05-30-2021, 09:53 AM
Advice rear locker won’t disengage
Before I rip into this thing, was lubing 4H and 4L with locker. Usually not a problem. Goes in and out easily. Straight away, but on pavement so no wheel slip. I know it's not good practice etc. I've tried backing it out both in the street and on the lawn. Can't get to dirt. It's dragging the rear tires in slow s turns. Front comes in and out of 4H and 4L but rear stays locked. I hear the actuator and it does sound like the gear is moving not straining. The dash light blinks and never goes solid. I pulled the 2 wire connector and the dash light continues to blink and the actuator still sounds the same. Pulled the 5 wire connector and no power to the actuator and the dash light blinks rapidly with the crawl light as well. Connections and wires are in great shape. Plug everything back in and the same happens. With the rear tires off the ground I can rotate them and they go in the same direction, in N and 2wd. I tried driving it about 75/100 yards in 2wd to disengage the locker. Suggestions before I pull the actuator and manually disengage the locker, I hope. I assume if I take that step I can put the actuator back on provided it/O-rings look okay so that I can drive it. I know I should have it in neutral/4Lo and aligned for disengaged to set the timing with the fork. Other suggestions or things I missed. First time with this issue on any gen and have only found info for mostly 3rd gens on the forum. Thanks in advance.
1995 sr5 sold
1998 sr5 gone but may have saved a life
2004 SE sold
2010 TE Dobinsons lift, spc ucas, 35x11.5 Maxxis Razr, XD Storm Sand, rci skids,spod,buncha mods, c4 lo pro smittybilt winch, early 5th hi clearance cut,Lights, pedal commander,Rago panels, spidertrax, shrockworks sliders
05-30-2021, 12:12 PM
Not well educated on the elocker system. can you hear the motor when you try to engage/disengage? If not, maybe check your fuses, if there is one. Like I said, I'm not well versed here but a fuse would be my first check followed by wiring to the motor and tapping the motor like a stuck starter, if there is a motor. Try the link below for info.
Toyota 4Runner Service Manual
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
05-30-2021, 12:28 PM
Jivewalker,
Thanks. From what I've read there is not a e locker fuse alone, it's tied into the 4 wheel fuse and my 4H and 4L are working. I can clearly hear the actuator motor working, not sure if it's bound up inside, but it clearly sounds to go through it's job of engage and disengage. A thought is that the light continues to blink as if not engaged, even though it appears to be engaged, so that might be an issue, but I believe that is just a separate sensor(the 2 wire connection on the motor) that tells the ecu it's engaged or not. Again may be my issue, but the actuator runs and the light turns off when I push the button for it to disengage. I'm going to pull the actuator and manually disengage it for now...cross my fingers it's that easy. Then I'll tackle the bigger issue. It'll be good practice. On a side note, we are heading down to vaca in Seabrook Is. late June for 12ish days and I have been researching places to wheel in your neck of the woods. Any suggestions? I haven't found much that isn't hours inland. Thanks for your input, I'll keep plugging away.
1995 sr5 sold
2004 SE sold
05-30-2021, 04:07 PM
Not much wheeling around here. Most of the times I'm off road is up in NC in the mountains trout fishing. I heard that there are some fun trails around the area in the link below from some locals, but I never go out that way just to go off road. have fun in Seabrook! BTW, I fish out in that area often, theres some good saltwater creeks and some good surf fishing there!
Google Maps
I am fragile.
Not like a flower.
But like a bomb.
05-30-2021, 06:56 PM
Great, thanks. Tough here in Maine as well, all privately owned unless you go north. I’ll take a peek at the map. FYI, I pulled the actuator, cycled the locker manually and was able to realign/clock it. Worked like a charm with wheels off the ground and I was able to cycle it in the driveway under power! I hope it pulls through when I need it, but I now know what the job entails, very simple. Also learned how low the actuator breather is, will move that up with the diff breather soon. Always a win win with these rigs. Not much of a fisher though I’ve been very tempted to learn to fly. We’re a Beans family, should take advantage! Thanks again, be well and have a successful trout season.
1995 sr5 sold
2004 SE sold
05-31-2021, 12:09 AM
Glad you got it worked out. Can you walk us through the process for future reference?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
05-31-2021, 09:59 AM
Yep, I’ll take a few pics and type up what I did. Took a few during the fix.
1995 sr5 sold
2004 SE sold
05-31-2021, 03:52 PM
Here is a link that was helpful.
