Old 05-29-2021, 12:40 PM #1
spyder918 spyder918 is offline
spyder918 is on a distinguished road
Reverse Light Mod?
Has anyone been able to successfully mod their reverse light to turn on via switch in the cabin?
spyder918 is offline   Reply With QuoteReply With Quote
Old 05-29-2021, 02:37 PM #2
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Why would you want to do that?
Old 05-29-2021, 05:17 PM #3
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Why do that?
I would run a separate circuit for a set of AUX rear lights.
You may want to think this out.
Best Regards,
Saker
Old 05-29-2021, 05:53 PM #4
Ripper238's Avatar
Ripper238's Avatar
In my teens i did it on my old 79 Buick just for fun.
30 years later i got a set of Baja S1's at 2500 lumens that i wired properly with a switch and relay.
Fantastic for backing down trails and setting up camp.
Old 05-29-2021, 11:57 PM #5
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I agree with others, what’s the point ? The reverse lights aren’t that bright. I would rather manually trigger a pair of 6” spot lights with a switch. Better yet, trigger the 6” spot lights in reverse.
But if you really want to create an anytime reverse light switch .. just tap the reverse light circuit. It’s on the drivers side footwell.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 12:59 PM #6
sac602's Avatar
sac602 sac602 is offline
sac602 is on a distinguished road
sac602's Avatar
I just did something similar when I installed a victory 4x4 rear bumper which has 2x 3" led lights in it.
I tapped into reverse light on passenger side (from cargo area) using t-tap connector, relay and aob switch.
Standard relay connections:
85 to aob switch
86 ground
30 positive wire to led lights
87 accessory-on power (run with add a fuse to fuse block down passenger kick panels)
87a wire from reverse light
lights come on when put in reverse like normal, And, come on or when the switch is used in dash.
Check this out at Amazon
LED Light Push Button Switch with Connector Wire Blue Backlit Kit Compatible with Toyota Tundra Tacoma 4Runner-Rear Light Symbol Amazon.com: LED Light Push Button Switch with Connector Wire Blue Backlit Kit Compatible with Toyota Tundra Tacoma 4Runner-Rear Light Symbol: Automotive
Amazon.com: ONLINE LED STORE 6 Pack Bosch Style 5-Pin 12V Relay Kit [Interlocking Harness Socket Holder] [14 AWG Hot Wires] [SPDT] [30/40 Amp] 12 Volt Automotive Relays for Auto Fan Cars: Automotive
Qibaok 240 PCS T-Tap Wire Connectors Self-Stripping Quick Splice Electrical Terminals and Nylon Insulated Male Quick Disconnect Spade Terminals Kit: Amazon.com: Industrial & Scientific
Amazon.com: Uriveusa 12V Car Add-A-Circuit Fuse TAP Adapter Fuse Holder with 10A, 20A Fuse [Upgraded Fuses] - (2 Pack) (Mini Fuse): Automotive
2014 LE-Attitude Black with front end conversion. Warn 100022 bumper/ smittybilt x20 winch. Toytec Ultimate lift / Camburg UCAs. Fn Fx(pro) rims (www.importequipment.com center cap decals), 285/70 r17 Ko2. ZenonDepot H11 HID Kit | Xtreme HID
[Philips Bulb 4300K] / Morimoto XB Led fogs, DiyBriGuy.com Front/rear camera override. Removed 3rd row seats for fridge / drawers. Odyssey Batterie 34R-PC1500T - needs Odyssey Group 34 Battery Spacer. C4 Ladder, Prinsu rack
sac602 is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 01:02 PM #7
sac602's Avatar
sac602's Avatar
85 to aob switch
86 ground
Old 05-31-2021, 01:16 AM #8
Very cool. Thanks for all the tips and replies! Yeah I'm just looking for a quick/dirty way to get some lights in the rear for when we go camping and stuff. I don't have any 3rd party roof racks to wire a whole Rear Light set and so I thought tapping into the existing reverse lights would be easier.
Also I thought it would be something cool to flash the idiot speed racer tailgaters..lol.
Old 05-31-2021, 11:03 AM #9
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
The diode dynamics kit turn to reverse kit works really well. I have done this and it great.....but I get what you mean by flashing tailgaters....I have a set of floods mounted on the rear of my rack, and it works great for tailgaters.
2014-2021 Toyota 4Runner Tail as Turn™ Module +Backup Module (USDM)
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 05-31-2021, 03:19 PM #10
sac602's Avatar
sac602's Avatar
85 to aob switch
86 ground
I tried to send a PM to a member with a question, but I dont think I did it right, so here is the diagram...
Old 05-31-2021, 03:24 PM #11
sac602's Avatar
sac602's Avatar
attached wiring diagram...
Reverse Light Mod?-wiring-jpg
Old 05-31-2021, 06:06 PM #12
????? ????? is offline
????? will become famous soon enough
I have this setup soon to be installed for a little extra rearward lighting
Just waiting on some DT connectors to quickly remove for towing.
HitchPod Combos - Hotshot Offroad
????? is offline   Reply With QuoteReply With Quote
Old 05-31-2021, 06:19 PM #13
Looks okay. But most folks use 86 as gnd and 85 no from the switch.
Old 05-31-2021, 09:23 PM #14
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
It shouldn’t make any difference. They’re just the coil pins. But it’s a good idea to be consistent with your schematics.
https://m.delcity.net/images/linedra...%20Diagram.pdf
light , mod , reverse , successfully , switch
Rigid Industries Back Up Light Kits / Reverse Light TotalAutomotiveLV Total Automotive Performance 1 02-11-2016 07:22 PM
Reverse light MOD 2007toyota4runners 4th Gen T4Rs 9 07-27-2012 08:56 PM
driver side only reverse light and tag light out wiladc100 Classic T4Rs 3 11-21-2009 04:28 AM
