Old 06-14-2021, 09:20 PM #1
mkivalex mkivalex is offline
mkivalex is on a distinguished road
2020 illumination wiring on windshield warmer switch colours
I am trying to install an AOB switch in my 2020 for front lighting and I am trying to hook up for illumination but the wiring on my windshield warmer switch do not match up with what I've read online (green and gray wires)
I have
BLACK
Red
Green
White
Yellow
Has this changed for newer 4runners? Any help would be appreciated
Also. If I don't hook.up illumination do AOB switches just stay lit up all the time?
mkivalex is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 03:26 AM #2
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
I have
BLACK
Red
Green
White
Yellow
I don't know if they've changed wiring on newer models, but what I can tell you is that I've never hooked any of my switches up to illumination. The way my switches operate is they only illuminate if I push them on. Otherwise they are off. Only thing that's kind of a pain is when driving at night, the switches are not lit up to match the dash lights lighting up when you turn on the headlights. So at night I can't see my aftermarket switches, but it's not that big of a deal because I know exactly where they all are and don't even have to look.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 03:59 AM #3
Saker's Avatar
Saker Saker is offline
Saker's Avatar
I have
BLACK
Red
Green
White
Yellow
Here is what I did when installing Raptor Lights.
White wire is the illumination wire.
Best Regards,
Saker
Old 06-15-2021, 05:26 PM #4
Thank you! That's exactly what I was looking for.
And you had no issues when hooked up this way? I've read of people having electrical issues when hooking it up wrong and that is the last thing I need!
Old 06-15-2021, 08:25 PM #5
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Also depends if the aob switch supports backlight illumination and indication.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 08:54 PM #6
Saker's Avatar
Saker's Avatar
Absolutely no issues.
I always test the circuit before making the connection.
The color code on the wiring changed from my 2014 to the 2021 models on that illumination circuit.
@daytonaviolet ,
The AOB switch supports backlight illumination and indication on the ones I use.
If it is supposed to illuminate when the parking lights are on and supposed to illuminate when the device it’s terminated to is turned on, then he’s good to go.
Best Regards,
Saker
Old 06-15-2021, 08:57 PM #7
Saker's Avatar
Saker's Avatar
I assume you are running your circuit thru a relay, correct?
If not, I strongly recommend it!
Best Regards,
Saker
Old 06-16-2021, 03:15 PM #8
Thank you for the info! and Yes I have a relay in there, I am in the ACC fuse spot so I will be changing the fuse in the Add a fuse to 7.5A from the 10A that it came with.
I will probably wire up the illumination wires tonight, thanks again.
aob , green , illumination , switch , warmer
DIY: Factory E-Locker Switch Illumination Killer Squirrel 3rd gen T4Rs 9 08-23-2022 01:17 AM
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 11 10-23-2021 03:51 PM
12Volt Guy elocker harness wiring/illumination Q WeakSauz 3rd gen T4Rs 4 10-11-2020 10:20 AM
Wiring- where can I tap in for dash illumination? nytosc 4th Gen T4Rs 2 02-09-2018 07:57 PM
Light switch illumination headache! kolelt 3rd gen T4Rs 8 04-10-2016 01:19 AM
