Old 06-28-2021, 02:39 PM #16
meltdown meltdown is offline
meltdown will become famous soon enough
What PSI For 275/55R20 Tires?
27 psi.
Assuming the stock tires were SL (107 load index) at 32 psi they will carry 1940 lbs. Your new tire is XL (117 load index). At 27 psi, it can carry 1987 lbs.
Those weights actually seem low for the 4Runner though. I was thinking they should be around 2200 - 2300lbs.
Im running 33 psi on my XL tires, but they are 116 load index. Still dialing them in as well.
2014 MGM TEP - Dobinsons’ C59-300, Bilstien 5100 (front set to stock height), Cornfed 1/2 spacers in rear, Spidertrax, Airlift 1000
meltdown is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 03:56 PM #17
Tuco S.'s Avatar
Tuco S. Tuco S. is offline
Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about Tuco S. has a spectacular aura about
Tuco S.'s Avatar
Yep, your tires are the XL load so try 27 psi. That should get you in the ballpark. You can always fine tune later on with a chalk test.
Lots of tire shops over-inflate them when new as it supposedly helps the tires to seat. I always check psi on every tire right after I leave the tire shop because pressures can be all over the place.
If your car is pulling to one side at 27 psi, you might want to get an alignment check.
2019 TRD Off Road w/KDSS in silver. Dobinsons IMS59-50700 & C59-314 front (coil seats lowered 1/2"), IMS59-50705 & C59-505 rear; Dobinsons diff drop; Ironman UCAs; Eimkeith PCK, Ironman adjustable panhard rod, and Treaty Oak KDSS spacers; Toyo Open Country A/T III 255/80R17; C4 Fab skids & Shrockworks sliders; Durobumps front & rear.
Tuco S. is offline   Reply With QuoteReply With Quote
Old 06-28-2021, 03:56 PM #18
Frasher4Runner's Avatar
Frasher4Runner Frasher4Runner is offline
Frasher4Runner is on a distinguished road
Originally Posted by meltdown View Post
27 psi.
That’s what I was coming out with as well. I guess I’ll air down and see how it goes.
Sent from my iPhone using Tapatalk Pro
Frasher4Runner is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 01:34 PM #19
NYRunner NYRunner is offline
NYRunner will become famous soon enough
Am I crazy for preferring to keep my 20” Yokohama’s inflated to 35/36psi? My truck feels much nimbler that way than at 32...
2010 Mag Grey Limited 4X4
NYRunner is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 01:46 PM #20
I decided to call Cooper Tires and ask them what PSI they recommended for my new tires. I gave the lady my vehicle info, old tire size, PSI recommendation on the vehicle and the new tire size. She looked it up and said her book said 26 PSI (so I guess the 27 that the one website was spitting out for me was accurate) but recommended I run 30-32 to keep the low tire pressure light from coming on.
Old 06-29-2021, 03:16 PM #21
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
If it were me, I would run them at correct psi and re-program your tire pressure sensors.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 03:29 PM #22
How’s that done? Can I do it or would it have to be a dealer or tire shop?
Old 06-29-2021, 04:25 PM #23
Tuco S.'s Avatar
Tuco S.'s Avatar
The place you bought the tires should be able to do it.
Old 06-29-2021, 05:05 PM #24
I'll check on that, thanks.
Old 06-29-2021, 09:17 PM #25
jam36a jam36a is offline
jam36a is on a distinguished road
Falken Wildpeaks AT3's
I am in Florida and run 40 psi. It suits me well, great traction and gas mileage. No shakes or vibrations.
jam36a is offline   Reply With QuoteReply With Quote
Old 06-30-2021, 09:20 PM #26
Definitely better gas mileage for me at 35/36 on my stock geolanders than at 32 as well
275/55r20 , factory , psi , they’re , tires
275/55r20 Tire pressure? 17Jetta 5th gen T4Rs 9 11-01-2022 10:10 PM
Nokian WR G3 SUV 275/55R20 ? rblt Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-27-2020 12:06 AM
2010 OEM 4Runner Limited wheels with 275/55r20 tires - Mapleton, Utah - $275 jffgrdnr For Sale: Suspension/Wheels/Tires 4 04-29-2019 10:19 AM
285 55r20 on 20x9 wheels TRD_SR5 5th gen T4Rs 11 10-02-2017 04:36 PM
Calgary Alberta 2012 limited 20 inch wheels and 275/55r20 Cooper tires FJ Cruiser Matt For Sale: Suspension/Wheels/Tires 0 11-20-2015 02:49 AM
