway transitons, speed bumps etc. As far as pushing wheel travel I have definitely pushed it...the kids like hitting transitions fast. Anyways, it looks like the rear of each well, the liner has sprung back a bit, maybe I did not get hot enough. You can see the obvious clean spots.. mine is a 20 model with the TSB fronts,, so the same as a 21. There is no rub on the front of wheel well. Hope this helps.
Pro Lift - Westcott Front & Eibach Rear?-20210520_135101-jpg  Pro Lift - Westcott Front & Eibach Rear?-20210520_135133-jpg  Pro Lift - Westcott Front & Eibach Rear?-20210520_135157-jpg  Pro Lift - Westcott Front & Eibach Rear?-20210520_135224-jpg
Old 05-25-2021, 01:25 PM #9
Front would be ~1" higher. I am quite happy with how everything sits and rides as is.
Old 05-28-2021, 04:38 PM #10
JRod0981 JRod0981 is offline
JRod0981 is on a distinguished road
Would this Westcott Designs be a good option for a 2017 with the billstein shocks with 40k miles on them vs the Fox shocks in later pros? I just found out about this lift option today and trying to weigh this versus a 2"-3" lift from Dobinsons or Toytec.
I don't want to do something cheaply and this is a very attractive pricepoint. Trying to gauge if this is worth it or if I should just go all in on something mentioned above. How is this not just a body/spacer lift?
JRod0981 is offline   Reply With QuoteReply With Quote
Old 05-29-2021, 10:39 AM #11
I think the Wescott lift is just for the Pro/Fox suspension. I could be wrong though.
Old 05-30-2021, 06:00 PM #12
Yeah, that's how I took it. Mean to work with the stock TRD PRO suspension. I have a 2017 pro and I think those were billstien shocks rebadged to TRD shocks. Later the shocks in the PRO were moved to FOX I believe.
Old 09-18-2021, 07:18 PM #13
Izam559 Izam559 is offline
Izam559 is on a distinguished road
Any word on eibach release date?
Izam559 is offline   Reply With QuoteReply With Quote
Old 09-18-2021, 09:15 PM #14
Zal4R Zal4R is offline
Zal4R is on a distinguished road
Last update was they will be available sometime in Q4.
Zal4R is offline   Reply With QuoteReply With Quote
Old 09-19-2021, 12:21 AM #15
Thank you.
collar , eibach , front , rear , westcott
Lift Kit - TRD Pro by Westcott Designs V2009 5th gen T4Rs 33 04-03-2023 08:07 AM
Lift Kit - Factory Fox TRD Pro by Westcott Designs Maka15 5th gen T4Rs 78 12-06-2021 05:57 PM
Westcott Designs vs Eibach lift kit for trd pro alpaka5 5th gen T4Rs 11 10-27-2020 08:43 PM
Fs: Toytech/Eibach front lift springs 98runnerelock For Sale: Suspension/Wheels/Tires 4 01-05-2017 09:43 PM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
