Old 06-10-2021, 01:39 PM #1
Ripper238's Avatar
Ripper238's Avatar
Additional battery time needed AGM G34
Been thinking of doing a dual battery system but it seems all i really need is a deep cycle AGM since it will primarily be providing power for my 20W / 1.45A BaJa LED's for setting up camp and maybe some amplified music from my 600 watt amp (low volume/not at same time) for a few hours.
Figured i would put down where i am so far and revisit when i am ready (also get some input). So far:
AGM Group 34 in ether an X2Power X2Power Premium AGM BCI Group 34 Car and Truck Battery - SLI34AGMDP at Batteries Plus Bulbs
Or Odyssey battery (not sure model Odyssey).
And to provide enough voltage to charge the AGM i will need a Voltage Booster like this: HKB Electronics
Or i could go with a battery tender Amazon.com: NOCO GENIUS5, 5-Amp Fully-Automatic Smart Charger, 6V and 12V Battery Charger, Battery Maintainer, Trickle Charger, and Battery Desulfator with Temperature Compensation: Automotive
I really prefer to do things the safest and best way so not to mess with my 4R since it seems its sensitive to changes in electrical modifications (have had issues with a remote start). So i may just upgrade the battery and forgo the Voltage Booster, but it sounds like a battery tender may not be enough if i don't drive much daily.
I would just go with a regular high CCA lead acid battery so not to mess with things but i would really like to be able to have some backup power for those 2 things.
So far that's all the info i have gathered.
Old 06-10-2021, 04:19 PM #2
bring_it_on's Avatar
bring_it_on bring_it_on is offline
bring_it_on will become famous soon enough bring_it_on will become famous soon enough
The voltage booster you've mentioned is pretty good and perfectly fine to use. I use a different one with two boost settings but they all get the job done. It is as simple as literally pulling out a fuse and adding it instead and you can reverse the process whenever you wish to do so. That said, I had an Odyssey Group 34 battery that I ran without one of these for well over a year and I would simply plug it into the wall (overnight) with an AC-DC charger once every couple of weeks (sometimes once a month) and it worked perfectly fine. I know a lot of folks who don't even do that and have been fine with the AGM though I would recommend some sort of AC charging to get the most capacity and life out of your battery. They are relatively cheap and if it means a healthy battery for 5+ years then that is really a no brainer especially if you take trips where you do end up cycling close to that 50% discharge point.
2019 TRD Off Road| 285x70xR17 Falken WP AT3W| Dobinson C59-314/GS59-700 & C59-505/GS59-701| Total Chaos UCA| RCI front skid plate (steel)| C4 Fab. Low Pro. Bumper| Extreme LED Light Bar (bumper)| Baja Designs Squadron Sport Fog Lights (Amber)| Bud Built Ultimate Rock Sliders| Front Runner slimline II full-size Roof Rack with Wind Fairing| C4 Fab Summit Hatch Ladder| ARB CKMA12 Air Compressor| Xenon Depot HID Low Beam Head Lights|Renogy-20 Amp DC-DC Charger|Battle Born LiFePO4 Auxiliary Battery| Goose Gear rear drawer system (8")|National Luna 52L Legacy Fridge/Freezer| Alu-Cab tilting fridge slide (Small/Medium)| ROAM Adventure 8' Awning
bring_it_on is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 10:19 AM #3
Ripper238's Avatar
Ripper238's Avatar
Since i don't have AC in my garage (and that part is on B/O) do you think a battery tender like the NOCO GENIUSS is good enough long term?
Old 06-11-2021, 11:11 AM #4
If you don't have a 110 outlet in your Garage you should probably buy on of the VB devices. I have a similar situation as I park in an underground garage and don't currently have access to a power source. VB means that I don't have to take the battery into my condo to charge it periodically.
