Old 06-14-2021, 10:51 PM #1
vjack vjack is offline
vjack is on a distinguished road
1000 watt inverter w/ a 2016... will the alternator keep up?
I want to run a 1000 watt load off an inverter at a job site. I have one of those inverters that comes with jumper cables to run right off the battery but now I'm wondering if the alternator will be able to keep up. How much will the alternator put out at idle (or will the vehicle rev up if need be?) By my math a 1000 watt load is going to be ~80 amps.
I may be running it for a few hours so it would be a problem if I was slowly draining the 4Runner's battery.
Ideally I would have a small generator for this but it's not going to happen on short notice.
2016 4Runner Limited 4x4
vjack is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 11:37 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
I doubt that you will be using all the 1000 watt constantly on a construction site, that is if you are using power tools (drills, saws, etc), they are used for a few minutes then the are off for a while. Thus, there will be no problem. Also, I doubt you will be using all the 1000 watts. Most power tools are far less than than that.
The car will not automatically rev up if the alternator cannot keep up with the load; you would have to do that manually which I doubt you want to do.
You might want to get a voltmeter and check the voltage from time to time. You can get some that plug into the cigarette lighter socket. If the voltage is constantly below 12 volts, the alternator is not keeping up.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 11:42 PM #3
Sagacity Sagacity is offline
Real Name: Greg
Sagacity is on a distinguished road
Real Name: Greg
Following. I'm also interested in a good tire compressor if anyone wants to chime in.
2016 T4R Trail edition, KDSS, still stock except for 265/70-R17 KO2's
WRECKED: 2000 T4R SR-5, 300,000 miles. State Farm gave me almost $10k!
Sagacity is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 03:08 AM #4
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
I like this tire compressor:
STEEL Vs. ALLOY WHEELS Which One Is Stronger? Hydraulic Press Test! - YouTube
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 06-15-2021, 08:26 AM #5
I omitted the boring details but yes it is a 1000 watt load (8 amps @ 120v) and yes it will be running constantly. Not a power hand tool. So I do need to know at least the ballpark of what output I can expect from the 4Runner's alternator.
I do have a multimeter so that's a good idea of checking on it periodically so at least I don't end up with a dead battery.
Old 06-15-2021, 10:57 AM #6
Have you looked through this thread?: Getting more current from your stock alternator at idle
Old 06-16-2021, 10:30 AM #7
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
i have the high flow compressor which i really like. i used the small cheap ones before and man, i was pumping my tire for 40 minutes after i went to the beach. lol. if you need to buy one, get the high flow one, just like what i have here. Smittybilt Tire Pump and Fridge mods using a powerpole connector instead of the cigarette outlet - YouTube
4r-4ever is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 08:05 PM #8
I did see that thread, but if you're going to go to al the trouble to get the accessory belt off and get a custom pulley for the alternator I would rather just get a HO alternate and not worry about running a stock one at 150% of its expected RPMs.
I'm really just asking what is the usable amps I can get from the stock alternator at idle, after the vehicle has taken what it needs to run the ECU etc.
alternator , inverter , load , run , watt
800 Watt inverter 1,600 peak questions SnakZ All Other Vehicles 0 04-13-2015 11:15 AM
450 watt margarita machine on inverter? Glenn_Law 5th gen T4Rs 8 08-23-2012 10:30 AM
1000 Watt Power Inverter TN_Soljah808 For Sale: Non-T4R Items 0 02-17-2012 03:28 PM
400 Watt Power Inverter for $5 MICA4R 4th Gen T4Rs 0 10-30-2011 10:45 PM
Black & Decker 750 Watt Power Inverter probwhite Classifieds - buy & sell (no commercial ads please) 0 12-09-2007 03:37 PM
