Old 05-26-2021, 03:19 PM #1
Rpede Rpede is offline
Rpede is on a distinguished road
Question Magnefine ATF filter install on 5th Gen 4Runner
I’ve been unsuccessful in finding a video or picture how-to on installing a Magnefine inline ATF filter on a 5th Gen 4Runner. Does anyone know of a source I have yet to find? May seem like overkill on a reliable transmission but I’ve had tremendous luck with this brand of transmission filter and like the paper media+magnet filtration these provide. Really all the stock 5th gens have are 4 magnets in the pan and a simple screen in the trans pan, so I am wanting something more substantial. I had a Honda Odyssey with one of the least reliable transmissions (2003) and got the original trans to go 400k with combo of the Magnefine and using Amsoil Signature Series ATF fluid (despite being told van would self destruct if I didn’t use Honda OEM trans fluid).
I have no clue where I would add the Magnefine filter except I am told it should be (transmission fluid flow) after the radiator and heading towards the transmission. Would appreciate it if anyone who has a diy how-to or knows of a video to please share with me. Much appreciated.
Rpede is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 09:55 PM #2
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
I think you are trying to solve a problem that doesnt need to be solved. At the same time you are introducing something that could actually reduce the reliability of your transmission. I just pulled my AT filter out and changed my fluid for the first time after 145,000 miles and it was doing its job just fine
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 05-26-2021, 11:19 PM #3
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
do your first ATF change when your powertrain warranty expires and then every 50k after that.. learn to do it yourself and save lots of monies...
1jzgte is offline   Reply With QuoteReply With Quote
Old 05-28-2021, 01:04 AM #4
The more and more I think about what you say, I think you are completely correct. Appreciate your candor, I have a tendency sometimes to sometimes go overboard based on prior makes of vehicles I’ve owned. This is my first Toyota so I’m adjusting to the incredible lifespan and reliability of this vehicle. Thanks again.
Old 05-28-2021, 09:48 AM #5
Chubbypanda Chubbypanda is offline
Chubbypanda will become famous soon enough
I think most of us who own toyotas think like you to keep our vehicles as long as possible to reach that magic 1 million mile on our odometer.
Chubbypanda is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 06:38 PM #6
4Runner4Life_2023's Avatar
4Runner4Life_2023 4Runner4Life_2023 is offline
4Runner4Life_2023 is on a distinguished road
Derale inline filter
Hello, this is my first post in this forum. Been driving Toyotas all my life but joined this awesome forum because 4Runners are special. My first 4Runner and plan to keep her as long as possible.
2023 X-series with 5 miles on the Odo when I drove it off the lot and installed a Derale inline transmission filter as soon as I got it in the driveway. After 700+ miles I replaced the inline filter along with first oil change. Anyone interested in seeing the amount of metal bits after only 700 miles?
You can see there are about 2grams of metal that settled in the bottom of the pan and all the shiny white specks are bits of aluminum. Cut open the filter it's pretty clean because when I lifted the filter media the metal bits were rolling off it along with the fluid.
Magnefine ATF filter install on 5th Gen 4Runner-tran-fluid-jpg  Magnefine ATF filter install on 5th Gen 4Runner-tran-filter-jpg
4Runner4Life_2023 is offline   Reply With QuoteReply With Quote
Old 11-18-2022, 10:36 PM #7
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
The caveat here is that while that may only be "700 miles", it is literally the first 700 mikes. The first couple thousand miles of any bearing + gear set (transmission, diff, transfer case, etc.) generates the most amount of wear metal. Mostly this wear metal is actually components "breaking in" to best fit each other. So, i expect after the break-in material you will no longer see metal.
Some things to consider beyond simply "adding filtration = good".
By-pass valve for the filter to compensate for filter clogging and maintain needed flow.
Backpressure/flow reduction caused by additional filter.
Messing with the flow rate of the transmission fluid could cause more damage than some metal specs that will be captured by the magnets.
Bmnorm2 is offline   Reply With QuoteReply With Quote
Old 11-19-2022, 07:18 AM #8
@Bmnorm2
Thanks for the pointer. Yes, I designed the hose path for minimum restriction possible using wide 90 degree bend into the adapter and straight shot back to the original path. I used original Toyota A5 filter for the adapter (my old Tacoma's) and test the flow. The reason for changing the filter so early is to capture all the bits from break-in and reduce the flow restriction. I also added a 1"x.5" neodymium magnet to the bottom of the filter to capture ferrous metal in the future. Pump back the same amount of fluid that's used during the install and test process. Now I only have to do tranny flush at 50k instead of 30k.
I'm shooting for the 2 mil mile club.
filter , fluid , magnefine , trans , transmission
3rd gen transmission filter and Magnefine filter - $40 +ship shiftmx For Sale: T4R Items 0 05-09-2021 03:39 PM
Mounting Magnefine filter? T4R2014 3rd gen T4Rs 6 02-26-2016 01:06 PM
Need advice on mounting Magnefine 3/8 Inline Filter thor999 3rd gen T4Rs 3 03-05-2015 01:39 PM
Magnefine ATF filter removal.... LittleCaesar 3rd gen T4Rs 4 03-10-2013 02:17 AM
Magnefine inline filters... calikev 4th Gen T4Rs 2 08-08-2012 04:05 PM
