Old 06-17-2021, 08:46 PM #1
tommyjay17's Avatar
tommyjay17 tommyjay17 is offline
tommyjay17 is on a distinguished road
tommyjay17's Avatar
Are 5th Gen Factory Struts Side Specific? (Front)
I was wondering if the front factory struts (entire assembly) on a 2011 SR5 are side specific, or interchangeable? I’ve tried a lot of ‘Googling’, but can’t seem to find a direct answer. I’m having trouble getting it aligned after installing the Daystar 2.5/1.5 leveling kit, and wondering if the struts were possibly installed on the wrong side? And if so, could that explain the alignment issues? Thanks in advance Are 5th Gen Factory Struts Side Specific? (Front)
2003 V6 SR5 4WD Titanium Metallic - Clazzio Leather Seat Covers - Interior LEDs - Husky Liner Mats - Curt Extended Roof Basket - Otto Navi HU - Rampage Receiver Hitch - Daystar 2.5"/1.5" Lift - AFE CAI Stage 2 - Spidertrax 1.25" Wheel Spacers - 6.5' Awning - Gibson Cat-back Exhaust - 265/70R17 Falken Wildpeak A/T3W - RIP
2011 V6 SR5 - Bought stock in May 2021....so the fun begins
tommyjay17 is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 09:04 PM #2
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
The front shocks are not left/right specific. 4Runners have a tendency to sit lower on the left side due to the driver, battery and gas tank all being on that side, but that's a spring length or rate issue.
edit: I realized my response might be pedantic and possibly confusing as I don't refer to them as struts. The shocks themselves won't care which side they are on, but the spring they are paired with may be different from left to right. I'm not 100% sure about that.
5thToy is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 09:25 PM #3
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
I don’t think so, but the ones with adjustable perches may need to be set higher on drivers side. This is to compensate for drivers side lean.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 06-17-2021, 10:26 PM #4
tommyjay17's Avatar
tommyjay17's Avatar
I’m referring to the entire assembly (front shock and coil) - sorry if I didn’t explain that accurately in the post. Both front assemblies were removed, and the spacer mounted on top. If the drivers side assembly were accidentally relocated on the passengers side (and vice versa), could this affect an alignment (if they are indeed side specific)? I’m trying to eliminate it as a factor in my shop having trouble aligning it, or if I need to consider something else as the source of the problem (maybe they just aren’t good at alignments). Thanks again Are 5th Gen Factory Struts Side Specific? (Front)
Old 06-18-2021, 11:29 AM #5
Javin028 Javin028 is offline
Javin028 will become famous soon enough
The struts aren't left/right specific, but the springs are.
Apollo X
2016 4Runner Trail w/ KDSS - Super White
Bilstein 8112/8100 |
Javin028 is offline   Reply With QuoteReply With Quote
Old 06-18-2021, 11:55 AM #6
tommyjay17's Avatar
tommyjay17's Avatar
Thanks for the response! Do you have any idea if the alignment would be tough if the springs were indeed on the wrong side? The shop I’m dealing with is saying they’re having trouble aligning it, without giving me any indication why. I think it might be time to bring it somewhere else either way - my frustration is maxed out. It’s been there for a week!
Old 06-19-2021, 02:46 PM #7
It’s possible the different heights of the springs are causing alignment issues. The springs have paint markings to identify each one. I’m not sure how accurate this site is, but hopefully it helps:
Toyota Spring Codes - Chi Town 4x4
Apollo X
Old 06-20-2021, 01:37 PM #8
tommyjay17's Avatar
tommyjay17's Avatar
Thanks for passing that along! I’ll go take a look to see - I finally got it back yesterday. After a second try, they were able to get everything within spec. - but it’s pulling to the right slightly. Thanks again
Old 06-20-2021, 01:52 PM #9
Saker's Avatar
Saker Saker is offline
Saker's Avatar
The chart has the correct color code for the springs.
If you notice the coils on one side are closer together than the other.
FWIW, your truck shouldn’t pull if the alignment is good!
Best Regards,
Saker
Old 06-20-2021, 08:35 PM #10
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
If the tires wore unevenly due to the alignment being off for too long, the Alignment could be spot-on, and you might still feel a pull. Or some tires exhibit radial pull even from new. It is a tire defect, and can cause a pull.
02SE is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 08:56 PM #11
Saker's Avatar
Saker's Avatar
You are definitely correct.
I was assuming tires were good & only addressing the mentioned situation.
Best Regards,
Saker
front , side , specific , struts , wondering
Are OME 880s side specific? RumHam26 3rd gen T4Rs 11 05-24-2021 05:46 PM
WTB low mileage Factory OEM front Springs/Struts complete 4th Gen NCSCOTT For Sale: Suspension/Wheels/Tires 5 02-24-2014 11:18 AM
Wtb: factory top hats for front struts 02gtfromky Want to Buy/Trade 0 11-17-2013 10:25 PM
FS: Factory front 2000 Limited springs with new oem struts MichaelFuller For Sale: Suspension/Wheels/Tires 0 09-30-2011 11:25 AM
WTB : 3RD Gen Front Driver side Spring/Struts Assembly Runner13 Classifieds - buy & sell (no commercial ads please) 0 08-12-2009 04:35 PM
