Old 06-21-2021, 01:41 PM #1
xcalbr2 xcalbr2 is offline
xcalbr2 will become famous soon enough
O2 sensor question
Happy Monday All.
Looking at replacing my O2 sensors - 133xxx on clock and Toyota replaced one under warranty due to a P0031 code.
It says that they replaced the Bank 1 Sensor 1 Air/Fuel ratio sensor.
I am trying to figure out which one they replaced... drivers/passengers ?
I have the other two and was thinking of trying myself due to the 3hrs rate local shop wants for one side - says its very hard to get to.
Any help /suggestions would be appreciated!
Thanks,
X
xcalbr2 is offline   Reply With QuoteReply With Quote
Old 06-21-2021, 11:51 PM #2
fkheath fkheath is offline
fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all fkheath is a name known to all
Originally Posted by xcalbr2 View Post
Happy Monday All.
Thanks,
X
If it is a pain for the dealer to replace, it will be a double pain for you unless you know how to do it. Besides getting to it, they can be frozen and almost impossible to take out. They often need a special tool due to the pigtail wires that come out of them. Then you must use high temp anti-seize on the new one, otherwise it will be impossible to remove in the future.
fkheath is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 12:58 AM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
I haven't changed one on my 4Runner yet, but I have done 3 on my Tundra. They should be easy to locate. Yes, they may be rather hard to get loose - but my Tundra O2 sensors were in there for close to 20 years. You do need a socket with a U cut out of the side to accommodate the wire. Just look for an O2 sensor socket. It's best to get a replacement that already has the connector on the end. You can buy universal ones that you have to splice in. Bosh made the ones I have used with good results.
Old 06-22-2021, 07:50 AM #4
O2
Looking for info on which bank is bank one etc.
Thanks
Old 06-22-2021, 08:06 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Thanks
Look here:
O2 sensor question-o2-jpg
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 06-22-2021, 09:08 PM #6
Bmnorm2 Bmnorm2 is offline
Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough Bmnorm2 is a jewel in the rough
So, bank 1 is passenger side. Bank 2 is drivers side.
Makes sense.. cylinder 1 is passenger side front, cylinder 2 is driver side front.
Bmnorm2 is offline   Reply With QuoteReply With Quote
3hrs , due , replaced , sensor , thinking
02 Sensor question 00runr 3rd gen T4Rs 4 10-30-2010 10:34 AM
02 Sensor Question schoeney 3rd gen T4Rs 3 09-03-2010 06:00 AM
89 o2 sensor question playswithtoys Classic T4Rs 2 07-30-2009 09:53 AM
O2 Sensor Question cat3rn Maintenance/Detailing 1 11-14-2008 04:34 PM
map sensor question Rscud87 Classic T4Rs 1 01-26-2007 01:43 AM
