Old 05-05-2022, 04:04 PM #31
bravozero bravozero is offline
bravozero is on a distinguished road
Barbed wire around the cat.
bravozero is offline   Reply With QuoteReply With Quote
Old 05-05-2022, 07:18 PM #32
bigdaddy2021 bigdaddy2021 is offline
bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough bigdaddy2021 is a jewel in the rough
Originally Posted by Humble Leader View Post
are you concerned about heat with that set up? there's no free air flow around the cats. wouldn't they overheat with hot air having no where to escape?
Hey Humble Leader, thought about you when we're cruising around Anza-borrego a few weeks ago.
Weather was hovering around 95-100 degrees the weekend we were there. Spent time blasting around the desert doing 40mph, sitting idling taking pics on side trails with the A/C on full-blast, carefully wheeling the badlands in 4LO @ 5mph's or so, etc, etc.
temp sensor/temp gauge never moved and the floorboards never felt any hint of too much heat, etc.
Just wanted to give some desert heat trail testing data.
2019 TRD Offroad | Dobinson's suspension/UCA | Warn bumper | M8000 winch | Victory4x4 Strike bumper |BFG 33’s | 4xInnovations sliders/skids | Frontrunner Slimline 2| Safari snorkel | Rago Fab molle panels/shelf | ICECO fridge slide | AJC cargo Plate.
bigdaddy2021 is offline   Reply With QuoteReply With Quote
Old 05-05-2022, 07:20 PM #33
LOL. awesome.
Old 05-05-2022, 07:44 PM #34
Humble Leader's Avatar
Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold Humble Leader is a splendid one to behold
awesome thanks. I think I'm going to pick up a cat skid. if you had no issues with the heat I certainly won't up here lol
Old 05-22-2022, 04:52 AM #35
AlumniCU's Avatar
AlumniCU AlumniCU is offline
AlumniCU is on a distinguished road
AlumniCU's Avatar
Originally Posted by salsanacho View Post
Let us know how the install goes, it looks like you need to remove the transmission skid to drill some holes and install. I haven't tried, but hopefully there's an easy way to remove the transmission skid without loosening all the bolts on all the other skids.
Works great and easy install. RCI pre-drilled holes in the transmission skid.
2015 Trail Premium w/ KDSS, OME suspension & UCAs, 255/80 17 Falken Wildpeaks, Hefty Banshee w/ Warn winch, RCI sliders & skids, all knockin' around the Rockies (~);}
AlumniCU is offline   Reply With QuoteReply With Quote
Old 05-29-2022, 08:08 PM #36
Originally Posted by RSGT40R View Post
It is a very easy install. We use two allen head bolts as well as two carriage bolts. The carriage bolt going through the rear cross member on the driver side can be tricky to get at but isn't too bad. This skid is a deterrent. Most catalytic converter thieves will look underneath and move on to the next one when they see this. It would take some time and tools for them to really get at the Cats. We are working on uploading instructions here this week so stay tuned!
do you have the instructions for these? I want to see if I can install this without a lift. those carriage bolts look really tricky to do from your back
Old 06-27-2022, 06:47 PM #37
perryi2 perryi2 is offline
perryi2 is on a distinguished road
Rci cat shield
Did you have to ask rci to pre drill the holes for you on the transmission skid or did it already have them pre drilled when you got it?
perryi2 is offline   Reply With QuoteReply With Quote
Old 06-27-2022, 06:48 PM #38
Old 06-27-2022, 09:16 PM #39
mbm112 mbm112 is offline
mbm112 has a spectacular aura about mbm112 has a spectacular aura about mbm112 has a spectacular aura about
I had put in an order for a full set before these came out so they weren’t going to have the holes pre drilled. They did offer to give me a trans skids with the holes if I was willing to wait for the next batch to finish.
2016 Limited 4WD Blizzard Pearl | Black
TRD Pro Sema | Toyo AT3 LT285/70/R17 C
Dobinsons IMS 302/700 and 505/705 | SPC UCAs | Durobumps
Victory4x4 Rack, BajaRack Ladder, Full RCI Skids & Sliders
CaliRaisedLED Ditch Lights & Light Bar
mbm112 is offline   Reply With QuoteReply With Quote
Old 06-28-2022, 04:02 PM #40
sid325's Avatar
sid325 sid325 is offline
sid325 is on a distinguished road
sid325's Avatar
I just installed my RCI’s, still no predrilled holes, but easy to do, took 5 minutes. Overall fit of everything was really good.
17 4Runner TRD Off Road Premium - Silver
sid325 is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 12:10 AM #41
AngryFatPanda's Avatar
AngryFatPanda AngryFatPanda is offline
AngryFatPanda is on a distinguished road
Just installed mine, The cat guards are predrilled square holes but the transmission plate doesn't... You get one shot so measure a bunch of times before drilling. The directions suck by the way very few pics.
AngryFatPanda is offline   Reply With QuoteReply With Quote
Old 08-25-2022, 04:01 PM #42
TRDHULK's Avatar
TRDHULK TRDHULK is offline
TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold TRDHULK is a splendid one to behold
TRDHULK's Avatar
This looks great! I'll be doing this for sure!
Any RCI coupon codes anyone knows of?
2020 Army Green TRD Pro 4Runner | Instagram: @TRDHULK
35" KM3s | Kings | RRW RR6-H -25 Wheels | Cali Raised LED Sliders | + lots more
Visit my LinkTree for discounts at Cali Raised LED, RRW, Rago, Canvasback,
Auxito, Diode Dynamics, Insta360, Ghost Mount, Giraffe Tools, and more
TRDHULK is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 12:40 PM #43
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
NOV22 20% off right now (it is on their landing page), expires in a few days.
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
5th , catalytic , converter , gen , skid
Skid plate that covers the catalytic converter Baughb 3rd gen T4Rs 21 07-04-2023 12:26 AM
Skid Plate protection for something a little different kfs-4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-29-2020 11:37 AM
Catalytic converter LedFloyd900 Classic T4Rs 1 03-06-2015 01:21 PM
Catalytic Converter downtow 4th Gen T4Rs 5 12-10-2012 09:10 PM
skid plate for converter theft Charlee78 3rd gen T4Rs 0 08-26-2008 07:08 AM
