Old 06-11-2021, 07:39 PM #1
Chilow Chilow is offline
Chilow will become famous soon enough
Inner Tie Rod Boot Leak
Was looking under the rig today and noticed the passenger side inner tie rod boot was showing signs of some sort of leak. The driver side was completely dry. What should I be checking or replacing?
Inner Tie Rod Boot Leak-663e6291-7d1c-4b26-8ac9-8e43a26e4a86-jpg
Chilow is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 08:21 PM #2
spartacus's Avatar
spartacus's Avatar
Check the ps fluid reservoir to see how much ATF fluid you are loosing. If it's negligible loss then i'would just drive it but if its leaking to the ground and you can see spots then it's time for a rebuild rack or have your rack rebuild with new seals. It's an expensive part to replace. My 3rd gen has had a leak sâme as yours for a year now and it's been fine.
Old 06-11-2021, 11:33 PM #3
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold Xtremluck is a splendid one to behold
Xtremluck's Avatar
I hate to be the bearer of bad news but your steering rack is failing. If you pull that cover I guarantee you will have a ton of PS fluid spill out. Its not going to be a cheap fix but you can DIY if you want to save some $$
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
Xtremluck is offline   Reply With QuoteReply With Quote
Old 06-11-2021, 11:56 PM #4
Jeremy556's Avatar
Jeremy556's Avatar
Yep, looks like your rack is leaking, which will require replacement. It would be worth your while to check for a leak above the rack, dripping down on to it.
MSRP (in 2012) on the rack is $915 and 2.8 hours labor to R&R. I bought one as a spare a few years ago and it was around $700, IIRC. The hours quoted seem low when perusing the service manual replacement procedure.
boot , leak , rod , side , tie
Outer CV boot Leak airbur 4th Gen T4Rs 6 07-15-2018 09:06 AM
Upper ball joint boot leak—replace UBJs or just boot kit? starclassic 3rd gen T4Rs 4 07-31-2016 02:50 AM
Another cv boot leak thread o-evets 4th Gen T4Rs 30 11-18-2011 10:22 AM
Help! CV boot leak T4RArmorLT 3rd gen T4Rs 4 08-01-2011 01:00 PM
