05-03-2020, 04:01 PM
Removal of Painted Pin Stripes?
Hello - Purchased 4-Runner new (14) and dealer had painted pinstripes as part of a package. Okay with look but a few areas have been dinged / washed away.
Have searched all over and there does not seem to be a clear (safe) removal method. Have seen people recommending Acetone, Lacquer Thinner, Oven Cleaner, and Wet Sanding.
What is the safest method in order to not damage car clear coat and paint. Willing to pay a shop if necessary.
Thanks!
05-03-2020, 04:34 PM
Disclaimer: I'm not a professional etc... try this on your own and don't come to me if it damages something.
If they are just stickers, you might try a hair dryer or heat gun. With that said, if you use a heat gun you can cook your paint pretty bad, so start low and move up.
YouTube
If they are flaking off, a buffer wheel might just knock them off too.
What you might see after you remove them is your original non-faded pain color and have a new pin stripe.
05-03-2020, 04:41 PM
YouTube
Thanks, but these are painted.
05-03-2020, 08:29 PM
Probably depends on what they used and if the paint had hardener in it. You can try lacquer thinner and slowly wipe it on without putting too much pressure on it. It will be a long process if it works. Would be a good idea to put a buffer on it afterwards.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
05-03-2020, 09:11 PM
Heat gun is good idea even for painted stripes because it'll soften that material. If you have small detail polisher it will take no time to level this down to paint with just some polish and yellow pad. Be careful not to burn trough original clear coat under that stripe. G.L.
05-03-2020, 10:38 PM
I have seen these exact pinstripes put on a camry. It’s a decal/sticker, not painted. Maybe they told you it was painted. Did you buy from the HB dealer that sold the barcelona red pro to the other guy?
When you have to shoot, shoot....don't talk.
#black4runnersmatter #myprodoesntclunk
05-04-2020, 06:17 AM
Rubber wheel with finesse
05-04-2020, 08:29 AM
Thanks
Have tried a polisher and compound, little result.
Originally Posted by jbtvt
Have seen the wheels work magic on vinyl.
Definitely painted, I have removed some. You can also feel the difference between a vinyl type stripe and paint.
Have seen these work on vinyl but not anywhere online for paint.
05-04-2020, 08:54 AM
Definitely not painted. Like others above said, you can use a heat gun or wait for a pretty warm day in conjunction with a heat gun and they should peel right of with little to no effort. Pin striping to me is such old school graphics. I hate the way it looks on a modern vehicle...just my $.02
2021 4Runner TRD ORP: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 265-70R17 tires.
05-04-2020, 10:10 AM
He insists they are painted. He could be right but I highly doubt a dealer would take the time to paint a pinstripe like that unless they added some giant ass markup for it. Also as I mentioned earlier, I have watched them apply these pinstripes on a camry before and it looks exactly the same.
05-04-2020, 11:49 AM
Real Name: Sparky
Real Name: Sparky
I find it hard to believe that the original dealer hired a pin stripe guy who can paint them (a dying breed) to paint boring parallel stripes on your 4Runner when nearly 100% of these vinyl appliques are done badly by some idiot they don't trust in the sales or service departments.
Old and (c)rusty.
05-04-2020, 11:54 AM
I’d be shocked if they’re painted as well. That’s a pretty uncommon practice these days. No way a dealer will pay that as mentioned without a huge markup. IF they are painted, lacquer thinner should take it off without affecting the clear. I have used lacquer thinner countless times on touch up paint on multiple vehicles. They clear is very resistant to it. The edges on vinyl will be super clean and not that way painted.
2020 Nautical Blue ORP ADS suspension, Icon Deltas, FN Pro wheels, Ridge Grapplers, CBI skids....
05-04-2020, 11:55 AM
I have used the rubber wheel. Works on vinyl pin stripes, not paint.
05-04-2020, 11:57 AM
Banned
Real Name: Mark
Banned
Real Name: Mark
I haven’t seen painted pin stripes in years, only at a classic car show. A vinyl stripe usually wraps around the door edge where you can start peeling it off. Try a hair dryer to heat it up.
