06-19-2021, 02:08 PM
Looking for a roof rack solution
OK, I'm a roof rack noob. I don't camp or go off road. I just need a little extra storage space from time to time. Like maybe once or twice a year.
I have a 2018 Limited with the factory roof rail - no cross bars. Ideally, I'd like something not permanent, low profile, functional, that would attach to my existing rack.
Is there any such thing? I've searched, but didn't come up anything current. Any ideas would be welcome.
Thanks in advance!
2018 Limited 4x4, Magnetic Gray/Redwood FN 17" Type X, Mich Defender 265.70.17, LED upgrades (XD Low Beams, DD Turn as Tail, DD Switchbacks, LEDs inside and out), Bully Step, N-FAB Nerf Steps, Front Spacer lift, DR900S-2CH Dashcam, and more...
06-19-2021, 02:26 PM
Thanks in advance!
I just added 2 Victory cross bars to my stock roof rails, i was going to add 3 but decided 2 was fine. I needed very low profile and simple versatility. Perfect option and the standard pre-drilled hole spacing was perfect for my Maxtrax. I may do a platform on it but they work great as a base to add to for now.
4Runner Roof Rack Crossbar | 5th Gen (10+) - Victory 4x4
If you go this rout keep in mind they are sold individually.
06-19-2021, 02:35 PM
Depends on what you will need to place on the roof once or twice a year.
As stated the crossbars/rails will be a simple low profile solution. Probably find factory crossbars for good prices on here as people switch to permanent racks.
If you want something bigger you could do the basket rack that comes on the Pro. I think it is Yakima.
Or a hard/soft storage box/bag to stick stuff in. Will still need the crossbars though.
Ford Explorer - Jeep Liberty Renegade - GMC Yukon Denali - Hummer H2 - Ford Raptor SVT - BMW M6 - Suzuki Jimny - Mazda Demio - Daihatsu Naked - Will Cypha - Toyota 4Runner TRD ORP - Toyota RAV4 Limited Hybrid
06-19-2021, 03:43 PM
The LFD or Victory crossbars are stronger than the side rails themselves and are very low profile. You can mount a basket, a roof bag or even a cargo box on them. It is the simplest solution- the OEM crossbars are pretty weak and kind of flexible.
06-19-2021, 06:29 PM
Thanks for this! For my needs, I think I am going to buy 2-3 of these cross bars, a couple of stormproof bags from ARB, and just strap them down well. Best plan so far, I believe.
06-19-2021, 09:51 PM
Thanks in advance!
What ever you go with for storage, you will need cross bars to start. Avoid the factory cross bars, as mentioned by others; for one, they are too close to the roof and some accessories may scratch the paint on the roof.
I went with the Yakima sky box for storage; it is low profile, aerodynamic, and water resistant. Thule also makes a similar cargo box. Both are easily attached to the cross bars and easy to load and unload.
06-19-2021, 10:04 PM
I also was in your se position with my limited. After a lot of research, I ended up with a yakima skybox 16 on an LFD 3/4 rack. A lot of factors influenced this decision, more than I can write here. However let me know if you have any queations.
06-19-2021, 10:23 PM
Check out NiseRack. Discussed in detail in this thread.
06-20-2021, 12:18 AM
I have a big, lightweight basket I bought from Cabella years ago. It was like 160 new and I got it for like 90 on a Black Friday sale.
That kind of basket is perfect for 1-2/year trips. It may need spray painting to protect from rust but that can be an issue with pricier baskets as well.
Similarly, I have had a big roof cargo box for 9 years now that I bought last minute from Autozone for 250 as I suddenly realized I needed it for a trip. Never felt the need for a pricier one. Currently "lives" on top of my lightweight trailer and keeps getting the job done.
Point is, no need to spend big money on either a basket or a cargo box. Also, cargo box wins hands down for road uses. Unless you need to carry odd shaped objects.
06-20-2021, 03:58 AM
Real Name: BLACK TRD PRO
LFD wide crossbars here. The standard bars with integrated fairing (a must) would suffice. You do not have to remove anything for installation to your oem rails.
06-20-2021, 05:19 PM
Why do you think the faring is a must? I can see how it might help some with wind resistance, but the LFD one is very low profile. Looks better, for sure, but I can't imagine it would help much if I have a couple of those large stormproof bags up on the roof. I'd want taller faring if I were going with a basket, I think. But with this setup, I don't think there's much value.
I may change my mind after a road trip, though.
06-20-2021, 05:56 PM
It cuts down on wind noise dramatically, from what I understand. Most people who got the crossbars early on without the fairing complain about a ton of noise.
06-20-2021, 06:05 PM
It makes a noticeable difference especially when there isn’t anything on the crossbars.
06-20-2021, 06:31 PM
Good to know - thanks!
06-21-2021, 12:12 AM
If you decide to go with crossbars and don't like them for some reason I will buy them from you.
