Old 06-29-2021, 07:35 PM #31
Dzldust Dzldust is offline
Dzldust is on a distinguished road
Love my Scangauge,this was pulling my camper ,flat ground
High transmission fluid warning light-19a0fb9f-193f-405f-b09a-7f666dd2eb6a-jpg
Dzldust is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 10:37 PM #32
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
Originally Posted by DougR View Post
I can not find a 5th generation engine oil temperature sensor. I searched on Camelback Toyota using the terms "temperature sensor" and "engine oil temperature sensor". I also searched with Google "5th generation 4runner engine oil temperature sensor" and didn't find anything.
Your OBDLink MX+ is showing engine oil temperature 177.8 F which is too low if the engine is fully warmed up. Oil temperature leaving the engine and entering a cooler should be above 212, ideally 220-230 F to evaporate condensation in the crankcase. Your oil temperature is also less than coolant temperature, 186.8 F, which doesn't make sense if this is oil temperature exiting an oil/coolant heat exchanger. Why would Toyota measure coolant or oil temperature at the exit of a radiator or heat exchanger? When a technician wants to perform diagnostics, isn't it better to measure coolant and oil temperature exiting the engine block?
Have you observed an engine oil temperature reading in the 220 to 230 F range?
Only time I seen my oil temps get up in the 220-230’s is in the Rocky Mountains.
I know this little scanner isn’t the perfect fit for everyone’s application but it fit the bill for me. As for how or why the oil temps are the way they are I don’t know, all I know is when I cross reference the oil temps on the scanner with a thermal gun reading the oil pan it’s within an acceptable range for me.
The transmission pan temps are Spot On between the scanner and the thermal gun, the engine oil pan temps can be up to 5-20 degrees hotter than the scanner. But that’s still good info because it gives me a range.
Below are two pics from tonight.
High transmission fluid warning light-4ac51239-868c-43ba-be52-3ff6fbdaf5ee-jpg  High transmission fluid warning light-979d00da-b5d5-4589-aa56-f65e07f0798e-jpg
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 01:19 AM #33
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
Does this one do individual tire PSI display also? Is this the one I should get and is this a fair price? TIA
Amazon.com: ScanGauge - SG2 II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges , Black , 5 Inch: Automotive
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 09:19 AM #34
ahtoxa11 ahtoxa11 is offline
ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about ahtoxa11 has a spectacular aura about
Originally Posted by BobsTrail View Post
With high daytime temps and a steep hill, maybe 4L would be better.
Yep, that's the correct approach. If it requires 4HI and there's a long sustained climb or even a short and steep climb, 4LO is what should be used. Here in CO it's not uncommon to overheat the trans in 4HI offroading.
ahtoxa11 is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 09:23 AM #35
This reminds me to pull out my Scangauge. It's been buried at the bottom of my center console unused since 2 years ago when I sold the Ecoboost F150.
Old 06-30-2021, 10:09 AM #36
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Yup.
ScanGauge Codes
Transmission Temperature (Pan) - 07E02182 046105820000 2808 00090005FFD8 TFT
Transmission Temperature (Torque Convertor) - 07E02182 046105820000 3808 00090005FFD8 TCT
TPMS:
TP1 (PSI) 822AF02138 546180004000 2808 001D0008FF6F TP1
TP2 (PSI) 822AF02138 546180004000 3008 001D0008FF6F TP2
TP3 (PSI) 822AF02138 546180004000 3808 001D0008FF6F TP3
TP4 (PSI) 822AF02138 546180004000 4008 001D0008FF6F TP4
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 10:11 AM #37
1000MPH's Avatar
1000MPH's Avatar
I did find a post but now I can’t remember where that said ScanGauge posted an oil temp code but then deleted it.
Edit: found the post. Unfortunately the person who posted it hasn’t been active here in awhile.
Scan Gauge II Codes..New stuff
Old 06-30-2021, 11:21 AM #38
Originally Posted by 1000MPH View Post
Yup.
ScanGauge Codes
TPMS:
Great. Thank you
Old 06-30-2021, 12:05 PM #39
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
The post you're referring to is number 123 on page 9 of that thread. Travelin wrote, "I have a new 2018 TRD Off Road Premium factory stock and a new ScanGuage II. I programmed X-Guages for trans temp and engine oil temp. The trans temps and the built-in coolant temp read as expected. However I'm puzzled by the engine oil temp reading. I programmed the codes I found on the ScanGuage website as follows:
(ScanGuage has removed the codes for 4Runner engine oil temp, so I have deleted the link. They said although the codes I found are correct and work, they were posted inadvertently and have not yet been publicly released. )
After driving for about an hour at highway speeds the engine oil temp reading on the ScanGuage tracks almost perfectly the transmission fluid temperatures (160 to 170 degrees F). I expected the EOT to be substantially higher."
DougR is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 01:54 PM #40
NotaTRD's Avatar
NotaTRD NotaTRD is offline
NotaTRD will become famous soon enough NotaTRD will become famous soon enough
NotaTRD's Avatar
This is the scan tool I use and I love it, plugs in under the dash and then connects to your phone via Bluetooth. There’s probably 100 different gauges to choose from but these are the ones that I use.
I was out west in March and this thing is a life saver; climbing trails you can get all your temps at a glance.
I’ve been looking for something like this. Thank you
2017 SW SR5
NotaTRD is offline   Reply With QuoteReply With Quote
Old 07-01-2021, 01:44 PM #41
DougR's Avatar
DougR's Avatar
Only time I seen my oil temps get up in the 220-230’s is in the Rocky Mountains ... As for how or why the oil temps are the way they are I don’t know, all I know is when I cross reference the oil temps on the scanner with a thermal gun reading the oil pan it’s within an acceptable range for me. The transmission pan temps are Spot On between the scanner and the thermal gun, the engine oil pan temps can be up to 5-20 degrees hotter than the scanner.
I went to the OBDLink MX+ forum and asked this question, "The 5th generation 4Runner doesn't have a Engine Oil Temperature Sensor and yet there is a Toyota Specific PID that displays Engine Oil Temperature. Is the value calculated? If so, how is it calculated?"
Their reply, "EOT is obtained directly from a sensor, or inferred by a control strategy using other sensor inputs. The Toyota specific PIDs are supplied directly by Toyota and unfortunately, do not come with any explanations."
Apparently, Engine Oil Temperature is a value calculated from other sensor data. Perhaps someone with a TIS subscription may find information about this Toyota specific PID and how it is used by the ECU.
concern , didn’t , high , light , rig
high transmission fluid temperature? rnb754 5th gen T4Rs 22 04-21-2017 02:24 PM
A/T oil temp warning light and battery warning light concern arki01 3rd gen T4Rs 3 05-23-2015 10:45 PM
T4R sold in US doesn't have windsheild washer fluid warning light, right? sunnyside 4th Gen T4Rs 18 02-17-2010 01:17 PM
Low windshield washer fluid warning light Redstone8 4th Gen T4Rs 9 01-24-2009 10:46 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
