Old 05-30-2021, 01:53 PM #1
aweaver65 aweaver65 is offline
aweaver65 will become famous soon enough
Front Sway Bar Rubbing after ICON Install - Questions
Well, after a month of driving around, I finally figured out where the "Pirate Ship Creaking" sound is coming from... My front sway bar is rubbing on the bracket that goes from the radiator support back *See Pic
I had the ICON Suspension installed at 4Wheel Parts here in Tulsa and took it back after a few days because of the creaking sound. They kept it for an hour and told me "Just keep driving it, it will probably go away and if it doesn't bring it back"...
I figured something was rubbing where it shouldn't be or otherwise binding up, IT'S LOUD and you can feel it in the steering wheel. I know this is where the noise is coming from because a quick squirt of lube made it stop instantly.
So my questions are:
1. Have any of you had this issue?
2. Should the sway bar be in this position; i.e. is this an indication of something being out of alignment, or maybe a missing part that wasn't installed which would have corrected this?
As for 4Wheel Parts mechanics, I'm now convinced that whichever guy they had do the install doesn't take pride in his work, at all.
They did a Body Mount Chop, and while I was under there today lubing stuff to trace the squeak, I noticed the inside of the mount isn't fully painted and is already getting surface rust.
The brand new Billet UCA's have greasy hand finger prints on them and there is a small gouge in one of my front fender flares. So, would I recommend using them to install anything? Nope.
Anyway, If any of you have any feedback on this sway bar issue, I would appreciate it.
Thanks!
Front Sway Bar Rubbing after ICON Install - Questions-sway-rub-small-jpg
2020 Army Green TRD Pro, RSG Flat Sliders. SV.4 LED's from Headlight Revolution, RAM Mount for Cell Phone (got my cup holder back!), Deleted Roof Rack (sold). Canvas Back full Cargo Liner (for my Dog "Donkey")...
Icon Stage 2, Body Mount Chop, Method MR305's and BFG KO2 285/75/17's (34 Inch Tires) (No rubbing at all), East Coast Gear 4.56 Diffs Front/Rear
aweaver65 is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 03:08 PM #2
Pho thit cho Pho thit cho is offline
Pho thit cho is on a distinguished road
My front sway bar looks similar to yours post lift. But I can't remeber if it was like that pre lift. I only get creaking when im reversing at full lock or going over speed bumps. (Only squeaks over speed bumps randomly) ive yet to determine where the squeeks are coming from. Annoying considering my suspension set up was about 3k +
Doesnt squeek that bad to the point I want to take it back to installer 🤷*♂️
Pho thit cho is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 08:35 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Does the icon lift have any parts which effect the angle or location of the sway bar ?
I know kings has a 1/2” bracket which the sway bar attaches to. This bracket is used to hold the strut reservoir. This will make the sway bar get closer to the radiator support and in some cases even hit the them.
But kings provides radiator support spacers to resolve this issue.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 09:26 PM #4
kpinthebay's Avatar
kpinthebay kpinthebay is offline
kpinthebay is on a distinguished road
kpinthebay's Avatar
There's supposed to be spacers/washers that drop the skidplate brackets so the sway clears.
Sent from my Pixel 3 XL using Tapatalk
2018 Tacoma OR 4WD Cement > Icon Stage 2; 285/75/16 BFG KO2; Volk TE37
kpinthebay is offline   Reply With QuoteReply With Quote
Old 05-30-2021, 10:53 PM #5
scratchhax scratchhax is offline
scratchhax has a spectacular aura about scratchhax has a spectacular aura about scratchhax has a spectacular aura about
looks like the swaybar relocate isn't installed. If you bought the kit, it's supposed to come with a bracket that moves the swaybar out of the way. It's optional if you have KDSS, but if you don't, you need it.
19 offroad premium, icon stage 3 with overland springs, warn semihide front bumper, victory 4x4 rear bumper, victory skids front to back, warn 10s evo, sso sliders and roof rack, magnaflow exhaust, procharger d1-sc, nitro 4.56 gears and a whole mess of little bits and bobs.
scratchhax is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 12:30 AM #6
SirWilliamGoes SirWilliamGoes is offline
Real Name: William Adams
SirWilliamGoes has a spectacular aura about SirWilliamGoes has a spectacular aura about
Not sure what’s causing the rubbing but I can tell you that you wont miss the front sway if you take it off particularly if you have upgraded suspension.
