08-19-2022, 04:05 PM
#46
Originally Posted by RedRunner_87
What is your offset?
TRD Pro wheels (+4mm) with 1.25" spacers, so about -28mm.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
08-20-2022, 10:07 AM
#47
Ok cool. I will be in the -30's when I put my wheels on. -12 plus the 1.25" spacers.
2016 T4R SR5: Ironman FCP w/ Performance Springs l RAV4 Mirrors l TSO Pro Grill l TSO INCOG Front Bumper l Raptor Lights l 255/80 Falken WildPeak AT3W l CaliRaisedLED Ditch Light Brackets l Avid Sliders l Custom Drawers l R1 Concepts Rotors/Pads
5th Gen Build
1996 T4R Limited: E-Locked l 285 KO2's l Toytec BOSS w Superflex l SS Panhard l Ultra Gauge l AIRAID MIT l Drifter CB Mount l AOF Sliders l Weathertech's l Hilux 167 Snorke l Cobra 19DXIV l Ditch Lights l Relentless Front Bumper l Superwinch Tiger Shark l Paranoid Fab Din Switch
08-22-2022, 11:02 AM
#48
I've found that it seems to vary from truck to truck. Too much caster and you start leaning the tire back into the body mount instead of away. But you might be right.
Originally Posted by comtn4x4
You would want to increase the Caster to move it away from the body mount. I have mine around 5* which cleared 305's but I don't know about those tires. Like you said I think the wheel spacers are the culprit
I found my alignment spec sheet from last year and it says front left is 4.5* and front right is 4.4*. I may go and get it aligned again just to make sure the left hasn't wandered.
I hit a concrete culvert in a snow storm 2 winters ago (which the truck drove away from), but I've worried about that left front ever since. something might actually be bent down there.
08-22-2022, 11:10 AM
#49
Yeah I have that happen to me too. I tend to be kind of obsessive about keeping the rig aligned. Rather pay for alignments than trash the tires due to uneven wear. You might see if they can get your caster out a bit more. Might help clear the body mount.
Have you hammered the pinch welds etc?
08-22-2022, 11:25 AM
#50
Yes, the pinch welds are hammered back. I looked down there again and the wheel is actually making contact with the bottom of the wheel well. Only on the right tho. Left wheel is free and clear.
08-22-2022, 02:38 PM
#51
Do you have a picture of how it's rubbing?
08-22-2022, 03:36 PM
#52
Best I can do without taking the wheel off. You can see its rubbing just a touch on the fender flare and down the bottom black trim cap and then you can see the patch on the inner fender where it has rubbed off the rubberized coating I sprayed when I hammered the pinch-weld. You can also see where I notched the body mount (it was already chopped, just not very aggressively) and it is still rubbing just a tad there. I'm thinking about a relocation kit for the body mount.
08-22-2022, 04:12 PM
#53
So it's rubbing like that just daily driving? Have you fully compressed it?
Looks like you've cut it up pretty good. I attached a picture of what I did to mine to get 305/70's to fit. So I'm outta suggestions at this point. My experience is that the wheel spacers make it really hard to get bigger tires to fit without rubbing. Only other thing that worked for me was adjusting caster.
Do you have a front bumper?
08-22-2022, 05:57 PM
#54
Yeah, that is just street driving. I have been intentionally hitting driveways and other bumps mid-turn pretty hard to see what else rubs, because if it rubs on the street, its gonna rub way more on the trail.
I have a SSO lo-profile front bumper with the side protectors. Clearance in the front is a non-issue.
05-31-2023, 11:29 PM
#55
Sidewall Difference
Is the sidewall flatter and less aggressive on the XL versions compared to the LT versions? Hard to tell from the pictures, but I know some manufacturers do that.
2008 4runner SR5 4wd ↟ 2" Dobinsons Suspension Lift ↟ RSG Metalworks Sliders ↟ 265/70r17 Falken Wildpeak AT3W