The end of DIY car maintenance and how I replaced the e-locker motor on my 2010 4Runner - Daniel D. McKinnonDaniel D. McKinnon
From the manual:
Toyota 4Runner: Reassembly - Rear Differential Carrier Assembly(w/ Differential Lock) - Service Manual
Tools needed:
12mm socket/wrench
14mm socket/wrench
Larger flat head/pry bar
Small flat head
jack
jack stands
PB blaster
pliers
Step 1: Unlike many other components on my truck this was not overly impacted by salt/elements. Use PB Blaster or equivalent to the 3 bolts/nuts, see photo. I did not need to remove the plastic cap. This seems like a tight spot but there is plenty of room to work below and from above. I do not have the spare, so there is more head room, really only need to acces s the 2 plugs and breather from above. I have the rci gas tank skid and still had more than enough room to wrench, remove the motor and access the locker fork port.
Step 2: Set your rear wheels off the ground and secure safely with jack stands etc. You will need to be able to move the wheels to help align. I moved it in and out of 4H and 4L and 2H. Obviously kept it in Neutral with engine on, but just moving the key to on position was fine to manipulate the actuator.
Step 3: Unplug the top 2 wire connection~lock confirmation sensor, 5 wire power/sensor, and the actuator breather tube, just pull it out where I marked in red circle. Do note where the breather is, pretty low if you consider a Diff breather mod. I will be moving this up to match my diff breather.
Step 4: Unscrew the 3 nuts/bolts. The 2 marked blue are guide pins threaded on both ends. If the nuts donÂ’t budge and it turns it's the inner thread giving. My top guide came out, and my bottom nut gave and the guide stayed in. **If your bottom guide threads off from inboard, the hole is open to the Diff fluid and it will leak out. These are both 14 mm. The 3rd is a bolt and 12 mm marked in green. You can then pry the actuator away, there are points that are obvious that give good pry points with a flathead. If itÂ’s corroded it may take a little muscle and then gently work it loose as there is a small o-ring you are going to not want to ruin if you can help it. I then moved the actuator up and over the casing and drive shaft and out for a cleaning and inspection. I cleaned up the face of the actuator and the diff casing as best I could without putting too much debris near the port and on the pinion. I used diff oil to clean and relube the pinion and o-ring before replacing and used a little on the port seat as well.
Step 5: I manually moved the fork to fully engage, as my first attempt to replace the actuator in the fully open position did not align with the pinion and it wouldnÂ’t unlock it after it locked and the sensor couldnÂ’t read it so the light blinked even though it was locked again. I repeated the disassembly and cycled the actuator to lock (11 OÂ’Clock position when placed in the port) by hooking up the 5 pin while it was in 4L and the actuator was hanging outside of the port. I then moved the fork to full lock, see pic (only took one in open and even then you canÂ’t see the fork) and manual. I then gently replaced the actuator to align the teeth. Make sure you tighten the bolts/nuts in a triangle pattern. It takes some wiggling and patience, but it should press in using the bolts. Remember you have an o-ring on there. There also looked to be a dab of threadlock on the bolt mount face and I also added a dab just to be safe. Torque is 20 ft lbs. on the bolts. Reattach the 2 plugs and the breather tube (just push it back in). Reattach the plug zip to itÂ’s bracket or zip tie if you cut the factory zip.
Step 6: cycle through lock and unlock with wheels off the ground by hand, then test under full power, you have to move the wheels for it to engage after you press the button. Mine went back to normal and immediate working condition. Hope it stays that way. Keep an eye for any leaks. Should be good to go and if you ever have it lock and wontÂ’ disengage on trail, you now know how to manipulate it manually and get home safe. One last note, there is a lot of info on this for 3rd gens, their actuator looks to be on the back of the diff compared to the 5th gen being on the front driverÂ’s side. Also, the link for DDMckinnon shows him purchasing a new actuator, Thankfully I didnÂ’t have to do that, but I noticed there are a number of models out there that are very similar. DD mentions that he had to mod his to fit, make sure you get the correct part as I think itÂ’s a difficult part to source and get the correct part #. It doesnÂ’t look to show up on the parts diagrams online. Not a dig on DD at all, just something to be aware of and his observation and experience may be accurate regarding the part.
https://www.toyota-4runner.org/attac...1&d=1622571365
https://www.toyota-4runner.org/attachment.php
attachmentid=382723&stc=1&d=1622571365
1995 sr5 sold
2004 SE sold
05-31-2021, 06:05 PM
Thanks Saker, pics reloaded.
1995 sr5 sold
2004 SE sold
06-01-2021, 02:26 PM
Pics are sooo frustrating...tried all formats...it says I keep timing out and to check cookies. I used the FAQ section on images and attachments. Just can’t get the images to stay. I added the write up with pics to my albums. Better than nothing. Sorry.
1995 sr5 sold
2004 SE sold
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
