Old 06-01-2021, 02:03 PM #1
Capt.Canuck's Avatar
Capt.Canuck Capt.Canuck is offline
Capt.Canuck is on a distinguished road
Broken spring, need heavier spring advice
2015 TRD Pro with SSO front cutout winch bumper and winch, discovered one front spring is cracked and the other broken badly.
Need a front spring recommendation pls, that will better handle the additional 150lbs of front end weight.
Thank in advance for the help.
Broken spring, need heavier spring advice-761c6a92-13cf-4b6e-9046-8ae601c4e08d-jpg
2015 T4R TRD Pro (Super Sexy White) - FrontRunner full-length roof rack & expedition rails - Shrockworks rock sliders - SSO hybrid front bumper - Smitty X20 synthetic winch - Gobi rear ladder - XenonDepot HID Phillips 4300K headlight kit - interior LEDs - Focal IS690TOY speaker kit
Capt.Canuck is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 05:18 PM #2
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
I highly recommend 14"×3" 650# King springs, it'll help out with the additional weight and give you a slight lift. Your suspension looks like it has quite a bit of rust, you might want to inspect other suspension components integrity.
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 08:23 PM #3
Thank you, I appreciate the reply.
Old 06-01-2021, 09:12 PM #4
Pistol Pietro Pistol Pietro is offline
Pistol Pietro is on a distinguished road
I believe that your TRD pro has 60mm Bilstein shocks (very similar to the 6112). Those shocks require springs with an inner diameter large enough to accommodate the large shock body. Bilstein sells a set of medium load springs
Part: 53-291387.
If you're interested in replacing the shocks also, Bilstein sells a 6112 that includes springs that apparently would accommodate a somewhat heavier load.
Part number: 47-281202.
Although finding them in stock can be a little difficult.
2020 TRD ORP with KDSS. 285/70 17 BFG KO2s. Bilstein 5100s w/ stock springs on top perch in front, and Bilstein lift springs in rear. SPC UCAs. RCI rock sliders. C4 Fab Low Profile front bumper with Smittybilt H20 12k winch. Factor 55 Flatlink E. RCI roof rack, Baja Designs and cheap Amazon led lights, Switchpro 9100, BeyondWraps hood scoop stamp.
Pistol Pietro is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 11:13 PM #5
Akkording's Avatar
Akkording's Avatar
Here is more info on the 6112 springs on this thread to give you a visual of the lift. Rear springs upgrade would be ideal to balance the rear rake.
TRD Pro with 6112 coils (pics inside)
Old 06-02-2021, 12:02 AM #6
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Considering how old those shocks are, it is probably best to just get 6112s on 650lb springs and call it a day.
But of course, there is no perfect rear match so there is that (I am still waiting on my second 8100 to arrive, having ordered in January and received one two weeks ago!).
Old 06-02-2021, 12:43 PM #7
Excellent info, much appreciated.
broken , front , spring , trd , winch
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 Want to Buy/Trade 1 09-10-2019 08:21 PM
Hood won't lock. Found one spring broken and hanging karyins 4th Gen T4Rs 4 07-20-2019 05:40 PM
WTB: 5th Gen OME Front Strut w/ 2884/5 spring and rear shock w/ 2889/98 spring lhg9105 For Sale: Suspension/Wheels/Tires 3 11-05-2014 11:43 AM
fj spring Daystar spacers XREAS vs. fj spring Bilsteins 5100 cmoua 4th Gen T4Rs 8 06-24-2014 08:13 PM
heavier spring help jam23r1 5th gen T4Rs 8 01-19-2014 06:49 PM
