Old 06-13-2021, 08:19 PM #31
Mack1611 Mack1611 is offline
Mack1611 is on a distinguished road
Been running it for a couple of years now.
Mack1611 is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 09:57 AM #32
Ripper238's Avatar
Ripper238's Avatar
Originally Posted by 97BlackAckCL View Post
Odyssey batteries are awesome, I switched over from Optimas on both my cars a few years back and have been ecstatic with my Odyssey's on both
What size did u get?
It appears the 24f has more capacity than the 34?
Old 06-20-2021, 10:33 PM #33
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
I got the 34 because I wanted a direct replacement battery, the 34-PC1500T. If I had to do it over again, I would get the 34M-PC1500ST-M with the extra set of terminals, but I love my 34.
Old 07-01-2021, 10:16 PM #34
Signal Signal is offline
Signal has a spectacular aura about Signal has a spectacular aura about
So I've read a ton of threads on the duel battery topic and I am going to start sourcing parts. Here is the list if I am missing anything please let me know.
2 of these Fuse blocks
1 of these
Smart Solenoid ????
1 of these
Battery tray
2 of these and a few incase they get blown
Fuses
I just don't know if I will need a new fuse box for the lightbar and fridge and what's a good fuse box to get.
The Build
2019 TRD ORP, OME 3" lift w/ heavy springs Front and Rear, Kenwood TM-D710GA, ARB Breather, Aux Beam Highs, lows, and fogs, Raptor lights, LFD Rear Bumper
Signal is offline   Reply With QuoteReply With Quote
Old 10-03-2023, 11:25 AM #35
yourfriendcasey's Avatar
yourfriendcasey yourfriendcasey is offline
yourfriendcasey is on a distinguished road
Originally Posted by bring_it_on View Post
Many folks here run the Northstar Group 27F as a single large battery. One option is to buy the Tundra battery tray that will fit a 27F. A Group 31 AGM will also fit in the stock location. Depending on what size LED's we are talking about, a simple upgrade to a Group 34 AGM should be more than plenty for your use case.
Here are a couple of good AGM options (make sure to check the terminals)
Group 34 - Will fit with existing tray -
Just a moment...
Group 27 - Need to remove the tray and mount it directly on metal or buy a Tundra battery tray
X2Power Premium AGM BCI Group 27F Car and Truck Battery - SLI27FAGMDP at Batteries Plus Bulbs
I know I'm reviving an old thread here, but just wanted to chime in and say that you don't need to do anything to put in an 27f. It fits the stock battery tray on a 4th gen without any modifications whatsoever.
I see no reason why you'd want to put in a group 34, its smaller than both the 27f and the 24f. And costs the same amount as the 24f. I have the exact powerx2 27f battery you linked above and its worked wonderfully.
Regarding the dual-battery debate, I'd recommend against using your starting battery for running a fridge unless you have a reliable way to jump your car. Keep your fridge on the lowest battery protection setting. Even on the lowest setting for most fridges, it will bring you into risky territory for your car not starting in the morning by the time it kills the fridge. If you want something simple, look into an ecoflow or similar power bank. Expensive but less expensive than a dual-battery setup and you will probably find a ton of use for it other than running your cooler. Plus you can take your cooler out of the car and bring it anywhere.
Also have to consider that dual battery adds a ton of weight, and if you're using an AGM battery, you are only getting 1/2 of the advertised AH in usable power. 100AH AGM battery= only 50AH of usable power. If you want a bigger battery built-into your vehicle, get a LifePo4 and a dc-dc charger. Way less weight, WAY longer-lasting battery, and nowadays they are cheaper. You can discharge them pretty much 100% so you actually get the advertised AH in usable energy.
05 v8 Limited - Eibach Pro Lift Kit 3" Front, Ironman foam cell pro w/ 3" mid weight coils Rear - JBA High Caster UCAs - Coastal Offroad High Clearance Rear Bumper w/ Dual Swingarms - Toyo Open Country ATIII 285/70/17 - Bronze Raceline Clutch 17x9 Wheels - Raptor Liner Paint - Front Sway Bar Delete - Extended Rear Sway Bar Links - Rear Diff Breather - RCI 1/4" Aluminum Front Skid - Cali Raised DOM Rock Sliders
yourfriendcasey is offline   Reply With QuoteReply With Quote
2nd , advised , battery , kit , smart
Awesome Videos of a Dual Battery Install Titanpat57 5th gen T4Rs 9 06-28-2017 10:44 PM
Peak DBI Dual battery monitor Install Mr.emergency Engines / Suspension / Wheels / Tires / Audio / Accessories 1 03-30-2017 06:48 PM
help, keep blowing fuse on dual battery install Jc12 3rd gen T4Rs 3 11-09-2014 09:14 PM
Diehard install dual Battery wiring warning Mick1 5th gen T4Rs 17 07-10-2014 09:08 PM
Dual Battery & Ham Radio Install-Pics!! Synister Engines / Suspension / Wheels / Tires / Audio / Accessories 1 10-11-2011 02:23 PM
