06-08-2021, 01:29 PM
Trd or aftermarket outer tir rods needed
I’m maxed according to my alignment tech so I’m looking for shorter outer tie rods to get within spec
Thanks Mike
06-08-2021, 01:50 PM
Is there something on the front steering / suspension that is bent, broken, or missing?
2015 4Runner Trail Non-KDSS Husky Floor Mats Falken Wildpeak A/T3W P265/70R17 AFe Drop in Air Filter So far stock... Loving it
06-08-2021, 01:52 PM
Definitely sounds like something is messed up.
06-08-2021, 02:47 PM
Yes he feels like my rack has internal damage but not enough to be broken I was looking for a band aid fix till I can get a new or rebuilt rack I guess it does operate fine no noises or mis step
06-08-2021, 06:23 PM
sounds like you need a new alignment tech.
06-08-2021, 06:28 PM
Real Name: Ron
Real Name: Ron
Measure your toe and compare to spec. As long as you can get about an 1/8" toe in or out, or something in between, and one side not showing 3+ more or less threads should be ok. Am I off base here alignment pros?
06-08-2021, 08:35 PM
Can you post the current alignment results and pictures of the outer tie rod ends?
Have you (or anyone) replaced the inner or outer tie rods? The stock ones should have plenty of adjustment unless something is very wrong
06-09-2021, 09:29 AM
yea thats what i'm thinking as well...as in bent shock hoop, bent spindle, bend lower control arm sub frame.
06-09-2021, 10:47 AM
where do you offroad lol, hope your steering rack is ok hah.
2017 Barcelona Red TRD PRO - Urd Supercharged - 4.88 Gears - ADS Shocks with External Reservoir/Clickers - King Secondary and Rear Bumpstops - Total Chaos Expedition LCA - JDFabrication LCA Pivot - RCV CV Axles - Icon UCA - Titan7 T-AK1 - Nitto Ridge Grappler 285/75R17 - Oem+ Reference Audio - Proline R1 Guard Bumper - Pelfreybilt Base Rear Bumper - Heftyfab Skids - Demello X-Wing Sliders - Prinsu Roofrack - Sos Stoptech Big Brake Kit - TJM Snorkel - URD Mark3 Catback Exhaust
06-09-2021, 03:39 PM
Off-roading in good old nyc pothole hill and a few moguls to add to my sphincter muscle flex thrown in to spice up my life and lighten my wallet
mike
06-10-2021, 09:53 AM
mike
its crazy the tie rod ends didnt bend first. They usually do, which is great cause its easier than a rack as you obviously know.
06-11-2021, 01:38 PM
All good again aligned wrong to 03 specs not 18 tech had a brain fart moment car is back to good but I will need stock tie rod ends before winter though
people are using corona excuse too often
