06-25-2021, 05:50 PM
Real Name: Tom
Real Name: Tom
Vehicle sag with 200lbs in the roof.
So I have a stock ‘19 TRD Pro and anticipate putting a RTT with a direct mount on top of it. Combined weight should be 200. As I like a stock ride height, how much sag can I expect? Thanks all.
1978 FJ40. Mostly stock, reverse shackle 3 inch lift.
2019 Pro Voodoo Blue
06-25-2021, 05:51 PM
Real Name: Tom
Real Name: Tom
Vehicle sag with 200lbs on the roof.
06-25-2021, 05:57 PM
If it sags, get air bags or stiffer rear coils. I bought a set of air bags a while back, and never installed them. PM me if you're interested... but I'd make sure its an issue first.
Troner envy... the struggle is real!
06-25-2021, 06:26 PM
I doubt it will be much, no difference than me sitting in your back seat. :-) Now with that weight up high above the roof, you will have some more lean in turns.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
06-25-2021, 06:38 PM
What is the allowable static and dynamic roof load?
I'd be more concerned with that than the weight of one average American on the ride height.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6: Gone
06-25-2021, 06:59 PM
Does the tent mount on the Pro rack or by direct mount mount do you mean you are removing the rack and mounting the tent directly on the roof? Not that it would have much affect on your question, I am just curious. As to your question though, just had my family of four and two labs and all our shit for a week in a rooftop cargo box and my mini max BGE and cooler in a hitch carrier and the stock springs sucked
06-25-2021, 08:46 PM
Real Name: Tom
Real Name: Tom
Looking at Alu Cab with load bars on custom brackets that mount directly to the roof, so no need for a roof rack. Keeps weight lower. So do most folks notice quite a difference in driving with weight up there?
06-25-2021, 08:48 PM
Real Name: Tom
Real Name: Tom
Lots of wallowing? Don’t want to sag too much as I am already at stock ride height. Guy at shop thinks it may sag 1/4 inch based on how the setup sits on other 4Runners
06-25-2021, 08:51 PM
Real Name: Tom
Real Name: Tom
Static 300, dynamic 600
06-25-2021, 08:52 PM
Real Name: Tom
Real Name: Tom
Removing the hokey Pro rack then using load bars to custom brackets on roof
06-25-2021, 10:13 PM
200 lbs, plus you need to account for anticipated gear for trips. If you're doing any kind of multi-day trip, you're probably going to have another 200 lbs. in the back, plus people.
06-25-2021, 10:18 PM
Have someone who weighs 200 lbs. set in the back seat and measure the difference.
06-25-2021, 10:25 PM
Or get some sand bags...
06-26-2021, 07:27 AM
200 lbs is not much- when my daughter and dog are in the back seat, it's about 200lbs, and there is little change. When I put my cargo box on top and load it with 100-120 lbs of gear, I notice a change in handling due to the higher COG. You will be fine, just be aware it will change the dynamics a bit with the load up high.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
