Old 05-19-2021, 10:31 AM #1
t4rlol's Avatar
t4rlol t4rlol is offline
t4rlol is on a distinguished road
t4rlol's Avatar
Made a dumb electrical mistake with my headlight HI beams
**DUMBASS MISTAKE ALERT** So a few years ago I followed a post on this forum to wire up raptor lights in the grille of my 2016. The post suggested tapping into (I know, I know...) the HI beam headlight harness which I did, and the raptor lights lit up, but after that point the HI beam / DRL bulbs never worked correctly even after removing the stupid raptor lights.
Lo Beams ON: HI beams don't light up with push or pull of stalk; dash indicator does light up.
Lo Beams OFF: HI beams do light up with push or pull of stalk; dash indicator does light up.
DRL position on the stalk never works. IIRC the HI and DRL share the same bulb so guessing related.
I did a check of fuses I thought could be related but don't see any burned out. Maybe it's a relay? I do have TechStream installed on a laptop and thought about trying to diagnose with that?
Any ideas?
t4rlol is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 12:21 PM #2
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Did you try changing the high beam bulbs ?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 12:34 PM #3
17KT4R 17KT4R is offline
17KT4R will become famous soon enough
Examine where you ‘tapped’ in very closely. Suspect there’s a fault there, you may have not repaired correctly. Strip it all back and inspect, solder the joint together or whatever you did there... good luck Made a dumb electrical mistake with my headlight HI beams
2017 TRD OR / KDSS / Canuckistan Edition
17KT4R is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 03:46 PM #4
t4rlol's Avatar
t4rlol's Avatar
Thanks that's probably a good call, it's just wrapped with electrical tape. I figured since the highs come on if the lows are off then the cabling itself was probably fine but can't hurt to check.
I didn't, because they turn on if the low beams are off. Figured that ruled out needing to replace the bulbs. Who knows though, maybe worth a shot.
Old 05-19-2021, 04:25 PM #5
You mentioned that drl does not work. Drl and high beam use same circuit. Only difference is pcm is on when drl mode.
Either bulb is damaged and won’t run In drl mode (pcm mode) or pcm mode in circuit my be bad.
Old 05-19-2021, 04:35 PM #6
srsrogerissrs's Avatar
srsrogerissrs srsrogerissrs is offline
srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice srsrogerissrs is just really nice
Remove the tap, verify if the highbeams work in your test above... if not.. then it's probably a bad relay. Then go buy yourself a fuse tap and use that instead.
2016 White TEP
srsrogerissrs is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 04:56 PM #7
t4rlol's Avatar
t4rlol's Avatar
Good info, thanks guys. I'll dig back in this weekend.
beams , drl , light , lights , raptor
I made a mistake... Cwright26 Maintenance/Detailing 8 10-04-2020 09:06 PM
I made a huge mistake... aelarson General Discussions 19 04-22-2017 10:01 AM
Dumb mistake, now no starting Jojosdad 3rd gen T4Rs 5 01-18-2015 09:53 PM
PepBoys made a big mistake! perfectmax 4th Gen T4Rs 14 12-02-2005 05:11 PM
Pep boys made a big mistake! perfectmax Classic T4Rs 3 12-02-2005 03:44 PM
