Old 06-15-2015, 11:59 AM #1
vumcrab vumcrab is offline
vumcrab is an unknown quantity at this point
Popping/Knocking from Front End
Guys,
2012 4R SR5 2WD, 50K mi.
For the past several months, I've noticed a loud popping or knocking sound coming from the front end when driving at low speeds and turning the wheel and/or going over small bumps...like driving in a parking lot and making turns. I've checked heat shield, etc. Didn't know if this could be related to body mounts or the like.
If anybody has had the same problem or you have a TSB that may help, I would appreciate it.
2005 V6 4Runner SR5
Saddleman Seat Covers
Exhaust Tip
Toyota All Weather Floor Mats
Weather Tech Cargo Mat
vumcrab is offline   Reply With QuoteReply With Quote
Old 06-15-2015, 12:09 PM #2
hearno's Avatar
hearno hearno is offline
hearno is on a distinguished road
hearno's Avatar
Maybe update your signature and then check your sway bar links?
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
hearno is offline   Reply With QuoteReply With Quote
Old 06-15-2015, 12:30 PM #3
Lenny33 Lenny33 is offline
Lenny33 is on a distinguished road
I am on the sway bar links thought process too - mine make a fair amount of noise.
2010 Mag Grey SR5 4Runner. 3" Lift with adjustable Boss coilovers in the front and Bilsteins in the rear. Light Racing UCAs. 285/70 17 BFG All Terrains.
Lenny33 is offline   Reply With QuoteReply With Quote
Old 06-15-2015, 04:49 PM #4
FactoryRide's Avatar
FactoryRide FactoryRide is offline
Real Name: Spencer
FactoryRide is on a distinguished road
Real Name: Spencer
I get the same sort of pop noise from the front end as well. I have KDSS though, so that would sort of rule out the sway bars for us both. I think.
I've had mine for a little while, and cannot seem to find it. I'm getting ready to completely tear apart the front end again to see if I can't find it.
2011 TE
FactoryRide is offline   Reply With QuoteReply With Quote
Old 06-15-2015, 05:26 PM #5
Daily-runner Daily-runner is offline
Daily-runner is on a distinguished road
I have this too. I have replaced the sway bar links and bushings. Still popping so it is definitely not the bar.
Lou
Mobile Toys Inc. College Station, TX
'14 Lexus GX460
'10 Tundra CM
'13 Audi A3 Sportback
Daily-runner is offline   Reply With QuoteReply With Quote
Old 06-16-2015, 06:48 AM #6
spooln30 spooln30 is offline
spooln30 is on a distinguished road
Is it mostly when your steering wheel is at or near full lock? Could be the steering stop points needing grease. Don't know if they still use those plastic caps like on my 99 4runner anymore.
spooln30 is offline   Reply With QuoteReply With Quote
Old 06-16-2015, 08:58 AM #7
It's not the steering stops. Most of time it's associated with driving over a slightly irregular road at slow speeds. Turning the steering wheel while going over small bumps (like turning into my driveway at home) is associated most of the time too.
2005 V6 4Runner SR5
Exhaust Tip
Old 06-16-2015, 01:52 PM #8
Mick1's Avatar
Mick1 Mick1 is offline
Mick1 is on a distinguished road
Mick1's Avatar
I occasionally get the loud front suspension pop noise on braking / turning.
I have Icon suspension and KDSS, 66K miles.
I doubt it would be the swaybar, I've been thinking it is the tie-rod ball joint loosening up and and have been considering an inspection or tear down because I don't want to have it break on a trail. I'm totally guessing at this point.
RHINO
'11 Trail
http://rhino4runnersuspension.shutterfly.com/
Mick1 is offline   Reply With QuoteReply With Quote
Old 06-17-2015, 01:46 AM #9
This is on your 2005 correct? I would say it's either the sway bar end links or the sway bar bushings but I would lean more towards the end links. The sound and when it happens indicates to me end links.
Old 06-17-2015, 02:17 AM #10
Jono.ful's Avatar
Jono.ful Jono.ful is offline
Jono.ful will become famous soon enough Jono.ful will become famous soon enough
Jono.ful's Avatar
I used to get this too, once I pulled my sway bars it stopped immediately
2012 Magnetic Grey Metalic SR5 w/ upgrade pkg (Canada)
pretty much bone stock
Instagram: ab4runnin
Jono.ful is offline   Reply With QuoteReply With Quote
Old 06-17-2015, 10:31 AM #11
This is in my 2012 4tunner.
2005 V6 4Runner SR5
Exhaust Tip
Old 06-19-2015, 03:07 AM #12
A good way to pin point where it's coming from would be to disconnect the end links from the LCA then drive the truck. If the noise goes away it's either the end links or bushings but if the noise is still there it's something else. I do this process often when I can't find anything loose in the suspension but it's making noise. GL.
Old 06-23-2015, 02:34 PM #13
Vegas's Avatar
Vegas Vegas is offline
Vegas is on a distinguished road
Vegas's Avatar
Same noise on mine.....aaaaarrrrgh
2012 Toyota 4Runner Trail, Black, NAV & KDSS My build thread:
http://www.toyota-4runner.org/5th-ge...ld-thread.html
Vegas is offline   Reply With QuoteReply With Quote
Old 06-23-2015, 07:09 PM #14
Jai02 Jai02 is offline
Jai02 is on a distinguished road
Originally Posted by vumcrab View Post
Guys,
I had the same problem. I looked under the truck and noticed my front sway bar was touching my radiator bracket. The noise only comes when driving and turning at low speed. My suspension guy just added a thick washer and the problem went away. Hope this sort of helps
2011 SR5 - ICON stage III Billet. 3" rear coils. ICON Panhard bar. ATX 17x8 wheel - Crawl- . Duratracs 285/70/17. Custom shifters. Weathertec mats. 2014 Tail lights. Retrofit headlights. TRD Cold Air Intake.
Jai02 is offline   Reply With QuoteReply With Quote
Old 12-11-2017, 01:53 PM #15
Mr. Weber Mr. Weber is offline
Mr. Weber is on a distinguished road
Front End Noise
I have a 2008 SR5. The clunking sound coming from my front end turned out to be due to the front stabilizer bushings. The sway bar is supposed to twist while seated in the rubber bushings but I think the rubber became less supple and was gripping the bar too much and allowing the bar to smoothly twist in the mount. When it finally did give, it made a clunking sound. I replaced the bushings with new ones but probably could have just taken it apart and put some silicone grease between the bar and the bushing and solved the problem. Easy cheap fix. FYI the bushing bracket clamps are marked left and right.
Mr. Weber is offline   Reply With QuoteReply With Quote
Popping in front end??? 4runningyota 3rd gen T4Rs 26 04-20-2022 05:34 PM
14' 4Runner popping noise from front end. Need help and idea. Apex Overland 5th gen T4Rs 7 04-18-2015 05:18 PM
Popping noise in front left? Laubage 5th gen T4Rs 18 12-24-2012 06:40 PM
Popping from front left BobLMTDT4R 3rd gen T4Rs 11 07-07-2012 10:00 AM
popping front end? rdgt4r 3rd gen T4Rs 5 02-09-2009 11:06 PM