Old 06-19-2021, 06:04 PM #5
Ripper238's Avatar
Ripper238's Avatar
Think i found the Odyssey model, apparently they are at Autozone: https://www.autozone.com/batteries-s...cca/411930_0_0
It also appears the stock size 24F Odyssey has more amp hours than the 34? Why would i go 34?
Extreme Series Battery Specifications | ODYSSEY(R) Battery
Old 07-12-2021, 01:21 PM #6
Ripper238's Avatar
Ripper238's Avatar
Guess it looks like ill be going with a 24F. Even there website says it will fit.
Old 07-12-2021, 06:56 PM #7
Rack Rack is offline
Rack has a spectacular aura about Rack has a spectacular aura about
Get the 34R with the adapter. It fits perfectly no mod needed.
signature not available
Rack is offline   Reply With QuoteReply With Quote
Old 07-16-2021, 01:21 PM #8
Ripper238's Avatar
Ripper238's Avatar
I was ready to but then it appears the 24F has more capacity and is a direct fit with no mod needed according to the Autozone guys.
Now i am confused. lol
Old 07-16-2021, 08:27 PM #9
Either one will work. but the 24-F weighs more.
Can't go wrong with a odyssey Battery.
Old 01-11-2022, 12:11 PM #10
Ripper238's Avatar
Ripper238's Avatar
Ok, its time. With temps in the teens and me wanting to be proactive ill be getting a new battery to replace the stock battery from 2019.
Ill be going to get a Odyssey Battery 34-PC1500T Group Size 34 850 CCA if no-one else has another suggestion of the best cranking high capacity battery for my usage as noted in OP.
It also appears no-one has this in stock.........
Old 01-11-2022, 01:18 PM #11
Ripper238's Avatar
Ripper238's Avatar
Well no one had that so I ordered a Odyssey ODP-AGM24F ill be swapping in tomorrow!
Old 01-14-2022, 10:40 AM #12
Ripper238's Avatar
Ripper238's Avatar
Well installed the Odyssey ODP-AGM24F. Wow does my 4Runner turn over fast.... Higher voltage sitting for hours too.
Almost makes me worried it turns over with so much gusto!! lol
Still curious 34 vs 24.
Old 01-19-2022, 11:01 PM #13
Gclark949's Avatar
Gclark949 Gclark949 is offline
Gclark949 will become famous soon enough
Gclark949's Avatar
The voltage booster fuse thing is totally safe. Been using it for years without any issues.
2016 Trail Edition Premium, Silver with KDSS, 2.5 King lift, T13 rear springs, FN Six Shooter with ST Maxx, BB Skids
Gclark949 is offline   Reply With QuoteReply With Quote
Old 01-21-2022, 03:17 PM #14
Ripper238's Avatar
Ripper238's Avatar
That's good to know. I think i am just going to run it with out one and see how it goes. I drive 2 hours evry day to work so i would think that would keep it going.
I also got a NOCO GENIUS5 5 to top it off before big trips. Just not sure if i should leave the battery connected while using the NOCO battery tender/charger.
Old 01-21-2022, 09:22 PM #15
Check the chargers owners manual to make sure it can be used on AGM batteries
Also there is no reason to disconnect the battery when charging.
See if your charger has the quick connect plug instead of the alligator clips.
These attach to the battery terminal bolts and makes it easier to just plug in the charger.
Most chargers come with these.
agm , battery , booster , things , voltage
Time for a new battery message 4th Gen T4Rs 40 05-21-2017 03:15 PM
Battery Time!! THe original battery in my 04 is getting a little slow... Jeff T 4th Gen T4Rs 38 12-22-2011 10:04 PM
What additional parts, if any, are needed when replacing shocks and springs? jamess 3rd gen T4Rs 2 05-18-2010 12:45 PM
new battery time! NDRYDEN123 4th Gen T4Rs 18 07-15-2009 02:54 PM
Time for a new battery.... SofaRider 4th Gen T4Rs 11 05-31-2006 09:35 AM
