Old 06-01-2021, 03:55 AM #1
michalik.piotr6837's Avatar
michalik.piotr6837 michalik.piotr6837 is offline
michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough michalik.piotr6837 is a jewel in the rough
Dobinsons MRR MRA install tips
This is just to make your install faster, there are other threads about spring rates and settings.
Front: First off when putting on adjusters... don’t lose or forget the tiny ball and spring. Pic one. Also if you take the hex bolt out of the shock, there is another small steal ball there.
Ignore all the you tube videos taking half the front suspension apart. You will undue exactly 6 bolts/nuts. 14mm top 3 on strut. 19mm bottom shock. Two 19mm holding the lower control arm. Now get a ratchet strap and just pull the lower A arm down and slide the shock out. See pic two. Assembly in reverse. No need for alignment b/c you didn’t mess with adjustor/caster plates.
Rear: Its way more of a pain in the ass FYI, front should be less then an hour per side.
Undue both nut/bolt holding shock and reservoir if you have a pro. Now cut/beat the crap out of the pinch weld above the nut b/c it will make your life easier putting on the new nut on the new shock.
Here is where it gets sketchy..... place scissor or bottle Jack b/t axl and bump stop to get spring out. Might have to use hilift to raise axl/hub to put top nut on.
Mount reservoirs under frame using provided brackets. They are different but labeled “R” and “L”. Careful so driver one doesn’t contact fuel tank skid. Don’t forget to undue the sway bar link, 12mm. Top nut is weird 18mm, bottom is 17mm.
Dobinsons MRR MRA install tips-bc7cbad4-4ede-4059-b4fd-9db14fa16169-jpeg  Dobinsons MRR MRA install tips-4b4aa73d-6dbc-4766-afb8-63ab192e6183-jpeg  Dobinsons MRR MRA install tips-417d8919-6fb5-40f1-bd27-c5fe30f3d3e3-jpeg  Dobinsons MRR MRA install tips-a9442dca-0038-4a11-bf8a-4aeaca4009d3-jpeg
michalik.piotr6837 is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 10:53 AM #2
Big Daddy K's Avatar
Big Daddy K Big Daddy K is offline
Real Name: Kevin
Big Daddy K will become famous soon enough Big Daddy K will become famous soon enough
Real Name: Kevin
If you have KDSS it helps to take the mount off the rigid side. Then it only need about 1/2” to fit the coils and spacer in. Working with a friend, you shouldn’t need a jack. But working by yourself it helps.
2016 Trail Edition Supa Dupa White
Dobinson's IMS lift, SPC UCAs, 285/70R17 Yokohama X-AT tires on Icon Rebound wheels, RCI Sliders and Skid Plates, Prinsu full length rack, C4 Fabrication rear bumper and fuel tank skid, and BPF molle panels.
Big Daddy K is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 11:07 AM #3
ha "no need for alignement" thats where youre wrong. Just cause you didnt touch the LCA cam bolts doesnt mean the alignment is still good.
Old 06-01-2021, 02:58 PM #4
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
100%
Originally Posted by honda250xtitan View Post
ha "no need for alignement" thats where youre wrong. Just cause you didnt touch the lca cam bolts doesnt mean the alignment is still good.
Daikon is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 05:57 PM #5
Might take it in but my tires are old anyways and I had a similar height lift on before this install...... either way...... fronts were easy. Might relocate rear reservoirs. Hard to access them now.
Old 06-02-2021, 03:43 AM #6
Relocated the rear reservoirs. Do yourself a favor and don’t. Untill someone comes out with a specific bracket. Too much work to get everything to clear.
Also, make sure the rebound screw on the bottom of the rear shocks is facing OUT! Hope this helps!
Old 06-02-2021, 03:45 AM #7
Here are a cpl pictures.
Dobinsons MRR MRA install tips-4e83dfae-361c-44c4-82ee-679ae59ac5be-jpeg  Dobinsons MRR MRA install tips-78927bde-acfd-4c40-b09b-41f4126686d8-jpeg
Old 06-02-2021, 09:26 AM #8
Hiitsmikee Hiitsmikee is offline
Hiitsmikee is on a distinguished road
How do your fronts feel going over speed bumps? My rear suspension feels fine. But my front suspension feels pretty harsh going over speed bumps unless going very slow. Also my driver side rebound adjuster on top is pretty much touching a welded on bolt above it that’s on the fender liner. Think I should break it down and re bolt everything down for that driver side? I originally had a lean spacer. But took it out and ran into that issue. Thanks!
Hiitsmikee is offline   Reply With QuoteReply With Quote
Old 06-03-2021, 12:59 AM #9
I’m on the default Prada settings and all feels fine but I will play around with the settings.
And ya, front adjusters almost touch the brazed on nuts. Seems fine tho? Might take em out and pound the liner like I thought of doing prior to install.
Old 09-18-2021, 05:50 AM #10
DeezyFBeezy883 DeezyFBeezy883 is offline
DeezyFBeezy883 is on a distinguished road
Looks good! Mine is similar I took the provided bracket and cut tab where it mounts to the frame
As of now no clearence issues.
Still trying to dial in settings for everyday road use.
Question for you or anyone who is running mra..any tips on adjusting spring seat up while
Under load?
Dobinsons MRR MRA install tips-dce1a1f8-0856-4d08-bd81-36863762c7c5-jpg  Dobinsons MRR MRA install tips-84075d0e-eea6-4fd4-aa8f-c998a5ae3edd-jpg  Dobinsons MRR MRA install tips-fc459e65-9524-4be9-9b87-d9f07065f8e8-jpg
2015 4Runner SR5 Magnetic Grey Metallic -
Dobinsons MRA - C59-314 springs Front - C59-327 Springs Rear - BFG ko2 285/70/17 - Pro Comp 05 17x8 - 1.5in WheelMate Spacers - Cali Raised Dual Function Light Bar - Rough Country Ditch Lights - Prisnu Full Length Rack -
DeezyFBeezy883 is offline   Reply With QuoteReply With Quote
front , nut , shock , top , undue
Dobinsons Strut Install - need help Drewfus_'13Limited 5th gen T4Rs 7 11-19-2019 02:01 PM
Tips to re-install IFS kc15842 Classic T4Rs 5 12-25-2014 09:19 PM
Toytec BOSS kit Install - Tools required and Tips for the install. Land_Shark 5th gen T4Rs 6 06-18-2014 12:36 PM
CV Install Tips sggaz 3rd gen T4Rs 5 10-19-2013 11:47 PM
