Old 06-28-2021, 02:18 PM #16
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 has a spectacular aura about Hammer0313 has a spectacular aura about
Hammer0313's Avatar
Real Name: Buck
This is the scan tool I use and I love it, plugs in under the dash and then connects to your phone via Bluetooth. There’s probably 100 different gauges to choose from but these are the ones that I use.
I was out west in March and this thing is a life saver; climbing trails you can get all your temps at a glance.
High transmission fluid warning light-8e5a5e2a-4e67-4ae3-849c-12685cae14da-jpg  High transmission fluid warning light-2d0c4d18-ddeb-45c2-86a9-568923dfa647-jpg
2019 TRD - Engine 0/5/10w30 - Diffs Redline GL-5 - BFG K02 - TC Redline GL-4 - Trans WS
Hammer0313 is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 02:22 PM #17
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
This is the only warning I’ve got related to my transmission, ironically this came up right after I hit the summit of a trail out west in Northern Arizona. It came up on my navigation screen with only 37k miles on my rig, no warning lights.
High transmission fluid warning light-e7c3a2e5-92ec-418a-a030-8b0a44887080-jpg
Old 06-28-2021, 02:38 PM #18
Skykomish's Avatar
Skykomish Skykomish is offline
Skykomish will become famous soon enough
Skykomish's Avatar
Originally Posted by Itchynuts View Post
That happened to me going up to cerro gordo (lone pine) 5k feet climb in 7 miles, consider putting in a tranny cooler
Second (or third or whatever) the trans cooler. I was regularly exceeding 230F in 4H up steep inclines until I put in a cooler, since I added it I haven't seen it exceed 190F even with very hard driving on hot days. It rarely gets above 170F and even when it does it drops pretty quickly once the load on the trans isn't so high.
Skykomish is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 03:41 PM #19
mike5 mike5 is offline
mike5 is on a distinguished road
Remember, Bishop is already at 4K feet. So you're likely higher. Your most likely issues (As mentioned) are that 1) you were in D (so lower RPMs, more slip) and 2) using 4H. Use 4L next time and shift the gears "manually" so you can keep the RPMs higher.
I've spent a lot of time in the hills of Bishop and lever had issues...
2013 T4R TE
My Adventures
mike5 is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 05:58 PM #20
Skykomish's Avatar
Skykomish's Avatar
I mean if you wanna roll around at high RPM and murder your range then sure. I haven't been in that area but I've spent quite a lot of time on forest roads where 4L is just gonna make your fuel consumption awful or needlessly add hours to a trip. My thought is that if the suspension can handle the speed, the trans better be able to as well. Cooler was the definitely best option for my driving style and the areas I frequent, zero regrets. The hardest part of the install was working around all my other mods.
Old 06-28-2021, 08:42 PM #21
slprciv slprciv is offline
Real Name: Nick
slprciv has a spectacular aura about slprciv has a spectacular aura about slprciv has a spectacular aura about
Real Name: Nick
Going through the mountains and switchbacks at Bishop I upgraded to a Derale tranny cooler. Best thing I ever did for the transmission. Temps never saw more the 195 degrees in ambient temperatures of mid 90s. Seeing the temps steady in my Scanguage prove the money spent was worth it.
The transmission cooler:
High transmission fluid warning light-screenshot_20200714-102838_samsung-internet-jpg
'18 TRD Off Road Premium w/KDSS.....and Kings, etc...
slprciv is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 08:44 PM #22
Real Name: Nick
Real Name: Nick
Before I had this i had to keep it in 4L to keep the temps down.
My setup:
High transmission fluid warning light-screenshot_20210628-174402_gallery-jpg
Old 06-28-2021, 09:45 PM #23
bglfgd bglfgd is offline
bglfgd is on a distinguished road
Probably not the worst idea to change that cooked fluid sooner than later.
Sent from my SM-G973U using Tapatalk
bglfgd is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 10:01 AM #24
alirawk's Avatar
alirawk alirawk is offline
alirawk will become famous soon enough
alirawk's Avatar
Once again — this forum does not disappoint. Thank you all so much for your kind insights.
2016 Toyota 4Runner -- Trail Premium
Icon Stage 2 suspension; Budbuilt Skid plates and rock sliders; Demello three-hoop front bumper with winch;
CBI swing out bumper with jerry cans, camp table & light; Goose Gear drawers & sleeping platform; Alu-Cab RTT/Shadow Awning; Prinsu rack with Heretic 40" light bar; Raingler nets; BF Goodrich AT K02 285 70/17; Dirty Parts dual battery kit; Prestigious Society Navigation Enhancement
alirawk is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 12:39 PM #25
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
The general consensus has been that there is no oil temp or oil pressure sensor, for that matter, in the 4R…at least no sensor that can deliver data to the OBDII. Is this incorrect?
