Old 06-12-2021, 09:05 PM #1
AZ_Trails's Avatar
AZ_Trails AZ_Trails is offline
AZ_Trails is on a distinguished road
AZ_Trails's Avatar
Help Identifying Rubber Part
Found this random rubber part sitting under the front end of my 4Runner this afternoon. Seems like it could be used to drain something, but couldn’t figure out where it came from.
Can anyone help identify where this goes?
2018 Toyota 4Runner TRD Off Road Premium
Mostly Stock...TRD Pro Grill & Valences, 265/70R17 KO2s on TRD Pro Wheels, Toyota Rock Rails
2000 Toyota 4Runner SR5 4WD 5-Speed
Sonoran Steel 1.2 w/ OME 861s, 4.56 Gears w/ ARB Front & E-Locker Rear, AOR Front, CBI Rear, 285/75R16 KO2s, Custom Full Length Rack, BudBuilt Skids, Lil' Skip's Gas Tank Skid, Savage Sliders
AZ_Trails is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 01:53 PM #2
TOYO74's Avatar
TOYO74 TOYO74 is offline
TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about TOYO74 has a spectacular aura about
TOYO74's Avatar
Looks like a broken off radiator drain plug . Had you coolant changed recently? Take a look at this:
https://www.autozone.com/cooling-hea...136/102857_0_0
AutoZone
Dorman Radiator Drain Plug 61136
TOYO74 is offline   Reply With QuoteReply With Quote
Old 06-13-2021, 06:45 PM #3
AZ_Trails's Avatar
AZ_Trails's Avatar
AutoZone
The piece is soft rubber, so thankfully doesn’t look like it broke off. Didn’t see anywhere obvious where it would go on the radiator…any thoughts?
Old 06-13-2021, 09:10 PM #4
TOYO74's Avatar
TOYO74's Avatar
The photo of it looks like the Dorman radiator plug, but those are hard plastic. Sorry for the bad lead.
Being soft rubber, I doubt it plugs anything that is pressurized. Have you done any work in engine bay recently?
Old 06-13-2021, 09:51 PM #5
Jeremy556's Avatar
Jeremy556's Avatar
There are several body drain holes that use that plug. 1 behind each rear wheel behind the plastic bodywork, I'm not sure where else.
Old 06-16-2021, 05:22 PM #6
AZ_Trails's Avatar
AZ_Trails's Avatar
Awesome lead, thank you. I’ll investigate.
figure , found , identify , part , rubber
Need help identifying a rubber part Outrider 3rd gen T4Rs 10 10-16-2018 03:51 PM
Help Identifying this Part SidKo 5th gen T4Rs 4 12-12-2017 11:50 PM
Need help identifying a part jumpman86 4th Gen T4Rs 5 06-24-2015 01:57 PM
help identifying a part jaybiRRd 3rd gen T4Rs 2 06-17-2012 02:59 PM
Can anyone help identifying this part???? srq5000 4th Gen T4Rs 4 11-11-2010 05:21 PM
