08-02-2022, 02:24 PM
#31
Originally Posted by RedRunner_87
This is the tire size I am looking at as well.I currently run 255/80 so it makes sense to step up a little bit to 255/85. Hopefully they become more widely available in the future. Hoping next year I can get a new set of tires.
I just found them at Discount Tire. Should have them by Saturday, installed one day next week.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
08-02-2022, 02:30 PM
#32
Please post some photos when you can. I haven't seen any in that size yet.
08-03-2022, 08:25 AM
#33
That is awesome! I look forward to seeing them installed.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
08-10-2022, 11:24 AM
#34
Just a quick photo from last night after getting them installed. I have to do a bit more trimming now - this size is basically 35"x10".
08-10-2022, 11:27 AM
#35
Whoa! Those look great!
08-10-2022, 04:17 PM
#36
Love the design of these - would actually be decent for mudding as the aggressive side wall would hopefully help with traction. Very cool.
08-10-2022, 05:09 PM
#37
I am excited to hear when people find tires that look and perform well on their 4Runners.
I, while not old, but a curmudgeon nonetheless, am still stuck on the original BFG K/O having the most iconic appearance, both sidewall and tread.
I am not the biggest fan of “swept” sidewall tread, or artsy designs approaching the appearance of flames, etc.
All that having been said, if they come in the sizes and load ratings people want (to push the limits for their ride height without rubbing or serious mods) then I think they’ll win us over.
08-10-2022, 09:52 PM
#38
That looks really good!
5th Gen Build
08-16-2022, 01:42 PM
#39
Of course I gotta ask: all the standard stuff was needed to clear these bad boys? BMC, pinch weld, UCAs …
08-16-2022, 03:09 PM
#40
Yes. My BMC is actually not aggressive enough, so I've just been chopping into the body mount with my angle grinder and clearancing where I see rubbing. I have a bit more plastic to trim out as well, but not nearly as much as with a 315. If I removed the 1.25" wheel spacers, I probably would not need to trim anything and my BMC would have been fine.
But I like the wide stance
08-16-2022, 04:10 PM
#41
What's you Caster set to?
08-16-2022, 04:42 PM
#42
I don't remember exactly 4 or 4.5 degrees. I'm mostly rubbing on the right, which I seem to recall has slightly more caster than the left. If it's at 4.5 degrees, I might be able to bring it down to 4 degrees and eliminate most of the rub.
08-16-2022, 05:04 PM
#43
You would want to increase the Caster to move it away from the body mount. I have mine around 5* which cleared 305's but I don't know about those tires. Like you said I think the wheel spacers are the culprit
08-17-2022, 11:10 AM
#44
I've found that it seems to vary from truck to truck. Too much caster and you start leaning the tire back into the body mount instead of away. But you might be right.
08-18-2022, 07:41 PM
#45
What is your offset?
5th Gen Build
