Old 06-16-2021, 09:24 PM #16
mmike87 mmike87 is offline
mmike87 is on a distinguished road
I thought I was the only one ... Dipstick blues. LOL
Sent from my SM-N986U using Tapatalk
mmike87 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 10:30 PM #17
Saker's Avatar
Saker Saker is offline
Saker's Avatar
Wow, this is right up at the top along with real world problems !
Never had any issues reading oil level on the dipstick of my 14’, no issues yet on my 21’.
One side will have a smear, the other side will read correctly.
Just rotate the dipstick to see where the level falls in regards to the full mark.
It’s really not that hard guys/gals!
YMMV
Best Regards,
Saker
Old 06-16-2021, 10:32 PM #18
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
yeah, there is a smear side and a clear side
5thToy is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 11:09 PM #19
Cndnmax Cndnmax is offline
Cndnmax will become famous soon enough Cndnmax will become famous soon enough
Seriously, it’s horrible. I just did an oil change then pulled the stick out and said wtf is this, There’s oil everywhere lol. I’m assuming it might be easier to read with dirty oil.
My VW has a braided cable with a nice chunk of textured metal at the end. There’s even a centering bead on the cable so that it doesn’t touch the edges. You can read it from 6 ft away if you wanted lol. Which is probably a good thing because it burns oil like crazy lol.
Cndnmax is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 11:34 PM #20
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Originally Posted by Cndnmax View Post
Seriously, it’s horrible. I just did an oil change then pulled the stick out and said wtf is this, There’s oil everywhere lol. I’m assuming it might be easier to read with dirty oil...
I pull my dipstick and lay it flat on a paper towel, then slide it sideways to rub the oil onto the towel. I can then see where the oil level on the towel and match it against the dipstick.
Is there some sort of dye that could be added to the thin synthetic?
Old Tanker is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 12:05 AM #21
TechBob TechBob is offline
Real Name: Bob Candelmo
TechBob is on a distinguished road
Wink
Originally Posted by dcjeeper View Post
Are there any aftermarket dipsticks available? 4Runner’s dipstick is so poor designed that every time I check the oil level, I have to pull it out and wait for at least 10 minutes then insert it into the tube to get the correct level. Really annoying. My MB ‘s dipstick is so much better even with synthetic oil.
Mine got so rusted (dipstick tube) I could no longer pull the dipstick out and once out was not able to put all the way back in, even with fresh grease on the O-ring. Advanceautoparts.com had the dipstick tube and dipstick for a reasonable price. They are identical to the original Toyota parts
TechBob is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 11:37 AM #22
4wheeldrivesmatter 4wheeldrivesmatter is offline
4wheeldrivesmatter is on a distinguished road
Hello Everyone,
kind of experiencing the same issue on my 2021 4unner's dipstick
I performed an oil change with the oil filter and added back the 6.6qts. after checking, the engine oil level shows really high on the dipstick. I am on level'd ground. I ended up taking about .8 qts out and kept checking over and over and it still shows really high
I did end up taking out the dipstick, cleaning it, waiting about 15 mins and checking it that one time did show the oil was in the middle of the 2 dimples on the dipstick but each time checking it right away immediately showed it was overfilled again
is this really the workaround to getting an accurate reading on the dipsticks? waiting 5+ mins, taking out dipstick, waiting about 15 mins+, reinsert, pull out and check?
thanks everyone
4wheeldrivesmatter is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 12:04 PM #23
Whippersnapper02's Avatar
Originally Posted by 4wheeldrivesmatter View Post
Hello Everyone,
thanks everyone
You can try scuffing the stick between the dots but no real fix since this engine came out in 2005.
Old 07-20-2021, 02:03 PM #24
might not be a bad idea
thank you!
Old 07-20-2021, 03:10 PM #25
Frasher4Runner's Avatar
Frasher4Runner Frasher4Runner is offline
Frasher4Runner is on a distinguished road
YMMV
Reading an oil level isn't hard, you're right. BUT in the 30+ years I've been checking oil levels, I've never had as much trouble as I do with the 4Runner. I agree with everyone who's stated they've had trouble - it's just one big smear, on both sides of the stick. YMMV
Frasher4Runner is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 06:16 PM #26
Fareastplaza Fareastplaza is offline
Fareastplaza is on a distinguished road
The easiest way to improve this is to sand the end of dipstick so the attached oil can be seen better.
Fareastplaza is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 07:41 PM #27
I have no problem seeing the oil - it’s all up and down the dipstick!
Sent from my iPhone using Tapatalk Pro
Old 07-20-2021, 08:45 PM #28
fourrunnerbill fourrunnerbill is offline
fourrunnerbill is on a distinguished road
just like someone else posted, I also discovered the best method is to don't remove the dip stick and wipe it and reinsert and take the reading. Just check once after letting the vehicle sit for awhile (over night even better) and just take one reading. I always get a very clear mark of the oil level this way.
fourrunnerbill is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 10:07 PM #29
That’s also a good way of getting a reading
I sure am glad I found this post. I was stressing over this simple oil change
Old 03-01-2022, 10:58 AM #30
krravi krravi is offline
krravi is on a distinguished road
My previous 2007 4runner I believe had a dip stick with bright orange hard plastic on the end with a cross hatch pattern that held the oil. Was very easy to read.
It could be have been a Honda Accord too not sure. Wonder if there are after market dipsticks with a cross hatch pattern on it.
krravi is offline   Reply With QuoteReply With Quote
dipstick , level , minutes , oil , tube
How much oil can a dipstick pump get? Johncmng 5th gen T4Rs 31 06-17-2018 12:29 PM
Oil Dipstick 934x4 5th gen T4Rs 8 10-11-2015 09:15 PM
Oil Dipstick sonerick 4th Gen T4Rs 2 03-09-2011 04:24 PM
Oil Dipstick?? FowerRunner 4th Gen T4Rs 2 11-08-2009 09:33 PM
Tranny dipstick jetboy1975 4th Gen T4Rs 2 04-28-2009 06:13 PM
