Old 05-25-2021, 11:54 PM #1
Nautical Nautical is offline
Nautical is on a distinguished road
Trailer lights question
Hello all,
2000 miles on my new orp and Iím loving it!
Iím hoping someone here can give some input on my trailer lights issue.
My main question is- is there anything different about the 4pin connector on the 4 runner than on a 2002 Ford e250 ( my previous tow vehicle)?
Some facts-
- I have not used boat in two years but I think all trailer lights worked properly when last used.
- Back right trailer light goes on with headlights, lights up with brakes and turn signal. It does not have the (white??) side light on.
- Back left trailer light does not respond to any headlights, braking or turn signal. The white side light is on.
- The side marker lights in the middle of the trailer both work
- - The back left bulb does not appear to be burned out. These are sealed units, not LED.
Should I buy two new tail light assemblies and wire them up?
Or is there something I donít know with 4 runner trailer hook up.
Any help is appreciated!
Thanks,
Nautical
Nautical is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 12:30 AM #2
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a glorious beacon of light patkelly4370 is a glorious beacon of light patkelly4370 is a glorious beacon of light patkelly4370 is a glorious beacon of light patkelly4370 is a glorious beacon of light
Our 4-pin trailer works the same on all our vehicles. 17 4runner, 07 Dodge Ram, 04 Jeep WJ, and 68 F100.
7-pin plug (horse trailer) works the same on all too (except the 68, no 7-pin plug)
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 10:31 AM #3
fkheath fkheath is offline
fkheath is a jewel in the rough fkheath is a jewel in the rough fkheath is a jewel in the rough
Originally Posted by Nautical View Post
Hello all,
Some facts-
Thanks,
Nautical
The 4Runner trailer light connectors corresponds to the industry standard. With the weird things going on with your trailer, it may be mis-wired. Check your ground connections as a start; sometimes a poor ground at one of the lights can cause weird problems like yours.
fkheath is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 02:30 PM #4
Saker's Avatar
Saker Saker is offline
Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold
Saker's Avatar
Put 12 volts to each of the 3 connections on the trailer.
That can be done by connecting a wire from a battery.
Connect from the battery ground to the ground connection on the trailer.
There are diagrams on the net that displays what connections send power to the specific lights.
As stated, check your ground connection..
I would do that first.
You could start there.
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 05-26-2021, 02:51 PM #5
s13koop's Avatar
s13koop s13koop is offline
s13koop will become famous soon enough
s13koop's Avatar
Best thing to do in these situations is to use a test light.
See if you got power at the pins/plug and if so then check at the light plug for power.
Green - right turn & brake
Yellow - left turn & brake
Brown - Tail/sidemarker light
White - Ground
Also, wiring will be same as previous vehicle
Source: I drive fords
00-JZX100
10-Trail Ed.
s13koop is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 07:08 PM #6
Thank you all for the good info and advice!
I had started to do some volt meter testing but ran out of time.
Iíll check for voltage and good grounds this weekend.
Just wanted to know if there was something different about the 4 runner than standard.
Thanks again!
back , light , lights , side , trailer
Trailer running lights/fuse question mc813 5th gen T4Rs 12 11-08-2020 02:56 PM
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
'97 trailer lights Stickit1997 Maintenance/Detailing 2 07-28-2011 09:52 AM
Question about hooking up trailer lights Jeffkin 3rd gen T4Rs 10 05-05-2010 09:35 PM
Trailer Lights Question Dirt4dinner 3rd gen T4Rs 2 05-09-2008 01:35 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
