Old 06-14-2021, 09:20 PM #1
mkivalex mkivalex is offline
mkivalex is on a distinguished road
2020 illumination wiring on windshield warmer switch colours
I am trying to install an AOB switch in my 2020 for front lighting and I am trying to hook up for illumination but the wiring on my windshield warmer switch do not match up with what I've read online (green and gray wires)
I have
BLACK
Red
Green
White
Yellow
Has this changed for newer 4runners? Any help would be appreciated
Also. If I don't hook.up illumination do AOB switches just stay lit up all the time?
mkivalex is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 03:26 AM #2
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie has a spectacular aura about Kamalani Mahie has a spectacular aura about Kamalani Mahie has a spectacular aura about
I have
BLACK
Red
Green
White
Yellow
I don't know if they've changed wiring on newer models, but what I can tell you is that I've never hooked any of my switches up to illumination. The way my switches operate is they only illuminate if I push them on. Otherwise they are off. Only thing that's kind of a pain is when driving at night, the switches are not lit up to match the dash lights lighting up when you turn on the headlights. So at night I can't see my aftermarket switches, but it's not that big of a deal because I know exactly where they all are and don't even have to look.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 03:59 AM #3
Saker's Avatar
Saker Saker is offline
Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold Saker is a splendid one to behold
Saker's Avatar
I have
BLACK
Red
Green
White
Yellow
Here is what I did when installing Raptor Lights.
White wire is the illumination wire.
Best Regards,
Saker
2021 T4R *MIDNIGHT BLACK METALLIC* TRD OFF ROAD PREMIUM 4X4| Sakerís Ebony Build | Sakerís Previous 2014 Midnight Build | Scuba Mod | LED LIGHT BAR INSTALL | Saker's EBRs Photos Updated 05-21-16| Saker's Previous 2013 FJ TT/SE
Old 06-15-2021, 05:26 PM #4
Thank you! That's exactly what I was looking for.
And you had no issues when hooked up this way? I've read of people having electrical issues when hooking it up wrong and that is the last thing I need!
Old 06-15-2021, 08:25 PM #5
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all daytonaviolet is a name known to all
Also depends if the aob switch supports backlight illumination and indication.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 08:54 PM #6
Saker's Avatar
Saker's Avatar
Absolutely no issues.
I always test the circuit before making the connection.
The color code on the wiring changed from my 2014 to the 2021 models on that illumination circuit.
@daytonaviolet ,
The AOB switch supports backlight illumination and indication on the ones I use.
If it is supposed to illuminate when the parking lights are on and supposed to illuminate when the device itís terminated to is turned on, then heís good to go.
Best Regards,
Saker
Old 06-15-2021, 08:57 PM #7
Saker's Avatar
Saker's Avatar
I assume you are running your circuit thru a relay, correct?
If not, I strongly recommend it!
Best Regards,
Saker
Old 06-16-2021, 03:15 PM #8
Thank you for the info! and Yes I have a relay in there, I am in the ACC fuse spot so I will be changing the fuse in the Add a fuse to 7.5A from the 10A that it came with.
I will probably wire up the illumination wires tonight, thanks again.
aob , green , illumination , switch , warmer
12Volt Guy elocker harness wiring/illumination Q WeakSauz 3rd gen T4Rs 4 10-11-2020 10:20 AM
DIY: Factory E-Locker Switch Illumination Killer Squirrel 3rd gen T4Rs 8 06-24-2019 06:00 PM
Wiring- where can I tap in for dash illumination? nytosc 4th Gen T4Rs 2 02-09-2018 07:57 PM
AOB Switch Illumination Issue QUESTION/Trouble With Switch Fully Engaging FIX mbumpus11 5th gen T4Rs 10 12-14-2016 12:19 AM
Light switch illumination headache! kolelt 3rd gen T4Rs 8 04-10-2016 01:19 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
