05-24-2021, 10:00 PM
Full Length Low Profile Racks - recommendations?
Hello.
I am interested in getting a low profile full length roof rack for my 2020 T4R. I like both the Gobi and Prinsu models and I will have them installed professionally. I could install myself if drilling holes would not be required.
I want to also be able to attach a cargo box to either one of them.
What is your recommendation?
Thanks in advance.
Farzad
05-24-2021, 10:04 PM
I went with Prinsu, it was easy and I installed it this weekend. It's no drill also so no extra holes.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
05-24-2021, 10:17 PM
I just installed my UpTop Bravo rack. It's very nice and doesn't require any drilling. The fitment and precision is top notch. I highly recommend it.
05-24-2021, 10:23 PM
Thanks. If it is no drill, how does the forward end of it come into contact with the roof?
05-24-2021, 10:29 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
05-24-2021, 10:30 PM
Thanks
05-24-2021, 10:47 PM
Take a look at Greenlane Off-road from Canada, prices shown are not USD so your number is much less. Great fit and finish, there is a good YouTube item on this.
05-24-2021, 11:12 PM
With the Sherpa, the forward end rests on adjustable rubber feet. If you leave the rear mounts a little loose, and the middle mounts a quarter inch loose, you can pull up the front windscreen, set a folded towel under it, and then set the front feet just a little long. Then when you tighten the other mounts it puts extra pressure onto the front feet. Just don't overdo it, which can put a bend into the side frame.
05-24-2021, 11:18 PM
Gotcha - thanks.
05-25-2021, 07:31 AM
Super happy with my Sherpa rack so far. No drill, easy install, very sturdy.
05-25-2021, 08:23 AM
Another vote for Sherpa. Very solid, low profile, and looks great (although they all kinda look the same anymore). I installed it by myself in about 1-2 hours, taking my time not to scratch anything.
05-25-2021, 11:12 AM
2021 Lunar Rock
05-25-2021, 12:09 PM
You cut the weather strip and use #M VHB tape for the legs. There is no noise all the way up to 80-85 mph. If I had to choose again I would pick Prinsu, UpTop, and Sherpa in that order.
The Build
05-25-2021, 01:20 PM
Why the Prinsu over the Sherpa? Sherpa build looks less flimsy and also doesn't require silicone..
05-25-2021, 02:41 PM
Me...Southern Style Offroad full length no drill, 40” lightbar cut out, wider 80/20 cross bars, camp light cut-outs, excellent powder coat and customer service.
