06-04-2021, 04:33 PM
Winch installed and …
Installed a winch yesterday did the measurements and the it sagged 3/4 inch. From 23 to 22-1/4 inch. I’m running toytec ultimate lift kit with adjustable coilovers ( old version) The question is should I adjust them to go back to 23 inch maybe 23-1/2 or go with bilstein 6112 as an upgrade. What do you think?
Thanks
06-04-2021, 04:37 PM
New coils because adding more preload is just going to make the ride stiff.
06-04-2021, 06:10 PM
How important is ¾" to you?
Will you now have to use the winch because of the installation?
06-04-2021, 07:02 PM
3/4 inch is not that bad hopefully it’s not gonna gag more, and of course i will use the winch the thing is that besides winch I also have slimline steel bumper and heavy sliders, that’s why I’m not sure if those coilovers will handle all the weight.
06-04-2021, 07:08 PM
Your call. We went with 700 lb coils with our coilovers because we knew the bumper and winch were coming soon. I’d probably leave it unless it really bugs you.
Her, Him & The Moose (RIP Moose 2010-2020) - Adventure bound
2018 TRD Off Road - First 4Runner!
@mooset4r on Instagram
06-04-2021, 11:43 PM
Real Name: Neal
Real Name: Neal
06-05-2021, 02:58 AM
Thanks
As others have mentioned, you just have to upgrade to heavier coils if you don't mind the rake.
Now, whether or not you 'NEED" to upgrade your coils, is find the crappiest road near you with lots of potholes, and see if you bottom out easily. If you do, then you probably need to upgrade your coils. another way, is to push up and down on your bumper, and if its easy to move up and down with just your body weight..you probably need to upgrade your coils. Or go offroading, and if you get thrown all over the inside of your car like a pinada..you need to upgrade your coils...lol.
06-05-2021, 09:26 AM
The bumper go easy up and down with my body weight at 190 )
Thanks
06-05-2021, 09:39 AM
Originally Posted by nglayton
I see what you did there, lol.
06-05-2021, 10:26 AM
I’ve got a similar problem with my 6112s... I’m trying to find heavier coils other than the ones (600lbs???) that came with my “kit” from Yotamafia. I am on the Bilstein site now...But, who else (King? Icon?) makes heavier coils that match the 6112’s?
Thanks
06-05-2021, 11:11 AM
What about Boss Aluma 2.0
06-05-2021, 12:16 PM
Thanks
Look at Eibach. They are available in 650# or 700# depending on what other weight you have. However, I had those coil overs some years ago and I though they came with a 650# coil? That's how I ended up with 700# on my rig. I think there is a part number stamped on the coils you could look up
EIBACH 14" COIL SPRING PAIR FOR 2.5" COILOVERS
06-05-2021, 12:17 PM
Thanks
Here are my backup 6112’s I have 650# King springs mounted.
2016 TEP, Elka 2.5 RR Adj F&R, Chaos UCA & LCA, OME 899, KO2 285/70E, Wheeler F&R Bumps, BMC, Spindle Gussets, Cam Tabs, Nitro 4.88 Gearing, Tranny Cooler, Hefty Fab F&R Bumpers Dual w/ ladder, Warn Plat 12s, Icon Pan & Billet Rear Links, OCD Links, GFC RTT, RCI Sliders, Every RCI Skid Plate (In Alum if avail), SCS Stealth 6 Rims, ARB Twin Comp, ARB 2500 Awn, Quick Pitch Shower Awn, Compustar T11 & RMS, Dual 42" drawers W/ Adj sleep/dog height platform (2nd Row Removed) Switch Pros, Baja LP9's, Squadron & S2 Pros, Rock Lights, Dometic CFX3 35qt.
06-05-2021, 01:07 PM
I had the same problem. I have the same lift that you do also. I was able to switch out the steel cable for a synthetic line and I gained back my sag from the weight difference.
2004 SR5 V8 AWD
06-05-2021, 06:45 PM
Although not the OP, thanks for the info/answers as well. I spent some time over on the Taco forums and there’s a 6112 coil upgrade “debate” over 650’s and 700’s. Looks like Bilstein doesn’t recommend the 700’s unless you have the 8112 coils, but... apparently Eibach 700’ will work. ...isn’t Bilstein also Eibach?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
