Old 06-19-2021, 12:23 PM #1
klone217 klone217 is offline
klone217 is on a distinguished road
Lights Wiring
I need help! Anybody know to wire a dual switch to 2 sets of Baja squadron S2
Lights Wiring-f991503b-e932-4c41-aa21-304fe5304f1f-jpg
klone217 is offline   Reply With QuoteReply With Quote
Old 06-19-2021, 03:24 PM #2
mbumpus11's Avatar
mbumpus11 mbumpus11 is offline
Real Name: Bump
mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about mbumpus11 has a spectacular aura about
mbumpus11's Avatar
Real Name: Bump
Need more context.
Is that a dual switch (meaning one button on top, and one button on bottom)?
What are the individual colors for the switch to each component wire (i.e. is red "for sure" power, black ground, blue accessory, are the yellows backlit switch LEDs?), and how do those line up with the pre-fab switch that comes on the Baha rocker switch?
I just installed Squadron Sport pods on mine, so maybe check out that install write up...I think I covered how the switch wires lined up to an AOB switch...
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
mbumpus11 is offline   Reply With QuoteReply With Quote
Old 06-20-2021, 12:11 AM #3
Originally Posted by mbumpus11 View Post
Need more context.
Yes one on top and one on button
In regards to wire I’m not sure but I saw a picture it looks similar. I’ll attach the picture
Thanks for the reply
Lights Wiring-dd786a74-3086-4939-a9d0-c934c90036f5-jpg  Lights Wiring-3046c7ef-1a77-4771-92c5-9ef49705cde5-jpg
Old 06-20-2021, 11:55 AM #4
Originally Posted by TravThePro View Post
It is a little embarrassing how lazy these Chinese electronics companies have become. You are basically getting sold half of the product you would need to power your light accessories. This "dual LED light switch" is really a dual relay activator. If you tried to use this alone to power the 4 Pods at 12V 7A, the switch would burn up.
They know they are preying on unsuspecting customers. Their lack of instructions and putting "You MUST use a relay" is a way of saving face. These switches are used to trigger a backlight on the buttons when the vehicle is on, to trigger a positive current to activate relay 1 (you have to buy separately), and to trigger a positive current to activate relay 2 (also sold separately).
Rant aside, relays such as this is what you will need to buy to run this in your setup. Amazon.com: 5 Pack 40/30 AMP 12 V DC Waterproof Relay and Harness - Heavy Duty 12 AWG Tinned Copper Wires, 5-PIN SPDT Bosch Style Automotive Relay: Industrial & Scientific
You need 1 if you want to run the entire circuit on 1/2 of the buttons on that switch. You will need 2 if you want to use both buttons.
I don't have my electronics/programming software on this computer, so I will hurry and draw you up a crappy version with good old paint. I'll post it in a second. Turned out like crap haha! I'll pm it to you, just ask me if you have any questions
The squadron comes with cables that has relay built in already (attached picture 1)
And here’s the switch with the 3 wires that came with it.
Lights Wiring-602547b9-15ef-4c76-838e-37ccf4055c7d-jpeg  Lights Wiring-68934afb-985f-4c3f-a226-249da0c4b28f-jpeg
Old 06-22-2021, 01:01 PM #5
_JT_'s Avatar
_JT_ _JT_ is offline
_JT_ is on a distinguished road
_JT_'s Avatar
On the switch that came with your Bajas, each wire should have a symbol where its connected. Generally, switches top to bottom go
1:Red "HOT"
2:White "Relay"
3:Black "Ground".
Not sure how yours came wired, but the above is just a guess based on other wiring toggles I've seen come with wiring kits.
If you're doing two sets, you'd want to do a second wiring kit and relay, and then do the same wiring pattern to the dual switch you would be using. The relay cable is what would differentiate the two.
Looks like Tundra guys have it figured out for a factory switch.
Help with wiring for Baja DesignSquadron to factory switch. | Toyota Tundra Forum
_JT_ is offline   Reply With QuoteReply With Quote
baja , dual , lights , sets , squadron
Need help on wiring reverse lights Park Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-29-2015 07:10 PM
How to: Wiring Aux Reverse Lights TKinstler 4th Gen T4Rs 51 08-23-2015 08:43 PM
Wiring up some lights ... LimitedBlack 3rd gen T4Rs 21 02-09-2015 03:38 PM
Need help wiring reverse lights My06runner 4th Gen T4Rs 2 10-19-2013 11:18 PM
Wiring Lights On the Gobi jangoforhire 5th gen T4Rs 12 08-13-2012 09:53 PM