1000MPH is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 01:53 PM #26
Hammer0313's Avatar
Real Name: Buck
Hammer0313's Avatar
Real Name: Buck
I’m getting a good reading on oil temps with the unit I use. Not sure the location of the sensor but I assume it’s post oil cooler.
Old 06-29-2021, 04:21 PM #27
DougR's Avatar
DougR DougR is offline
DougR is just really nice DougR is just really nice DougR is just really nice DougR is just really nice
DougR's Avatar
I can not find a 5th generation engine oil temperature sensor. I searched on Camelback Toyota using the terms "temperature sensor" and "engine oil temperature sensor". I also searched with Google "5th generation 4runner engine oil temperature sensor" and didn't find anything.
Your OBDLink MX+ is showing engine oil temperature 177.8 F which is too low if the engine is fully warmed up. Oil temperature leaving the engine and entering a cooler should be above 212, ideally 220-230 F to evaporate condensation in the crankcase. Your oil temperature is also less than coolant temperature, 186.8 F, which doesn't make sense if this is oil temperature exiting an oil/coolant heat exchanger. Why would Toyota measure coolant or oil temperature at the exit of a radiator or heat exchanger? When a technician wants to perform diagnostics, isn't it better to measure coolant and oil temperature exiting the engine block?
Have you observed an engine oil temperature reading in the 220 to 230 F range?
DougR is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 04:38 PM #28
Allow me to clarify. If you're driving 25MPH or higher speeds, then yes 4H makes sense. In that case if you leave it to the car, you'll be in 4th gear...causing higher transmission temps. In that case keep it in 3.
2013 T4R TE
My Adventures
Old 06-29-2021, 05:10 PM #29
Kamalani Mahie's Avatar
Kamalani Mahie Kamalani Mahie is offline
Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough Kamalani Mahie is a jewel in the rough
Originally Posted by alirawk View Post
Great stuff here. Thanks.
Will look into scangauge. You have any recommendations?
No problem. There are many OBDII devices out there that will give you lots of vehicle information so I definitely recommend looking at a bunch and deciding what's best for you. I chose the Scangauge II because it's been around forever, reliable, and great customer service. It's a dinosaur but so is the 4runner lol. I like that.
Originally Posted by RysiuM View Post
I just look at them and say: you have not the absolute slightest idea what you are talking about. This is 4Runner.
'15 Trail Premium, GOBI Stealth, CVT Summit Awning, ARB Safari Snorkel, TRD Pro susp. w/Bilstein 6112 coils & 1" spacer (front) & OME 895 (rear), 285/70/17 BFG KO2, Spidertrax wheel spacers, TRD Pro package (wheels, grill, valences, & skid), full RCI aluminum skids, C4 Fab diff skid, Toytec bump stop extensions, plenty of lights, patches, stickers, and other miscellaneous mods (backup & front camera, accessory meter display, rear window/hatch, bumper cup holders, Wit's End fire extinguisher mount, Ellis Precision TRD shift lever)
Kamalani Mahie is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 05:58 PM #30
DougR's Avatar
DougR's Avatar
Great stuff here. Thanks. Will look into scangauge. You have any recommendations?
I bought OBDLink MX+. It took awhile to set up 4 dashboards that gives me continuous real time data on my iPhone 8+ to the following parameters: 2 transmission fluid temps, coolant temp, battery voltage, 4 catalyst temps, 2 oxygen sensor voltages, 2 long term fuel trims, 2 short term fuel trims, total number of DTCs, number of emission related DTCs, total number of all cylinders misfire count, number of trouble codes, evaporator fin thermistor temp, and 4 tire pressures.
I have scanned for DTCs and none were found. I haven't tried the data log, monitor or mapping features. I will load OBDLink software on my laptop when the weather is cooler.
When launching the app, one has to select a connection to a particular system, such as Network A (engine, steering, airbag, a/c, driveline, etc), Tire Pres Monitor, Network F (vehicle body), Telematics, Immobiliser, and Occupant Detection. I haven't tried using the last 4 features. Note, each network is separate, therefore, when looking at tire pressures, one cannot simultaneously view engine data because each network has a different control unit.
Overall, I like how the information is displayed and I wanted something easy to use. BlueDriver is another one to consider. Google search BlueDriver vs OBDLink MX+.
concern , didn’t , high , light , rig
high transmission fluid temperature? rnb754 5th gen T4Rs 22 04-21-2017 02:24 PM
A/T oil temp warning light and battery warning light concern arki01 3rd gen T4Rs 3 05-23-2015 10:45 PM
T4R sold in US doesn't have windsheild washer fluid warning light, right? sunnyside 4th Gen T4Rs 18 02-17-2010 01:17 PM
Low windshield washer fluid warning light Redstone8 4th Gen T4Rs 9 01-24-2009 10:46 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
