06-04-2021, 10:59 PM
#16
Originally Posted by MAST4R
I don't understand this post.
The 6112 cannot be re-valved.
They don't come with 700lb springs option.
Or is that about going from 6112 to Elka on 700?
Maybe he's talking about a Fox DSC with a 700lb spring?
06-05-2021, 03:09 AM
#17
Originally Posted by honda250xtitan
i think i'm the opposite. i'll take under sprung but over valved. maybe thats wrong though?
I swapped rear springs to toytec HD's and cranked the kings to the stiffest stetting. once all loaded up for our week long trip it was plush offroad. bottoming out was done with hydraulic bump stops as well. zero bucking. those toytec HD's have some bad feedback but with a quality shock controlling it and enough weight to soften it, they were perfect. So, similar to your "ideal setup" Which Accutune can do for you. Valve the shocks according to weight. i'm sure if given spring specs they'll also adjust. The best thing is to take it to the desert with someone who can re valve on the spot and dial it all in. BUT these are daily driven minivans for the most part, kinda overkill IMO.
As you mentioned, undersprung but overvalved is the ideal setup. However, most people don't end up with that ideal setup because we all go out like dumbasses and buy the suspension first, and then add weight and it becomes undersprung and undervalved (is that a word). I managed to even blow a front shock and eventually got my whole suspension overhauled and rebuilt, so I speak from experience..lol.
So for most people who do things assbackwards like i did, and buy a suspension setup before knowing what their final weight is....i'd go oversprung every time, since we tend to add weight overtime..not lose it...(like my ever growing waistline). Also, i found that a quick fix to the firmness while offroading is lower the tire pressure a little bit more..or drive faster...or add more weight. There are no quick fixes to a vehicle that is under sprung and undervalved...it just feels and drives broken when off the pavement.
FYI...obviously, not talking about the ideal setup..more emphasizing what mistakes most people just getting into offroading make when choosing suspension, and the compromise they need to make if they have no idea what their final weight is going to be.
06-05-2021, 03:27 AM
#18
I'd like to know from personal experience but I have better uses for money than paying for constant car mods.
Clearly, racers go for valving with softest possible spring. On the opposite extreme, endurance uses like military seem to prioritize, well, longevity, and so stiff springs that can essentially make poorly working shocks irrelevant.
In normal use, both would allow going as fast as reasonable in a non-race vehicle (so long as the shocks are powerful enough to control the springs) so I guess it is ultimately a matter of preference for us.
Mine has logged 209 runs of 154 trails in 3 years, so not really used as a minivan Over the last 18 months, I have commuted to work, all the 12 RT miles, like maybe once every ten days. I don't commute daily anyway. I use our Subaru for grocery getting and the like. So even my Phoenix area driving is chiefly made of attempts to get out, LOL.
Same here..i dont want to constantly upgrade my upgrades or accessorize my accessories. When i make changes to my vehicle, its all about compromises that I can live with, or what i have future plans i have for the vehicle. After I had my suspension rebuilt...i don't want to do that again in the near future...its god damn expensive lol.
06-06-2021, 01:15 PM
#19
I changed the springs on the 6112s to 700lb. This time around, I'm going Fox DSC with 700lb springs
06-06-2021, 01:17 PM
#20
Originally Posted by nimby
Why did you go with 700lb springs in the first place?
Don't most 6112 owners with a stock weight vehicle go with a 600lb spring?
Did you see the part about my weight? Extra weight is why I switched to 700lb springs back in 17...
06-06-2021, 01:18 PM
#21
So what springs did you use to do that? Bilstein/Eibach does 550 (which vendors call 600) and 650.
I have never bottomed out on 650 springs with the 6112. I don't have front bumper though.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
06-06-2021, 01:28 PM
#22
King 700lb (I believe 14in). Eibach makes them also, but when I bought them, Kings had a discount that made them cheaper than eibach. Eibach makes most, if not all springs for US....so I been told.
KING 14" COIL SPRING PAIRS FOR 2.5" COILOVERS
Reason: Add link
06-06-2021, 01:29 PM
#23
No.
The way it reads to me is that you didn't have any additional weight.
06-06-2021, 02:31 PM
#24
No.
Just under 5800lbs unloaded....no one in it, no RTT, dogs, gear. Its probably at least 500-700lbs heavier than stock before adding the above for trips.
06-06-2021, 05:43 PM
#25
Gotcha, thanks.
06-06-2021, 06:29 PM
#26
Yup, that's real difference. Thanks for clarifying.
06-06-2021, 11:14 PM
#27
you should swap rear springs for trips if youre adding that much weight. It's a bit of extra work but it pays off. We did a trip and one other vehicle was a 4runner, he did not swap rear springs, it held him up on the faster sections, he was riding the bump stops.
06-06-2021, 11:46 PM
#28
Yikes. Yes, it is not hard at all to change springs in the rear.
06-11-2021, 09:45 AM
#29
Originally Posted by mrblah
My experience has taught me that I rather be oversprung than undersprung in almost every driving environment, but it is at the expense of on-road comfort.
So the compromise is performance vs comfort, unless you find that perfect happy middle ground.
To come back to this, my front is precisely that: oversprung. In result it goes over everything and does not bottom out, but because it is oversprung the suspension absorbs less than it should.
It does the job at a fraction of the cost of a high-end front suspension, but a 600lb spring would probably be better (the standard is not 600 as sometimes advertised by vendors, but 550 or less).
06-12-2021, 01:43 AM
#30
WAIT A MINUTE:
I ended up noticing that all over the Elka site their so-called 2.5 shock is said to have a 56 mm BODY. A 2.5 shock is supposed to have a 60 mm PISTON.
Bilstein and King have 60mm pistons
Fox has 58 mm piston
Elka is 56 mm body the SAME as Dobinsons MRA which is never advertised as 2.5. The Dobs has a 50 mm piston, OME BP 51 has, cough, 51 mm piston and so the Elka maybe 50-52 mm piston definitely not 58-60.
I also don't see anything special in their description: smaller shocks on heavier springs. No surprise. Until you notice the price. Now, that's something.
I get it that they are made of aluminum but the Elka shocks just on numbers alone have no place in one line with King, Fox, Bilstein.