SirWilliamGoes is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 01:23 AM #7
Thank you. They actually did install them. I noticed them while I was under there chasing this down and realized they were new because they were spotless. That said, the ICON Description of these brackets states:
"Overview:
These black anodized, billet aluminum sway bar relocation blocks will move your sway bar 1" forward to avoid any contact with aftermarket coilovers. This small investment can save yourself a ton of headache when installing aftermarket coilovers."
I think that is the root of the problem right there. The Sway Bar is moved forward to allow for clearance of the coils, but now it's pushed into the Skid Plate Bracket.
In any case, I fixed it today by dropping the bracket that rubbed about 3/16" of an inch with some fender washers and now it is fine. While I had the skid plate off, I got a tap and chased the threads, got some good anti-sieze cleaned and painted everything that needed it (few rusty welds, etc.) and that did it.
Here are a few pics, in a couple, you can see the spot that rubbed and wore through the finish on the Sway Bar and also the Bracket. It seems like ICON needs to supply spacers to drop that driver's side bracket along with the Sway Bar Relocation kit. :
Front Sway Bar Rubbing after ICON Install - Questions-clearance-jpg  Front Sway Bar Rubbing after ICON Install - Questions-fender-washers-back-close-up-small-jpg  Front Sway Bar Rubbing after ICON Install - Questions-fender-washers-front-jpg  Front Sway Bar Rubbing after ICON Install - Questions-sway-rub-bracket-jpg  Front Sway Bar Rubbing after ICON Install - Questions-sway-bar-rub-jpg
Old 06-01-2021, 02:05 AM #8
Vinyl303 Vinyl303 is offline
Real Name: Jeff N.
Vinyl303 is on a distinguished road
Real Name: Jeff N.
Do you have pictures of the support spacers? I would like to buy king coilovers for my 4th gen and would be interested in seeing what the brackets look like for the 5th gens.
2004 Limited 4WD | FJ Coil Swap | Bilstein 5100 | 265/70/17 Cooper all-terrains | Chinese Bull Bar | APF Trail lights
Vinyl303 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 10:35 AM #9
Interesting. I have a 19 without KDSS and a stage 3 tubular and didn't run into this issue. I wonder if there is a small difference between the 19 and 20?
Old 06-01-2021, 12:40 PM #10
rayofsi's Avatar
rayofsi rayofsi is offline
rayofsi is a jewel in the rough rayofsi is a jewel in the rough rayofsi is a jewel in the rough
rayofsi's Avatar
Arb sway bar rub fix!!! Bp-51 fit kit
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
rayofsi is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 02:05 PM #11
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
I have a 19 with the same rub issue, though I have Kings.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 07:29 PM #12
zonzin's Avatar
zonzin zonzin is offline
zonzin has a spectacular aura about zonzin has a spectacular aura about
zonzin's Avatar
Installing Ride Tech sway bar bushing and Icon relocation block did the trick for me. Here's a thread for pics and writeup
Review, Ride Tech Delrin Bushings and Dirt King LCA's
Here's the block
Amazon.com: Icon Billet Aluminum Sway Bar Relocation Blocks Kit 611030: Automotive
zonzin is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 01:53 AM #13
perf0rmance perf0rmance is offline
perf0rmance will become famous soon enough
Originally Posted by rayofsi View Post
Best solution.
Works with my Kings - I no longer use spacers to lower my skid plate too.
perf0rmance is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 11:21 AM #14
Does that kit really come with the modified Driver's side Bracket?
Originally Posted by perf0rmance View Post
Best solution.
I've tried looking that kit up and looking at the exploded parts diagram to see what it comes with, but I see that bracket in some cases but not others...
If it really comes with that bracket for $75, that's a steal! Can you let us know when/where you got the kit?
Old 06-03-2021, 12:00 PM #15
rayofsi's Avatar
rayofsi's Avatar
kit is $115, but comes with the bracket. Can't even make your own bracket like that for $115.
back , bar , front , install , sway
Icon stage 2 with Icon wheels rubbing aaronRR 5th gen T4Rs 15 01-09-2020 06:20 PM
Trouble Shooting/advice - Icon coil overs / sway bar still rubbing Howard35 5th gen T4Rs 9 09-18-2017 12:01 PM
Icon 2.5 ext CO's & UCA install questions T4R3prospect 3rd gen T4Rs 9 05-01-2016 11:48 PM
Icon 58400 Uniball UCA Install Questions JWaldz 3rd gen T4Rs 11 12-30-2013 08:10 PM
