Originally Posted by 5thToy
I asked these same questions when you posted this on another forum.
Curious, how was head gasket failure confirmed? Wet/dry compression check, milkshake oil, positive test for combustion gas in coolant? Has the engine ever overheated?
Originally Posted by Jeremy556
Fortunately, you should be well within powertrain warranty. Your symptoms don't sound like typical HG symptoms... I don't believe the 1GR has a limp mode, though reduced power from lack of compression may seem similar.
Please follow up with resolution.
I have remote start and when I got into my car that morning it was still freezing cold. When I took my car to the dealership I mentioned the heater wasn’t working so they did a compression check, and ran the codes which said cylinder 3 misfire.
Prior so the blown head gasket, my engine was making a fluttering noise when the engine it’s cold. I felt a reduced amount of power too. I checked the oil, checked the coolant reservoir and it was all fine.
The day I got the check engine light the coolant reservoir way past the full mark.
