Old 05-31-2021, 04:56 PM #1
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Bent oil pan skid. Should I worry about structural damage?
Untitled | anthony zanegin | Flickr
So I bent my oil pan skid and from the front you can see the passenger side is pushed up. The hit was right on the corner bend. Keep in mind this is an aluminum skid so I expected it to bend more.
Question is this - should I worry about the x-member it bolts to getting bent? It was a good hit but not the worst I’ve had wheeling. Then again that engine cross member is likely beefy enough for such a hit.
Measuring LCA to ground I don’t see anything off, really.
Thoughts?
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 05-31-2021, 05:48 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
unbolt it and inspect it.
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 12:26 AM #3
SirWilliamGoes SirWilliamGoes is offline
Real Name: William Adams
SirWilliamGoes has a spectacular aura about SirWilliamGoes has a spectacular aura about
Na bro youre good!! Mine looks like a budweiser can that was crushed and brought back. What i will say is be careful with the bolts. The dealer and others like to use an impact and that mixed with the bends not making it align right will eventually fatigue the bolts and cause them to break.
SirWilliamGoes is offline   Reply With QuoteReply With Quote
bent , hit , oil , pan , skid
Alcohol and Brain Structural Damage Thai Off Topic 99 01-02-2022 11:29 AM
Need shop recommendations in So Cal to fix bent up/dented RCI steel skid plates boyfester 5th gen T4Rs 5 11-22-2018 10:21 PM
Structural Damage Carfax Pastanoose General Discussions 12 12-11-2017 12:30 PM
Skid Plate / Front Undercarriage Bent and Beat Up (with pictures) limited05 4th Gen T4Rs 19 02-25-2015 03:26 PM
Skid plate is gone, should i worry? Jacobzky 4th Gen T4Rs 17 07-17-2007 03:08 PM
