Old 06-09-2021, 12:16 AM #1
mann65 mann65 is offline
mann65 is on a distinguished road
Switch Wiring
Hey there,
I have the SSC2 Ditch lights, with the back-light option, and Purchased a custom switch to utilize both lights (not at the same time obviously), in other words I ordered a CH4x4 dual push switch with the following diagram;
I also purchased the Diode Dynamics 4 pin, 3 way switch harness and I'd like to wire the CH4x4 switch to it in place of the 3 way switch it came with.
Wondering how to do this, the Diode switch only has 3 wires, and the CH4x4 has 5.
Thanks!
Switch Wiring-dual-toyota-push-switch-wiring-scaled-jpg  Switch Wiring-dd4093_heavy_duty_dual_output_4-pin_wiring_harness_diagram_b-jpg
mann65 is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 06:48 AM #2
NB17Limited's Avatar
NB17Limited NB17Limited is offline
NB17Limited will become famous soon enough NB17Limited will become famous soon enough
You essentially have two circuits on the CH4X4 switch. The black and yellow are your hot and ground for the backlights. The other three are for switching your lights.
You could trace the wires or use a multimeter but I believe based on looking at this, that on part A of the Diode Dynamics diagram, the red wire is your hot wire. That should go to the red wire on your switch. The other two colors on your switch, blue and green, would go to the Diode wires that are blue and yellow. Thatís how I would wire it and see if it works.
Iím sure someone will tell me if Iím wrong
NB17Limited is offline   Reply With QuoteReply With Quote
Old 06-09-2021, 09:06 AM #3
Thanks for the reply
With all that said, I would probably need to find a ground for the black wire, it's pretty short, so it would need to be extended if I wanted the switch to illuminate?!
Thanks alot!
Old 06-09-2021, 09:55 AM #4
Thanks alot!
Yes. Need a complete circuit if you want the light to illuminate. Youíll need to extend it but it just needs to get to any bolt on the chassis. If youíre putting it next to an OEM switch, you could figure out which is the illumination hot wire and which is the ground and just tap those. Thatís my plan whenever I finally get around to installing the lights and switches I have laying around
ch4x4 , diode , lights , purchased , switch
AOB Switch wiring help Primo 5th gen T4Rs 12 10-11-2019 05:54 PM
Wiring air on board switch to Amazon wiring harness. Btmannin Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-18-2018 03:33 PM
DAC switch wiring matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-02-2013 02:18 PM
Help with switch wiring ARK_SWAMP_RIDER Classic T4Rs 3 09-09-2013 06:32 PM
