Old 06-04-2021, 07:09 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Car Started and died immediately
Weird issue today after work. Started my car, it turned over like it normally would, but died immediately when the engine turned over. I didn’t notice any check engine lights or anything. I also have a volt meter plugged into the cigarette light, but it was over 12v before the engine turned over. Couldn’t tell what voltage it was at exactly since it happened so quick. I know for sure it read at least 12v or else the volt meter would blink, which it did not. I tried to start it again and it was perfectly normal.
I have an AGM battery with a voltage booster. My usual commute is 35-40 minutes one way if you need that info. Should I be concerned? Anything I should check?
Chilow is offline   Reply With QuoteReply With Quote
Old 06-04-2021, 08:13 PM #2
jawkdna's Avatar
jawkdna jawkdna is offline
jawkdna has a spectacular aura about jawkdna has a spectacular aura about
jawkdna's Avatar
This sounds exactly like what happens after you disconnect and reconnect a battery... The rig will die on first start up.
Had you disconnected the battery? Could your terminals be loose?
"Outgunned, outnumbered, though never outclassed" - Bolt Thrower
XXX
Toyota Trucks Patches, Pins & Stickers | 2016 Trail Premium Edition | Icon Stage 2 | KO2 285s | BlackGate Customs KDSS Rear Sway Bar Drop Kit | RCI Skids | Pelfreybilt Sliders | Gobi Stealth Rack | TRD CAI | Sprint Booster | DuroBumps | Stahlbus Oil Drain Valve
jawkdna is offline   Reply With QuoteReply With Quote
Old 06-04-2021, 08:15 PM #3
jawkdna's Avatar
jawkdna's Avatar
From another thread-
"Found it. Page 515.
404
●The engine may not start on the first attempt after the battery has recharged
but will start normally after the second attempt. This is not a malfunction."
XXX
Old 06-04-2021, 08:18 PM #4
Haven’t disconnected the battery and I don’t think it’s loose. If it was, my alarm would probably trigger. Usually when I would remove the negative battery terminal and reconnect it, it would trigger the alarm until I unlock/lock via the key fob.
Old 06-04-2021, 08:36 PM #5
rageandlove's Avatar
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
I don't get that alarm when I disconnect the battery. I DO get the immediate die after the first start after I hook it up.
I've been doing a bunch of electrical work, so I've gone through that about 10 times since Dec.
rageandlove is offline   Reply With QuoteReply With Quote
Old 06-04-2021, 08:38 PM #6
91foxbody 91foxbody is offline
91foxbody will become famous soon enough 91foxbody will become famous soon enough
Did you shift it out of park too quickly? That’s happened to me more than once, it’ll cut off immediately.
91foxbody is offline   Reply With QuoteReply With Quote
Old 06-04-2021, 09:19 PM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
My tacoma did that when the battery died. It started fine, but as soon as I hit the brakes it died. Had to drive to the sore using the emergency brake to get a battery. True story!
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 06-05-2021, 08:43 AM #8
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
If it doesn't do it anymore, I wouldn't worry about it. Mine does it every time I reconnect the battery just like the others do. I have also had it happen twice at random. It was about a year in between them. I can live with that.
If it continues, the battery is the first place to look.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 06-05-2021, 12:12 PM #9
Ripper238's Avatar
Ripper238's Avatar
I have this happen every once in a while when i use my remote start. Plus i get this beeping when it fails to start. Noida why it does this, i just Chalk it up to the very sensitive electronics in the Toyotas that just like everything perfect.
Though i thought it could have to do with the fuel pump recall.
Old 08-09-2023, 08:57 AM #10
AlexaDuffy's Avatar
AlexaDuffy AlexaDuffy is offline
AlexaDuffy is on a distinguished road
AlexaDuffy's Avatar
Hey there! Don't sweat it too much; cars can be a bit quirky sometimes. It sounds like a hiccup that might not be a big deal. Your AGM battery with the voltage booster should generally be good to go. Maybe it just had a momentary glitch or something. Since your voltmeter was reading fine and the second start was normal, it might have been a random blip. If it keeps happening, maybe check your connections, but for now, I wouldn't stress too hard. Oh, and about that long commute, it's good to keep an eye on your battery's health. And speaking of cars, have you ever thought about car shipping door to door? I think this is a cool approach by many car companies that care about their customers.
AlexaDuffy is offline   Reply With QuoteReply With Quote
Old 08-10-2023, 05:06 PM #11
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Old thread. But I'll chime in. Mine does this to me maybe every 6 months to a year. Just once. Connections perfect, battery new or old, plugs new or old, MAF and air filter and TB clean or dirty, doesn't matter. Once every once in a while. It's always given me a second of pause and concern. But just for a second. Then it's fine for like another year until it does it just once again. I just accept it as normal now.
Sent from my SM-S901U using Tapatalk
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 08-10-2023, 07:45 PM #12
cumminsdieselfreak's Avatar
cumminsdieselfreak cumminsdieselfreak is offline
cumminsdieselfreak is on a distinguished road
Do you have a smart key? If so I'd recommend replacing the battery in it.
Sent from my Pixel 7a using Tapatalk
2022 4Runner ORP: Elka 2.5 DC, SPC UCA, 285 Cooper Rugged Trek
cumminsdieselfreak is offline   Reply With QuoteReply With Quote
car , check , engine , turned , volt
Battery Light started blinking then the car died and now car won't start! robaroni 4th Gen T4Rs 7 04-05-2017 10:25 PM
4Runner started, then died. 1 previous hard start. A.Wilson013 3rd gen T4Rs 2 12-17-2011 02:39 PM
WTB immediately evensteven Classifieds - buy & sell (no commercial ads please) 2 04-22-2011 10:44 PM
