Old 05-19-2021, 03:51 PM #1
clarkyclark87 clarkyclark87 is offline
Real Name: Clark
clarkyclark87 is on a distinguished road
Real Name: Clark
help with Magnuson Supercharger
Is anyone else having problems with the Magnuson Supercharger? My truck is a 2019 TRD Pro. Supercharger installed Jan 2021 at a local Magnuson authorized dealer.
Recently I took my truck to the local Toyota dealership for unrelated reasons and the mechanics found two issues:
1) The check engine light is on because the air intake hose (red cuff tip) cannot be firmly fastened to the engine block because the cuff length is too short. See attached photo. Is it possible to fabricate a longer cuff or do I need to buy a longer hose?
2) Coolant fluid is leaking from the right hose. See attached photo. There is a big pink mess dripping onto the wiring and pin connector below the hose. Is there a solution for this or a custom fabrication?
Are these problems my responsibility or the installer responsibility?
help with Magnuson Supercharger-img_0232-2-jpg  help with Magnuson Supercharger-img_0233-2-jpg  help with Magnuson Supercharger-img_0234-2-jpg
clarkyclark87 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 03:53 PM #2
Whippersnapper02's Avatar
You can always purchase a different coupler from various places. Try moving the tube over towards the driver side first. Loosen all the clamps and pull it over if there is enough space for the clamps to still work.
The leak is common with those tanks. My Tacoma supercharger kit leaked from the same place. There's a fix but I forgot what it was but you can try tightening the clamp. There is also a metal tank available.
Old 05-19-2021, 04:45 PM #3
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Posted this on the other forum also.
Constant torque clamps
Constant Torque Clamp, #10 9/16 - 1 1/16 (BRZ-10)
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 05:47 PM #4
Axix23's Avatar
Axix23 Axix23 is offline
Axix23 will become famous soon enough Axix23 will become famous soon enough
Axix23's Avatar
You can also put some Honda bond or any kind of high temp liquid gasket on the edges of the hoses and retighten the clamps. And also add another clamp. It worked for me.
Axix23 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 06:30 PM #5
TrailRunnin14's Avatar
TrailRunnin14 TrailRunnin14 is offline
TrailRunnin14 has a spectacular aura about TrailRunnin14 has a spectacular aura about
The one minute gasket maker works pretty good too. The TRD intake coupling should work with no issues, not sure what is going on there.
TrailRunnin14 is offline   Reply With QuoteReply With Quote
Old 05-19-2021, 09:47 PM #6
4rNCMTNs 4rNCMTNs is offline
4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light 4rNCMTNs is a glorious beacon of light
I have a URD not a Magnuson, but what are your CEL's. I had several repeating CEL's after my install and it just took the proper tune to get them all cleared and it optimized for the the '19.
i also changed all the clamps as a few came loose and fell off while driving and let's just saw that's not fun.
the leaking coolant should be an easy thing to find and resolve.
4rNCMTNs is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 01:02 PM #7
Hans Moleman Hans Moleman is offline
Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about Hans Moleman has a spectacular aura about
Use constant tension clamps. That is why OEMs use them.
2018 SR5 Premium MGM
TRD Pro wheels
LT265/70/17C BFG KO2
Hans Moleman is offline   Reply With QuoteReply With Quote
Old 05-20-2021, 02:29 PM #8
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
The TRD intake should fit fine although it is pretty tight at the throttle body side because of the SC bypass valve. I would say that's a installer issue. The intake tube may be pushed too far in on the filter box side making it short on the throttle body side. You can fix this yourself, but if you take it back to the shop, make sure they don't try to adjust the bypass valve on the SC to make more room. It's clearly marked not to adjust it, but you never know what someone else may do
help with Magnuson Supercharger-supercharged-jpg
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 09:19 PM #9
a47chuck's Avatar
a47chuck a47chuck is offline
a47chuck will become famous soon enough a47chuck will become famous soon enough
a47chuck's Avatar
This is a common problem. If you don't want to take it back to the installer, you could just clean up the leakage mess and re-tighten the clamp. Three times was a charm for me (only once on the left return side). Just checked after the last tightening, which was a few of months ago ... no runs, no drips, no errors. Also check the coolant level in the reservoir. Should be at the bottom of the return hose inlet (left side). Mine was installed by the dealer when new, so I guess they used Toyota coolant. That's what I put back in. Only took about 1/8 cup. You could also add a constant pressure clamp for piece of mind. Not catastrophic. Good luck and enjoy the extra "git up and go!" Hope this helps.
BTW, looks like your intake hose clamp needs to be moved closer to the throttle body at the top. It's not where it should be. There are ribs where the clamp needs to be between. Just and observation.
‘19 Limited Nightshade, Midnight Black Met, front leaving kit, 265/60R20 BFG KO2’s, fronts tinted to 20%, moonroof to 5%, Magnuson Supercharger
'03 Harley Dyna Superglide Sport
a47chuck is offline   Reply With QuoteReply With Quote
Old 05-21-2021, 11:28 PM #10
edizzle edizzle is offline
edizzle is on a distinguished road
your observation correlates to his 1) issue in his post!!
edizzle is offline   Reply With QuoteReply With Quote
cuff , engine , hose , magnuson , supercharger
i think i want a magnuson supercharger, but questions bradze Engines / Suspension / Wheels / Tires / Audio / Accessories 13 10-14-2022 03:21 PM
Magnuson decal on TRD supercharger Bigmd 3rd gen T4Rs 3 12-03-2019 01:35 PM
Magnuson Supercharger or GX460? MrGainzz General Discussions 20 11-10-2018 07:25 AM
Anyone ever install a Magnuson supercharger? bassmacka 4th Gen T4Rs 14 02-08-2018 03:44 PM
