Old 06-06-2021, 04:30 PM #1
inrebuttal2u inrebuttal2u is offline
inrebuttal2u is on a distinguished road
C1406 code - simple remedies not working
Okay 4Runner friends, I need some assistance.
I have the ABS, 4WD, and slip lights on the dash. The 4WD light is flashing. ABS and slip are constant.
I searched the forum and saw a discussion on ABS, 4WD, and slip indicator lights discussion. I havenÂ’t done a lift. I didnÂ’t replace lights with LEDs.
I have:
Changed the gas cap,
Replaced the whee speed indicators on LF and RF, and
Replaced the LF ABS wiring harness.
The OBD code I get is C1406, which is “open or short in front speed sensor LH circuit.”
Any ideas?
inrebuttal2u is offline   Reply With QuoteReply With Quote
Old 06-06-2021, 04:32 PM #2
Added info
It’s a 2010 SR5.
Old 06-06-2021, 11:05 PM #3
fkheath fkheath is offline
fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold fkheath is a splendid one to behold
I have:
Any ideas?
C1406 TOYOTA Open Or Short In Front Speed Sensor Left Circuit (With Video)
Most likely the ABS speed sensor on the front left wheel is bad, or the connector is not making good contact. Have you replaced that sensor?
fkheath is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 12:54 PM #4
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I have:
Any ideas?
Have you done a zero point calibration?
Yaw Rate and Acceleration Sensor Zero Point Calibration
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 05:51 PM #5
mike5 mike5 is offline
mike5 is on a distinguished road
Why not do a continuity test on the wires and confirm the message?
2013 T4R TE
My Adventures
mike5 is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 11:10 PM #6
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Rat stopped by for a quick snack, follow the harness and look for open in the harness.
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 06-10-2021, 11:31 PM #7
I replaced the wheel speed sensor and the wiring harness on that side, and the wheel speed sensor on the RH side, too.
Old 06-10-2021, 11:34 PM #8
I have not. I’ve watched the videos on YouTube, but they’re all for prior gens.
Old 06-10-2021, 11:35 PM #9
I replaced the harness. No hungry rats found.
Old 06-10-2021, 11:37 PM #10
I guess this is my tomorrow project, now.
Old 06-12-2021, 07:30 PM #11
Calibration completed. It did not clear the lights.
Old 06-15-2021, 06:13 PM #12
To recap, I tried these things:
1) changing the gas cap (did not work),
2) changed LH and RH front wheel speed sensors (did not work),
3) changed LH wiring harness (did not work), and
4) completed zero point calibration (did not work).
I ended up punting it to the repair shop. According to the shop - deeper in the engine was a broken wire that controls the LH ABS.
So, there ya go, fellow 4Runners. The fix - relatively cheap. The diagnostics - 2 shop hours.
Old 05-05-2023, 09:45 PM #13
haplo818 haplo818 is offline
haplo818 is on a distinguished road
I had code c1406 and c1414. Replaced the sensor and wire and got rid of the c1406 code but not c1414.
After replacing the sensor and wire I did a road test and the ABS went crazy as soon as I hit the pedal and the code came back right away (after clearing with scanner).
Turns out my LF bearing was so bad that the speed signal got corrupted and threw the c1414 code.
Local shop struggled quite a bit to release old bearing and install new but issue is now fixed.
haplo818 is offline   Reply With QuoteReply With Quote
4wd , abs , c1406 , lights , slip
Interior noises and remedies MikeMikeMikeT4R 5th gen T4Rs 2 05-16-2020 01:14 PM
285 clearance remedies judoant 3rd gen T4Rs 13 11-17-2019 11:55 AM
Sludge remedies Bijan 3rd gen T4Rs 33 10-25-2016 09:04 AM
Metal Tech Black Friday code not working... STX4Runner 5th gen T4Rs 11 11-29-2013 03:56 PM
Is there a working discount code for v-LEDS.com? kavalis 3rd gen T4Rs 1 09-01-2011 01:22 AM
