Originally Posted by Rack
Check the chargers owners manual to make sure it can be used on AGM batteries
Also there is no reason to disconnect the battery when charging.
See if your charger has the quick connect plug instead of the alligator clips.
These attach to the battery terminal bolts and makes it easier to just plug in the charger.
Most chargers come with these.
Thank you. Was worried it may cause issues if the battery was connected while charging.
Charger is definitely rated for AGM, has a AGM mode.
I was contemplating doing the quick connect plug instead since the alligator clips convert to it. But its quite likely ill only need to charge a couple times a year before long trips.
