Originally Posted by Nautical
Hello all,
2000 miles on my new orp and I知 loving it!
I知 hoping someone here can give some input on my trailer lights issue.
My main question is- is there anything different about the 4pin connector on the 4 runner than on a 2002 Ford e250 ( my previous tow vehicle)?
Some facts-
- I have not used boat in two years but I think all trailer lights worked properly when last used.
- Back right trailer light goes on with headlights, lights up with brakes and turn signal. It does not have the (white??) side light on.
- Back left trailer light does not respond to any headlights, braking or turn signal. The white side light is on.
- The side marker lights in the middle of the trailer both work
- - The back left bulb does not appear to be burned out. These are sealed units, not LED.
Should I buy two new tail light assemblies and wire them up?
Or is there something I don稚 know with 4 runner trailer hook up.
Any help is appreciated!
Thanks,
Nautical
The 4Runner trailer light connectors corresponds to the industry standard. With the weird things going on with your trailer, it may be mis-wired. Check your ground connections as a start; sometimes a poor ground at one of the lights can cause weird problems like yours.
