Old 06-16-2022, 03:22 PM #1
RaceAddict's Avatar
RaceAddict RaceAddict is offline
Real Name: Kevin
RaceAddict is on a distinguished road
RaceAddict's Avatar
Real Name: Kevin
Gear Selector Ignition Interrupt switch
I don't know what the actual technical term for this is, but there's evidently a switch/sensor of some sort in the gear selection mechanism that prevents the truck from starting if it doesn't "see" that it's in Park.
Mine's been acting up.
Sometimes the truck starts first try, no problem. Other times there's zero ignition and I have to press the brake pedal, jiggle the gear selector right to left, and it starts. Occasionally I even run it down to Reverse or Neutral, back into Park before it fires up.
Before I start pulling the center console apart:
Has anyone else had this happen?
I'm guessing it could be as simple as an electrical contact that needs cleaning... but could it also be a whole sensor that's failing?
In either case, is there's a walk-through for disassembling the center console? I hate experimenting with interior clips... they're not always easy to find until they snap.
2016 TRAIL - MGM
C4 Bumper - WARN VR10S
OME Lift - Prinsu Rack
Adventure Index DIY Storage System
Summer: Falken A/T3W (Winter: Nokian Hakkapeliitta 8 SUV)
RaceAddict is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 03:27 PM #2
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
I have not been prevented from starting or shifting, but there’s some kind of latent “click” / release that only seems to occur once I’m in drive and have begun to drive off. (Typically first 100-200 feet of wheels rolling)
What is this? 2021 Nightshade.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 03:43 PM #3
spartacus's Avatar
spartacus's Avatar
neutral safety switch 84540-35060.( check the part against the vin). But truck should still start with the truck in park. No ignition could be an electrical issue. Battery contacts good and clean is a good start.
Old 06-16-2022, 03:53 PM #4
Pavement Tested Pavement Tested is offline
Pavement Tested will become famous soon enough
Speed sensitive door locks locking at approximately 10-15 MPH.
2016 Trail Attitude black. 1.5" unknown brand lift, 275/70-17 Toyo Open County A/T on DX4 Rebel 17x8.5 -6, bull bumper, light bar, skid plate by Amazon, DD fogs, TRD roof rack by Craig's List, Accessorides remote start kit
Pavement Tested is offline   Reply With QuoteReply With Quote
Old 06-16-2022, 04:00 PM #5
spartacus's Avatar
spartacus's Avatar
Starter contact corroded could also be an issue.
Old 06-16-2022, 04:21 PM #6
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Neutral safety switch on the passenger side of the transmission is likely the culprit. It gets corroded from Winter salt etc. This makes the selector hard to shift. There are a few threads on this; as it's a common problem due to the switch not being sealed. A few members here have changed their own - doesn't appear to be all that difficult, but may be complicated depending on how badly corroded it is.
Old 06-16-2022, 04:28 PM #7
This is a single click that sounds like it’s coming from under the steering column.
There’s still a chance it could be a loud relay for locks, but I’m not hearing the locks themselves actuate in the same way as if I pressed the button.
One other thing came to mind. I was pulling out of a gas station one day that had a speed bump. I approached very slowly and actually came to a stop before proceeding over it.
When I tried to proceed over it, this same relay/switch actually got hung up and began a rapid clicking, which did not stop until I shifted out of drive and back in.
Old 06-17-2022, 01:32 PM #8
RaceAddict's Avatar
Real Name: Kevin
RaceAddict's Avatar
Real Name: Kevin
I had that done last winter... Canadian winters are not vehicle friendly. Shifting got worse the colder it got.
This starter interruption is a different thing.
2016 TRAIL - MGM
gear , ignition , park , selector , truck
Seeking Advice on Adding a Switch to Interrupt Headlight Power Bluesky 07 4th Gen T4Rs 3 08-29-2021 06:48 AM
4runner Doesn't know it's in Gear, Gear Selector in Dash Not Lit, VSC goes off the_josh 4th Gen T4Rs 2 01-26-2021 01:35 AM
Gear selector gone bad tnark 4th Gen T4Rs 4 12-26-2012 01:08 PM
gear shift selector riceandpho 4th Gen T4Rs 4 08-20-2011 11:47 PM
gear selector switch oxfordethan 3rd gen T4Rs 3 11-14-2007 12:36 PM
